    Code Error A0B
    15 Posts 5 Posters 849 Views 5 Watching
      Something is amiss with your setup.
      If you have Libfredo installed can you run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command and copy/paste the output into your reply?
      Can you confirm the versions of Clothworks and Sketchucation Tools you are running too?
        Sica3
        erro: CODE ERROR A0B, como resolver tem as licenças os gulguis foram instalados aparece esse erro: CODE ERROR A0B
          Sica3
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
              Sica3
              Fredo6 Plugins Information on 2025-02-28 07:51:43 -0300
              • Sketchup: 25.0.571
              • LibFredo6: v15.0a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                Curviloft v2.0a
                FredoCorner v2.7a
                FredoScale v3.6a
                FredoTools v4.5c
                JointPushPull v4.8a
                RoundCorner v3.4a
                ToolsOnSurface v2.4a
                Signature File: 2022-06-07 09:59:39 -0300
                Curviloft: 2023-01-11 13:37:45 -0300
                Curvizard: 2022-08-23 10:13:42 -0300
                JointPushPull: 2022-09-21 13:32:55 -0300
                ToolsOnSurface: 2023-02-22 09:48:29 -0300
                Sica3
                  Please delete your signate file at C:\Users\SomeName\AppData\Local\SCF Licenses
                  Restart SketchUpand activate any license
                    Sica3
                    Thanks for your help, they're working now. Captura de tela 2025-02-28 093535.png
                    That one didn't work ?
                      Yes, because it is Fredo Corner not Round Corner. Different extensions
                        Sica3
                        Ok, I understand
                          pavulon5
                          I have the same problem. I bought roundcourner and i can't activate license.
                          Fredo6 Plugins Information on 2025-08-21 14:47:11 +0200
                          • Platform: x64-mingw32 - Ruby: 2.5.5
                          • Sketchup: 20.2.172
                          • LibFredo6: v15.4d
                          • Fredo6 Plugins
                            Curviloft v1.8a
                            FredoScale v3.1a
                            FredoTools v4.0b
                            JointPushPull v4.4e
                            RoundCorner v3.4a
                            Signature File: 2020-11-03 19:38:01 +0100
                            ClothWorks: 2021-02-02 11:29:08 +0100
                            Rich O Brien Moderator @pavulon5
                            @pavulon5
                            Might be a permissions issue. Repair your SketchUp install by downloading the SketchUp installer. Right-click the .exe and choose Run as Admin and choose Repair when prompted
                            If your device is named using non-alphanumeric characters, áéíóú etc, please change it to only use alphanumeric.
                            Other option is to go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete your signature file. Restart SketchUp to generate a new one and try license.
                            The error is related to the signature file.
