    Code Error A0B
    15 Posts 5 Posters 849 Views 5 Watching
    • V Offline
      Vanessa12 Newcomers
      Hi everyone,
      I have a big problem.
      I bought a clothworks licence but when i try to install it, a error message appears : CODE ERROR A0B
      Has anyone had this problem and managed to resolve it please ?
      Thanks a lot i really need to resolve it to finish my project
        That error relates to the file time mismatch.
        Have you recently changed your computers clock/date ?
        Can you post a screenshot of the whole error message...
        It might help is identify where you've gone wrong...
        • V Offline
          Vanessa12 Newcomers
          Thanks a lot for you help
          I didn't change anything about date or hour
          I'm really desperate ...
            Something is amiss with your setup.
            If you have Libfredo installed can you run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command and copy/paste the output into your reply?
            Can you confirm the versions of Clothworks and Sketchucation Tools you are running too?
              Sica3
              erro: CODE ERROR A0B, como resolver tem as licenças os gulguis foram instalados aparece esse erro: CODE ERROR A0B
                Sica3
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    Sica3
                    Fredo6 Plugins Information on 2025-02-28 07:51:43 -0300
                    • Sketchup: 25.0.571
                    • LibFredo6: v15.0a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      FredoCorner v2.7a
                      FredoScale v3.6a
                      FredoTools v4.5c
                      JointPushPull v4.8a
                      RoundCorner v3.4a
                      ToolsOnSurface v2.4a
                      Signature File: 2022-06-07 09:59:39 -0300
                      Curviloft: 2023-01-11 13:37:45 -0300
                      Curvizard: 2022-08-23 10:13:42 -0300
                      JointPushPull: 2022-09-21 13:32:55 -0300
                      ToolsOnSurface: 2023-02-22 09:48:29 -0300
                      Sica3
                        Please delete your signate file at C:\Users\SomeName\AppData\Local\SCF Licenses
                        Restart SketchUpand activate any license
                          Sica3
                          Thanks for your help, they're working now. Captura de tela 2025-02-28 093535.png
                          That one didn't work ?
                            Yes, because it is Fredo Corner not Round Corner. Different extensions
                              Sica3
                              Ok, I understand
                                pavulon5
                                I have the same problem. I bought roundcourner and i can't activate license.
                                Fredo6 Plugins Information on 2025-08-21 14:47:11 +0200
                                • Platform: x64-mingw32 - Ruby: 2.5.5
                                • Sketchup: 20.2.172
                                • LibFredo6: v15.4d
                                • Fredo6 Plugins
                                  Curviloft v1.8a
                                  FredoScale v3.1a
                                  FredoTools v4.0b
                                  JointPushPull v4.4e
                                  RoundCorner v3.4a
                                  Signature File: 2020-11-03 19:38:01 +0100
                                  ClothWorks: 2021-02-02 11:29:08 +0100
                                  Rich O Brien Moderator @pavulon5
                                  @pavulon5
                                  Might be a permissions issue. Repair your SketchUp install by downloading the SketchUp installer. Right-click the .exe and choose Run as Admin and choose Repair when prompted
                                  If your device is named using non-alphanumeric characters, áéíóú etc, please change it to only use alphanumeric.
                                  Other option is to go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete your signature file. Restart SketchUp to generate a new one and try license.
                                  The error is related to the signature file.
