    Computer Died
    36 Posts 4 Posters 2.3k Views 4 Watching
    • Gus RG Offline
      Gus R
      This sucks.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        Rich O Brien Moderator @Gus R
        @Gus-R said in Computer Died:
        This sucks.
        Yes, mirrored backups would save you a ton of time and frustration.
        I use this to create images and sync weekly.
        Windows 11 doesn't do a good job letting a user know its available as it pushes you to use their OneDrive option. But if you launch classic Control Panel you'll find it under System & Security.
        Won't help you with your current situation but for future its probably worth it.
        • Gus RG Offline
          Gus R @Rich O Brien
          @Rich-O-Brien Is that an external drive?
            yeah, its a Samsung Portable SSD T7
            • Gus RG Offline
              Gus R
              All systems go. Ready for Autocad.
              Surprised at how much was saved.
              • Gus RG Offline
                Gus R @Gus R
                @Gus-R Lost the start menu. I give up.
                  Windows Start menu? Run Terminal with Admin and try:
                  sfc \scannow
                  Maybe a recent OS update didn't finish correctly. I get Explorer issues now and then in Windows 11and its always after they release a patch.
                    Windoze crapdates seem to be at the heart of a lot of issues...
                    1 Reply Last reply Reply Quote -1
                    • Gus RG Offline
                      Gus R
                      I created a new profile (user) and it works. I don't know what I did. I've tried everything. Including doing a Window.iso install. Nothing changed. It wasn't the OS. It's the profile. That means moving everything over to the new profile.
                      • Gus RG Offline
                        Gus R
                        Looks like moving everything over to a new profile will be a real nightmare.
                        What's broken:
                        Start menu broken
                        Search in start menu broken
                        Calendar won't open
                        Can't create new user in normal Windows boot
                        Everything else is working fine. A new profile won't pay the bills.
                        Microsoft of course doesn't have a straight answer. It's not like the old days when you could re-install something from a disc.
                          Anytime I'm refreshing my device with a clean install I never sign in to microsoft.
                          There's a tool I use by Chris Titus that runs a series of commands to completely debloat windows and turn off all of its telemetry etc.
                          Digital Downloads
                          WinUtil Documentation Website Troubleshooting
                          Chris Titus Tech | Tech Content Creator (christitus.com)
                          There's also Microwin if you feel brave.
                          • Gus RG Offline
                            Gus R @Rich O Brien
                            @Rich-O-Brien Thanks Rich.
                            I either forget about these problems and just work with what I have or I start all over again with a clean install. I'd have to get an external drive since my current work profile is huge and it includes my documents directory. Everything else is still on my work hard drive which is separate. I think if I copy over to a new profile it might be a big mess. I don't know what to do yet. I suppose I have to figure out if transferring everything to the new profile or starting over would be easier. The original repair was $639.
                            I should have become a mailman.
                            • Gus RG Offline
                              Gus R @Gus R
                              Holy smokes I think I fixed it. It was the Windows Font Cache Service.
                              https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/start-menu-and-others-broken-in-profile/cbb2a51b-081e-426d-a4c2-b3a276e5b263
                                Are you tired after jumping through all those hoops?
                                Cirque du Soleil are hiring: https://careers.cirquedusoleil.com/
                                To be honest, its not nice seeing the direction Microsoft are going with Windows OS. It's intrusive and since Windows 7 it feels like things are getting bolted on willy nilly.
                                I'd never go Mac but if I could go Linux I would.
                                • Gus RG Offline
                                  Gus R @Rich O Brien
                                  @Rich-O-Brien Right? Microsoft always has the same cut and paste answers. It was sort of by accident that I found the answer and as is often the case I had to find the answer myself. I was bolt up trying to fix this thing since Friday and 20 packs of cigarettes later I fixed the damn thing. Maybe this is the answer for the commonly disappearing start menu with other people? I don't know.
                                  I should add that the answer I found wasn't directly associated with my issue. All I saw was "Windows Font Cache" and went from there.
                                  I saw Cirque du Soleil many moons ago in San Francisco.
                                  • 2 / 2
