    Crash at sketchup startup, what can I do?
    8 Posts 3 Posters 433 Views 3 Watching
    • alexpacio2013A Offline
      alexpacio2013
      I am not a programmer, I created a Ruby script to check which files are automatically loaded at sketchup startup to understand which one is crashing my sketchup 2024 at startup. The plugin creates a log file and the last part of the startup log lists these last scripts loaded and I think that the plugin that crashes the system is cold Lord of the toolbars. What can I do to solve it? By restarting sketchup several times, it starts without problems but most of the time it crashes. I would not like to disable Lord of the toolbars, for me it is indispensable.
      [10:47:14] Caricamento: tt_vertex2/bridge
      [10:47:14] Caricamento: tt_vertex2/geom3d
      [10:47:14] Caricamento: tt_vertex2/quadface
      [10:47:14] Caricamento: tt_vertex2/edges
      [10:47:14] Caricamento: tt_vertex2/editor
      [10:47:14] Caricamento: tt_vertex2/l10n
      [10:47:14] Caricamento: tt_vertex2/vertices
      [10:47:14] Caricamento: tt_vertex2/geom2d
      [10:47:14] Caricamento: tt_vertex2/gl_ui
      [10:47:14] Caricamento: tt_vertex2/length
      [10:47:14] Caricamento: tt_vertex2/license
      [10:47:14] Caricamento: tt_vertex2/numeric
      [10:47:14] Caricamento: tt_vertex2/observable
      [10:47:14] Caricamento: tt_vertex2/proxy_tools
      [10:47:14] Caricamento: tt_vertex2/relax
      [10:47:14] Caricamento: tt_vertex2/selection
      [10:47:14] Caricamento: tt_vertex2/ui
      [10:47:14] Caricamento: tt_vertex2/app_commands
      [10:47:14] Caricamento: tt_vertex2/app_settings
      [10:47:14] Caricamento: tt_vertex2/uv_mapping
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6_txtmsg
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6G6
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6FaceSelector
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6SelMode
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Translate
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Tool
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Spline
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6RoundingProfiler
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6WebHtml
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Marshall
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Algo
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Contour
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Offset3d
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Transform
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6Mark
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6ParameterManager
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6EdgePicker
      [10:47:14] Caricamento: Fredo6_!LibFredo6/body_Lib6CameraManager
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsCleanScreenDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsFindDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsHelp
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsJS
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsManager
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsMasterDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsNative
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsPersoDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsPrintDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsTlbPropDialog
      [10:47:15] Caricamento: C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!!Fredo6_LordOfTheToolbars/LordOfTheToolbarsVignetteDialog
      [10:47:15] Caricamento: Fredo6_!LibFredo6/body_Lib6Vault
      [10:47:15] Caricamento: Fredo6_!LibFredo6/body_Lib6Marshall
      [10:47:15] Caricamento: Fredo6_!LibFredo6/body_Lib6Shortcuts
      [10:47:15] Caricamento: Fredo6_!LibFredo6/body_Lib6MonoFactory
      [10:47:16] Caricamento: Fredo6_!LibFredo6/body_Lib6NativeManager
      [10:47:17] Caricamento: Fredo6_!LibFredo6/body_Lib6ChromiumJS
      [10:47:17] Caricamento: Fredo6_!LibFredo6/body_Lib6ChromiumWdlg
      @fredo6
        Prevent LOTT from loading and confirm it is the cause.
        Then re-enable it and disable VT2 and see if it too resolves clashing.
        You can then deduce that LOTT and VT2 have issues when running in tandem.
        alexpacio2013A 1 Reply Last reply Reply Quote 0
          alexpacio2013 @Rich O Brien
          @Rich-O-Brien Actually if I disable vertex tools2 it starts. Now I disable vt2 and once it starts I re-enable it with the Sketchup plugins manager panel and it works. It's a problem only at startup. Now I'll do further tests and update you.
            Does VertexTools need TT's Lib ?
            Have you tried installing that ?
              alexpacio2013 @TIG
              @TIG I only disabled vertex tools I did not disable lib di TT
              TIGT 1 Reply Last reply Reply Quote 0
                TIG Moderator @alexpacio2013
                @alexpacio2013
                Sorry, but you misunderstood what I meant.
                If VertexTools was enabled but LibTT was not loading [or not installed] then that could cause some weirdness.
                However, it seems that the issue is between VertexTools and LOTT clashing...
                  alexpacio2013 @TIG
                  @TIG
                  Yes sorry, However as you say the problem is an interference between vertex tools and lord of the toolbar. Is it possible to pass this problem to Fredo?
                    @alexpacio2013
                    Prefix a member's name with a @ and they are notified of the mention.
                    @fredo6
