    Plugins as a source of bugsplat etc.
    Scheduled Pinned Locked Moved Resources
    25 Posts 4 Posters 2.9k Views 4 Watching
      So you have another extension loading which causes the issue !
      MX
      Which in turn has a Util module
      which sets an object camera on
      Relating to Sketchup::Page.
      It then has unloading Fire data load
      Resulting in 1AA Also Extended Cut
      Which are all called by OnActiveModelChanged
      Or to put it more simply...
      You have an extension which creates a module called
      MX
      This adds an observer to the model
      This seems to run all the time - perhaps activating as the extension is loaded.
      When the model changes something happens with its code as it looks at pages [scenes], and it can cause a BugSplat.
      So it's not directly related to Extrude Tools at all - a 3rd party extension is hijacking your model and splatting when something happens in another extension...
      Search through your extensions and find one setting up module MX - that's the real culprit.
        I thank you, Sir.
          Maxwell render. I have spoken to next limit, no solution.
          I saved the file post extrude, before doing anything else and the file save OK WITH the extrusion.
            It worked once, not again.
              OK, went with the next limit suggestion of disabling maxwell render, none of these methods worked so I removed maxwell render completely. Extrusion tools now works perfectly well.
              Waiting for next limit to come up with a fix but not holding my breath.
                OK, Transmutr failing now. Completely removed sketchup. Nothing left for the time being.
                  OK, reinstalled, when I got to installing curviloft and cleanup, Sketchup opened slowly. I disabled those two plugins and SKetchup opens normally. Not tried Transmutr yet.
                    Transmutr from within SKetchup will open, but does not import the transmuted file, simply transmutes it.
                      Sounds like you are in a right mess. Is Maxwell still supported?
                        Too many issues appearing all over the place to give a clear picture I can see, no more chillblast pc's coming my way. Being lied to about simple issues is a step too far.
                            Sketchup is slow to load the welcome screen. Only takes a few plugins to get that way too. No bugsplats and maxwell render reinstalled, working. Clueless at the moment.
                              OK, Fernando at Next Limit had a look around the PC, say's apart from an hdd where an ssd should be it is sound. Renamed maxwell.rb to maxwell.rb00 and the slow startup was cured. After renaming it maxwell.rb, still no error. He cannot explain it either.
                              Gremlins in the mix or perhaps it has been taken over by aliens, possibly even from Dagenham east?
                              • 2 / 2
