    Plugins as a source of bugsplat etc.
    Scheduled Pinned Locked Moved Resources
    25 Posts 4 Posters 2.9k Views 4 Watching
      TIG Moderator @Mike Amos
      @Mike-Amos
      Do you have the latest version of my Extrusion Tools installed ?
      If so what are you trying to do when it 'splats' ??
      It shouldn't clash with anything else when it's not in use, so it seems to be something you are trying to do...
      Several of its functions were superseded with the superior Fredo6 tools like CurviLoft...
        I have the latest version installed. I use extrude edges by rails because it gives more control over the result than curviloft. I do use both from time to time to see which gives best results on different car parts. For the creation of front wing units I prefer Extrude tools for the most part.
        For some reason just lately after I select no to delete the original lines, instant bugsplat. There is however another piece of odd behaviour where setting markers with the measuring tool, I will see two dotted lines when i finish using the tool.
        Not sure where the issue lies tbh. Graphics card glitch?Extrude Tools Lines.jpg
          I have tried this with simpler models and it is 100% repeatable.
            Extrude Tools - if you select yes to delete the original lines, is it then splat free ?
            I assume you refer to the native measuring tool - are you 'toggling' between guide liens and points [which will have a short guide attached] ?
              Not toggling and deleting original lines results in bugsplat too.
              The guidelines thing is something I notice happens, a 'lag' when I finish setting the guidelines.
              TIGT 1 Reply Last reply
                @Mike-Amos
                So to be clear...
                When you use the EEbyRails and it gets to the prompt to keep or delete the original lines it splats in v24 - irrespective of which choice you make....
                I've retested it and can't get the same issue - .
                If you open the Ruby Console and retry the EEbyRails are there any error messages at all, before the 'splat' ?
                Mike AmosM 1 Reply Last reply
                  Mike Amos @TIG
                  Tried twice, this is all I havbe seen.
                    So you have another extension loading which causes the issue !
                    MX
                    Which in turn has a Util module
                    which sets an object camera on
                    Relating to Sketchup::Page.
                    It then has unloading Fire data load
                    Resulting in 1AA Also Extended Cut
                    Which are all called by OnActiveModelChanged
                    Or to put it more simply...
                    You have an extension which creates a module called
                    MX
                    This adds an observer to the model
                    This seems to run all the time - perhaps activating as the extension is loaded.
                    When the model changes something happens with its code as it looks at pages [scenes], and it can cause a BugSplat.
                    So it's not directly related to Extrude Tools at all - a 3rd party extension is hijacking your model and splatting when something happens in another extension...
                    Search through your extensions and find one setting up module MX - that's the real culprit.
                      I thank you, Sir.
                        Maxwell render. I have spoken to next limit, no solution.
                        I saved the file post extrude, before doing anything else and the file save OK WITH the extrusion.
                          It worked once, not again.
                            OK, went with the next limit suggestion of disabling maxwell render, none of these methods worked so I removed maxwell render completely. Extrusion tools now works perfectly well.
                            Waiting for next limit to come up with a fix but not holding my breath.
                              OK, Transmutr failing now. Completely removed sketchup. Nothing left for the time being.
                                OK, reinstalled, when I got to installing curviloft and cleanup, Sketchup opened slowly. I disabled those two plugins and SKetchup opens normally. Not tried Transmutr yet.
                                  Transmutr from within SKetchup will open, but does not import the transmuted file, simply transmutes it.
                                    Sounds like you are in a right mess. Is Maxwell still supported?
                                      Too many issues appearing all over the place to give a clear picture I can see, no more chillblast pc's coming my way. Being lied to about simple issues is a step too far.
                                          Sketchup is slow to load the welcome screen. Only takes a few plugins to get that way too. No bugsplats and maxwell render reinstalled, working. Clueless at the moment.
                                            OK, Fernando at Next Limit had a look around the PC, say's apart from an hdd where an ssd should be it is sound. Renamed maxwell.rb to maxwell.rb00 and the slow startup was cured. After renaming it maxwell.rb, still no error. He cannot explain it either.
                                            Gremlins in the mix or perhaps it has been taken over by aliens, possibly even from Dagenham east?
