    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek @gullfo
      @gullfo
      Post a screenshot or send me some via email (nathan@medeek.com) so I can get a better idea what this looks like. I will give it some consideration.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      gullfoG 1 Reply Last reply Reply Quote 0
      • gullfoG Offline
        gullfo @medeek
        @medeek I'm away until Thurs I'll send some then
        Glenn
        http://www.runnel.com
        • medeekM Offline
          medeek
          design.medeek.com
          • gullfoG Offline
            gullfo
            wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
            Glenn
            • medeekM Offline
              medeek
              Very interesting. Let me see what I can do.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.7.2 - 10.13.2024
                • Fixed a critical bug with the in-wall column module.
                • Added the following additional Wide Flange (W14) beams to the beam module: W14X38, W14X43, W14X48, W14X53, W14X61, W14X68, W14X74, W14X82, W14X90, W14X99
                • Added the following additional Wide Flange (W16) beams to the beam module: W16X45, W16X50, W16X57, W16X67, W16X77, W16X89, W16X100
                • Enabled a wood grain and an end grain material for glulam beams within the beam module.
                • Enable additional built-in materials for "Custom" in-wall columns.
                • Added the following (27 - low poly) Simpson column bases to the post module: CB7_6, CB1212, CB1012, CB1010, CB812, CB810, CB718_7, CB718_6, CB718_4, CB612, CB610, CB88, CB86, CB68, CB64, CB48, CB46, CB9_105, CB9_75, CB9_9, CB9_6, CB7_105, CB7_75, CB7_9, CB6_7, CB5_45, CB5_6
                • Added the following (6 - low poly) Simpson column caps to the post module: CCQ84, CCQ86, CCQ94, CCQ96, CCQ98, CCQ106
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.7.2b - 10.14.2024
                  • Added in the remainder of the commonly available wide flange beams (W4 thru W44).
                  I think it comes to just a little over 250 different W flange beam profiles. However I'm sure there are some profiles I am missing or that are not as standard, if so let me know and I will add them in.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.7.3 - 10.14.2024
                    • Added a duplicate post check to the regen module for post assemblies.
                    • Added a duplicate beam check to the regen module for beam assemblies.
                    • Added a duplicate stair check to the regen module for stair assemblies.
                    • Added in the remainder of the commonly available wide flange beams (W4 thru W44) to the post module.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.7.5 - 10.23.2024
                      • Added the following (9 - low poly) Simpson post caps to the post module: LPC4_4, LPC4_6, LPC4_8, LPC6_4, LPC6_6, LPC6_8, PC4, PC6, PC8
                      • Added the following (10 - low poly) Simpson post bases to the post module: ECB88, ECB66, EPB66, EPB46, EPB44, MPB44, MPB66, MPB88, PPBF44, PPBF66
                      The post module now has 86 post caps and 65 post bases within its built-in library. I think I've modeled about 75% of the Simpson Strong-Tie's Wood Construction Connectors Catalog at this point.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I will be running a Thanksgiving promotion beginning Nov. 11th until Dec. 5th with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS24.
                        This will reduce the bundle price from $280.00 USD to $162.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Dec. 5th and no rain checks will issued thereafter.
                        design.medeek.com
                        I running this promotion a bit earlier this year to also coincide with the ongoing SketchUp Basecamp (Nov. 11-14, 2024):
                        (3dbasecamp.sketchup.com)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 53: Multi-Landing Stairs (10:21)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Switching between landing and no-landing:
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.7.7 - 12.12.2024
                              • Added a "Calculated Parameters" section to the edit menu of the stair module.
                              • Added the ability to create L-Shape, U-Shape and Straight runs of stairs with landings.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 54 - Stairs with Landings (13:27 min.)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  With each landing being configurable, its possible to mix and match some of the landings:
                                  wall_su814_800.jpg wall_su815_800.jpg wall_su816_800.jpg wall_su817_800.jpg wall_su818_800.jpg wall_su819_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    First look at double landing configurations with 2-step and 3-step L-winders:
                                    wall_su820_800.jpg wall_su821_800.jpg wall_su822_800.jpg wall_su823_800.jpg wall_su824_800.jpg wall_su825_800.jpg wall_su826_800.jpg
                                    design.medeek.com
                                    • gullfoG Offline
                                      gullfo @medeek
                                      that looks like a lawsuit just waiting to happen lol πŸ™‚
                                      Glenn
                                      • medeekM Offline
                                        medeek
                                        Tutorial 55 - Complex Stairs</a> (9:57 min.)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Since I've been focusing on updating the stair module the last week I've had quite a number of requests for various things. One request is the ability to flare out the bottom of the stairs. I can add in this functionality however to start with it would be very rudimentary (just a modification to the treads and risers as shown):
                                          I'm not entirely sure how one would go about in-fill framing the flared portion, nor do I think there is any established or standard way to do this, I could be wrong. Any thoughts or ideas in this regard? I should probably ask first if this is something that you would all want or even need.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            First look at an inverted T-Shape staircase with a straight and a curved flare:
                                            design.medeek.com
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 75
                                            • 76
                                            • 62 / 76
