    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 3.6.9 - 07.23.2024
      • Enabled "Remove Cladding Lines" for 3D cladding materials.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.7.0 - 07.25.2024
        • Added a duplicate wall check to the regen module for all wall types.
        Tutorial 51 - Duplicating Walls (6:15 min.)
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.7.1 - 09.17.2024
          • Added a vertical offset parameter for in-wall column king studs.
          In the case where you have a beam pocket and king studs over top of a door or window this update is critical. Previously the king studs would simply project to the bottom plate in the wall passing through the opening. Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset. Note that the offset can be both positive or negative or zero (default)
          design.medeek.com
          gullfoG 1 Reply Last reply Reply Quote 1
          • gullfoG Offline
            gullfo @medeek
            honestly though, if i was putting in a beam support over the opening, i've have either an additional jack stud under the header/lintel, or a X x X sized column on either side, and likely as well as a glulam etc type header/lintel. unless the beam was only supporting some deadweight and not a live area above. just me probably...
            Glenn
            http://www.runnel.com
            • medeekM Offline
              medeek
              I wasn't paying attention to a realistic header with trimmers, just focusing on the king stud offset, I agree, a few things would need to be beefed up to handle this type of beam configuration. I've only actually engineered one job with this type of beam over window(s).
              design.medeek.com
              • gullfoG Offline
                gullfo @medeek
                i don't have to do it often but a couple of recent projects have beams over doors to address the extended span of a room with the door the best option - in those cases we used steel i-beams as posts and header as well as the new beam in order to get the load supported needed with lower profile than wood products. so it's rarely needed but a useful option when you can get around to it. maybe even just leaving the space so manually someone could insert the members / assemblies would work.
                Glenn
                medeekM 1 Reply Last reply Reply Quote 0
                • medeekM Offline
                  medeek @gullfo
                  @gullfo
                  Post a screenshot or send me some via email (nathan@medeek.com) so I can get a better idea what this looks like. I will give it some consideration.
                  design.medeek.com
                  gullfoG 1 Reply Last reply Reply Quote 0
                  • gullfoG Offline
                    gullfo @medeek
                    @medeek I'm away until Thurs I'll send some then
                    Glenn
                    • medeekM Offline
                      medeek
                      design.medeek.com
                      • gullfoG Offline
                        gullfo
                        wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
                        Glenn
                        • medeekM Offline
                          medeek
                          Very interesting. Let me see what I can do.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.7.2 - 10.13.2024
                            • Fixed a critical bug with the in-wall column module.
                            • Added the following additional Wide Flange (W14) beams to the beam module: W14X38, W14X43, W14X48, W14X53, W14X61, W14X68, W14X74, W14X82, W14X90, W14X99
                            • Added the following additional Wide Flange (W16) beams to the beam module: W16X45, W16X50, W16X57, W16X67, W16X77, W16X89, W16X100
                            • Enabled a wood grain and an end grain material for glulam beams within the beam module.
                            • Enable additional built-in materials for "Custom" in-wall columns.
                            • Added the following (27 - low poly) Simpson column bases to the post module: CB7_6, CB1212, CB1012, CB1010, CB812, CB810, CB718_7, CB718_6, CB718_4, CB612, CB610, CB88, CB86, CB68, CB64, CB48, CB46, CB9_105, CB9_75, CB9_9, CB9_6, CB7_105, CB7_75, CB7_9, CB6_7, CB5_45, CB5_6
                            • Added the following (6 - low poly) Simpson column caps to the post module: CCQ84, CCQ86, CCQ94, CCQ96, CCQ98, CCQ106
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.7.2b - 10.14.2024
                              • Added in the remainder of the commonly available wide flange beams (W4 thru W44).
                              I think it comes to just a little over 250 different W flange beam profiles. However I'm sure there are some profiles I am missing or that are not as standard, if so let me know and I will add them in.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.7.3 - 10.14.2024
                                • Added a duplicate post check to the regen module for post assemblies.
                                • Added a duplicate beam check to the regen module for beam assemblies.
                                • Added a duplicate stair check to the regen module for stair assemblies.
                                • Added in the remainder of the commonly available wide flange beams (W4 thru W44) to the post module.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.7.5 - 10.23.2024
                                  • Added the following (9 - low poly) Simpson post caps to the post module: LPC4_4, LPC4_6, LPC4_8, LPC6_4, LPC6_6, LPC6_8, PC4, PC6, PC8
                                  • Added the following (10 - low poly) Simpson post bases to the post module: ECB88, ECB66, EPB66, EPB46, EPB44, MPB44, MPB66, MPB88, PPBF44, PPBF66
                                  The post module now has 86 post caps and 65 post bases within its built-in library. I think I've modeled about 75% of the Simpson Strong-Tie's Wood Construction Connectors Catalog at this point.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I will be running a Thanksgiving promotion beginning Nov. 11th until Dec. 5th with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS24.
                                    This will reduce the bundle price from $280.00 USD to $162.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Dec. 5th and no rain checks will issued thereafter.
                                    design.medeek.com
                                    I running this promotion a bit earlier this year to also coincide with the ongoing SketchUp Basecamp (Nov. 11-14, 2024):
                                    https://3dbasecamp.sketchup.com/en
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 53: Multi-Landing Stairs (10:21)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Switching between landing and no-landing:
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.7.7 - 12.12.2024
                                          • Added a "Calculated Parameters" section to the edit menu of the stair module.
                                          • Added the ability to create L-Shape, U-Shape and Straight runs of stairs with landings.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 54 - Stairs with Landings (13:27 min.)
                                            design.medeek.com
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 79
                                            • 80
                                            • 70 / 80
