    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 3.7.5 - 10.23.2024
      • Added the following (9 - low poly) Simpson post caps to the post module: LPC4_4, LPC4_6, LPC4_8, LPC6_4, LPC6_6, LPC6_8, PC4, PC6, PC8
      • Added the following (10 - low poly) Simpson post bases to the post module: ECB88, ECB66, EPB66, EPB46, EPB44, MPB44, MPB66, MPB88, PPBF44, PPBF66
      The post module now has 86 post caps and 65 post bases within its built-in library. I think I've modeled about 75% of the Simpson Strong-Tie's Wood Construction Connectors Catalog at this point.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I will be running a Thanksgiving promotion beginning Nov. 11th until Dec. 5th with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS24.
        This will reduce the bundle price from $280.00 USD to $162.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Dec. 5th and no rain checks will issued thereafter.
        design.medeek.com
        I running this promotion a bit earlier this year to also coincide with the ongoing SketchUp Basecamp (Nov. 11-14, 2024):
        https://3dbasecamp.sketchup.com/en
        design.medeek.com
        • medeekM
          medeek
          Tutorial 53: Multi-Landing Stairs (10:21)
          design.medeek.com
          • medeekM
            medeek
            Switching between landing and no-landing:
            design.medeek.com
            • medeekM
              medeek
              Version 3.7.7 - 12.12.2024
              • Added a "Calculated Parameters" section to the edit menu of the stair module.
              • Added the ability to create L-Shape, U-Shape and Straight runs of stairs with landings.
              design.medeek.com
              • medeekM
                medeek
                Tutorial 54 - Stairs with Landings (13:27 min.)
                design.medeek.com
                • medeekM
                  medeek
                  With each landing being configurable, its possible to mix and match some of the landings:
                  wall_su814_800.jpg wall_su815_800.jpg wall_su816_800.jpg wall_su817_800.jpg wall_su818_800.jpg wall_su819_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at double landing configurations with 2-step and 3-step L-winders:
                    wall_su820_800.jpg wall_su821_800.jpg wall_su822_800.jpg wall_su823_800.jpg wall_su824_800.jpg wall_su825_800.jpg wall_su826_800.jpg
                    design.medeek.com
                    gullfoG 1 Reply Last reply
                    • gullfoG
                      gullfo @medeek
                      that looks like a lawsuit just waiting to happen lol 🙂
                      Glenn
                      http://www.runnel.com
                      • medeekM
                        medeek
                        Tutorial 55 - Complex Stairs</a> (9:57 min.)
                        design.medeek.com
                        • medeekM
                          medeek
                          Since I've been focusing on updating the stair module the last week I've had quite a number of requests for various things. One request is the ability to flare out the bottom of the stairs. I can add in this functionality however to start with it would be very rudimentary (just a modification to the treads and risers as shown):
                          I'm not entirely sure how one would go about in-fill framing the flared portion, nor do I think there is any established or standard way to do this, I could be wrong. Any thoughts or ideas in this regard? I should probably ask first if this is something that you would all want or even need.
                          design.medeek.com
                          • medeekM
                            medeek
                            First look at an inverted T-Shape staircase with a straight and a curved flare:
                            design.medeek.com
                            • medeekM
                              medeek
                              Here is a quick study of the three types of tread extensions that are probably the most common. I can probably make this happen but it will have a number of new parameters in yet another sub-menu.
                              With the half and full round, the riser simply follows the nosing dimension, however with the square cut extension the amount of the riser extension could be independent.
                              For both the full and half round the radius of the curve is paramount but also the placement of the center of the curve in the Y direction (perpendicular to the stringers). The extension variable can be used for the Y-dir placement of the curve.
                              The round nosing makes things a bit interesting but that can also be dealt with by breaking things down into a piecemeal modeling algorithm and then using some boolean addition of solids.
                              The parameters shall be:
                              Tread Extension Options:
                              Extension Side: Both, Left, Right
                              Extension Type: Square, Round, Half Round
                              Tread Ext. Length: 10" etc... (this variable also sets Y placement of center of curve)
                              Riser Ext. Length: 8" etc... (only applies to the square ext.)
                              Extension Radius: 10" etc... (only applies to full or half round extension)
                              I never get a day of rest, maybe after this update I'll move back to the Floor plugin...
                              design.medeek.com
                              • medeekM
                                medeek
                                If I enable some turn outs and volutes I will need to adjust for these but also I need to provide some additional parameters so one can fine tune the placement of the handrail and its termination:
                                design.medeek.com
                                • medeekM
                                  medeek
                                  So this is currently a specific limitation when it comes to handrails:
                                  The issue here is that each run of stairs literally needs it own handrail sub-menu (set of parameters). Globally the handrail options are fine but as soon as you start adding landings you then have multiple stair runs and it quickly gets complicated. Note that the same handrail settings get applied to each run of stairs currently, this is less than desirable with complex stairs.
                                  Of course the workaround for this is to not rely on the automatic landing functionality and create each separate run of stairs as a separate assembly (linear stair runs only). However this negates the convenience of having the landing and winder options that I recently added.
                                  Yes, I’m a bit in the weeds now but I want this new handrail system to be as functional and fully featured and efficient as possible. I will need to put on my thinking cap and come up with a viable solution that is not too complicated (for a complex problem).
                                  design.medeek.com
                                  • gullfoG
                                    gullfo
                                    one option might be to have the handrails independent of the riser sections. you could create a stair assembly from whatever your stair setup is (like a component with unified stair metadata inside it), then add the handrails over the entire structure - which could be a continuous rail or segmented, etc. might be easier to code it this way by reading the overall stair assembly metadata and use that to generate the handrails.
                                    Glenn
                                    • medeekM
                                      medeek
                                      Version 3.7.9 - 12.26.2024
                                      • Added the inverted T-Shape landing.
                                      • Enabled straight and curved flared staircases.
                                      • Added 37 handrail fittings into the built-in handrail fittings library.
                                      • Updated the handrail module with additional parameters for over-the-post handrail systems.
                                      • Enabled additional handrail sub-menus for multi-landing stair assemblies.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Tutorial 57 - Over-the-Post Handrails and Fittings (18.42 min.)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.8.0 - 12.30.2024
                                          • Enabled open tread staircases.
                                          • Added sub-menus for multiple stair runs for open treads.
                                          • Added the following starter steps: square, full round and half round.
                                          • Added a return parameter for square cut starter steps.
                                          • Enabled flared handrails (over-the-post) for straight and curved flared staircases.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Tutorial 58 - Open Treads and Starter Steps (7:35 min.)
                                            design.medeek.com
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 80
                                            • 81
                                            • 70 / 81
