    Snowman
    18 Posts 6 Posters 520 Views 6 Watching
    • Gus RG Offline
      Gus R
      Sketchup, Blender, D5 Sync to D5 Render. The snow is generated with a free Blender plugin. It's too heavy for Sketchup so I directly import it through Blender to D5. There's a mountain back there but I'm still playing around with D5 2.9's new terrain feature.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      Gus RG 1 Reply Last reply Reply Quote 5
      • Gus RG Offline
        Gus R @Gus R
        @Gus-R Short video.
        • Rich O BrienR Online
          Rich O Brien Moderator @Gus R
          @Gus-R Come on, Halloween hasn't even ended and I'm seeing xmas stuff!
          Gus RG HornOxxH 2 Replies Last reply Reply Quote 0
          • Gus RG Offline
            Gus R @Rich O Brien
            @Rich-O-Brien Stock up for Valentine's Day, Rich.
              Mike Amos @Gus R
              @Gus-R
              Wow, render guru and scary fella all in one. All that talk of Halloween and Valentine's day in one go reminds me of the MIL, the outlaw in chief.
              You do realise the goalposts have now moved into the stratosphere, I take it.........
              • Bryan KB Offline
                Perfect render!
                • Gus RG Offline
                  Gus R
                  Thanks guys!
                  Trying my hand at some icicles generated with Blender.
                  • HornOxxH Offline
                    HornOxx @Rich O Brien
                    @Rich-O-Brien said in Snowman:
                    πŸ˜€ Halloween or not - here in D they start selling christmas biscuits shortly after the summer holidays. So this is a seasonally appropriate job and a so very nice one on top it !!!
                    @ Gus R - interesting how you did it with the snow
                    never trust a skinny cook
                    Gus RG 1 Reply Last reply Reply Quote 2
                    • Gus RG Offline
                      Gus R @HornOxx
                      @HornOxx I have to say I'm really having fun with this. I always wanted to add snow to renderings. D5 has a snow effect but it doesn't pile on like you can using Blender. Here I started using some Blenderkit assets and plugged in a Ford F-150.
                      Here's a close up of the roof area.
                        Mike Amos @Gus R
                        @Gus-R
                        Years ago when I was running a long discontinued render program, I tried snow effect using a duvet for the topography and a 2d snowy tree background. It was OK. This is a few streets ahead mate. The icicles make it standout.
                        • Gus RG Offline
                          Gus R @Mike Amos
                          @Mike-Amos I tried using the Blender snow into Sketchup but there were far to many vertexes to handle. Being able to go straight from Blender into D5 is pretty smooth. Plus I'm slowly learning some Blender procedures which are normally kind of difficult. Especially creating some geometry nodes. I skipped that step with the icicles by finding a icicle addon which is kind of easy. For some people all that might be tedious but I'm used to tedium with my drafting.
                          Blenderkit has a Peterbilt cabover! I keep promising myself to model a Peterbilt conventional.
                          • Gus RG Offline
                            Gus R
                            These are some of the other cars you can get with Blenderkit.
                            marked001M 1 Reply Last reply Reply Quote 0
                            • marked001M Offline
                              marked001 @Gus R
                              @Gus-R The icicles are awesome!
                              http://www.revision21vis.com
                              instagram: revi21on
                                @Gus-R said in Snowman:
                                It's fun to see someone start their Blender journey
                                • Gus RG Offline
                                  Gus R @Rich O Brien
                                  Slowly but it's mostly trying out some mid level procedures and simply navigating within Blender. I have to learn to stop hitting the space bar like I do with SU and it sets off the animator in Blender. I'm trying to find some pre-made geometry nodes because some of them are too complicated. I'm sure I could figure it out but I'm too old for that and it's like calculus class.
                                  I'm sure you're aware of all this with Blender. But for whoever else is reading here's an example of a geometry node to create icicles. Fortunately I was able to get it for $1.20 (it was supposed to be free) and it's pretty easy to insert. This is not the one I used for the rendering above.
                                  • Gus RG Offline
                                    Gus R
                                    Trying out different icicles.
                                    This is using icicles geometry nodes by Ander Goico which I generated with the help of Construction Lines (which is like a CAD addon for Blender) by Don Norris. I added lines alongside the trim, fascia, under gutters, etc and converted those to curves and then added the icicle geometry node to each line. Then I synced it to D5 Render from Blender. The Bronco is another Blenderkit vehicle. These icicles are more random. It's a little tedious but that's a given.
                                    Rich O BrienR 1 Reply Last reply Reply Quote 2
                                      @Gus-R the initial rough start is slowly blossoming into beautiful friendship.
                                      these are great too!
                                      • Gus RG Offline
                                        Gus R @Rich O Brien
                                        @Rich-O-Brien
                                        Rich!
                                        You know what's funny is the brick is a default brick material from SU, I ran it through D5's AI material whiz bang machine.
