    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 29.7k Views 13 Watching
    • F Offline
      function
      bug on console load 2016
      C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
      C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
        How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
        • F Offline
          function
          strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
            What do you mean you use ThomThom's drag and drop?
            I expect you've got the thing installed incorrectly or it would work.
            • F Offline
              function
              thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                • SketcheldarS Offline
                  Sketcheldar
                  Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                    Sketcheldar
                    #Corrected code for plugin to work in SU 2024
                      @@colorx = "Black"
                      @@stipplex = "_"
                      def initialize
                        @endpoints = false
                        @change = false
                        @colorlist = String.new
                        colorlist = Sketchup::Color.names
                        l = colorlist.size
                        l = l - 1
                        for e in 0..l do
                          @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
                          @colorlist = @colorlist + colorlist[e].to_s if e == l
                        cflag = false
                      def activate
                        @model = Sketchup.active_model
                        @ents = @model.active_entities
                        @sel = @model.selection
                        @lines = []
                        show_status
                        conversion
                      def show_status
                        statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
                        statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
                        statusoption = "; Draw end points (Alt)" if @endpoints
                        statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
                        status_label = statustext + statusoption
                        Sketchup.set_status_text(status_label, SB_PROMPT)
                      def conversion
                        @model.start_operation "Line Conversion"
                        view = @model.active_view
                        if !@change
                          for e in @sel
                            if e.class == Sketchup::Edge
                              lstart = e.start.position
                              lend = e.end.position
                              if @endpoints
                                @ents.add_cpoint lstart
                                @ents.add_cpoint lend
                              @ents.add_cline(lstart, lend, @@stipplex)
                              @lines.push(e)
                            elsif e.class == Sketchup::ConstructionLine
                              if e.start && e.end
                                if @endpoints
                                @ents.add_edges(lstart, lend)
                                @ents[-1].material = @@colorx.to_s
                                @ents[-1].find_faces
                                @lines.push(e)
                            end # e.class
                          end # for e
                          if !@lines.empty?
                            @lines.each do |e|
                              e.erase! if e.valid?
                        elsif @change
                          for e in @sel
                              e.stipple = @@stipplex
                              if e.start && e.end
                                if @endpoints
                            elsif e.class == Sketchup::Edge
                              if @endpoints
                              e.material = @@colorx.to_s
                            end # e.class
                            view.invalidate
                          end # for e
                        end # @change
                        @sel.clear
                        @model.commit_operation
                      def self.xLine_validate_selection_edge
                        Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
                        return nil
                      def self.xLine_validate_selection_xline
                        Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
                        return nil
                      def onKeyDown(key, repeat, flags, view)
                        if key == VK_COMMAND  ### Cmd toggles stipples and change
                          @change = !@change
                        if key == VK_ALT ### Alt toggles end points
                          @endpoints = !@endpoints
                        show_status
                      def onLButtonDown(flags, x, y, view)
                        ph = view.pick_helper
                        ph.do_pick(x, y)
                        best = ph.best_picked
                        @sel.add(best) if best
                        conversion
                      def onRButtonDown(flags, x, y, view)
                        cflag = true if @@colorx == "Black"
                        list = ["-|.|-.-|_", @colorlist]
                        prompt = ["XLine Stipple: ", "Color: "]
                        values = [@@stipplex, @@colorx]
                        result = inputbox(prompt, values, list, "Change Parameters")
                        if result
                          @@stipplex = result[0].to_s
                          @@colorx = result[1].to_s
                          if cflag && @model.rendering_options["EdgeColorMode"] != 0
                            choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
                            case choice
                            when 6
                              @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                              cflag = false
                            when 7
                              cflag = false
                          end # if cflag
                        end # if result
                        show_status
                        conversion
                      def deactivate(view)
                        Sketchup.set_status_text("", SB_PROMPT)
                        Sketchup.set_status_text("", SB_VCB_LABEL)
                        Sketchup.set_status_text("", SB_VCB_VALUE)
                    if !file_loaded?("XLinem.rb")
                      UI.add_context_menu_handler do |menu|
                        if XLinemTool.xLine_validate_selection_edge
                          menu.add_separator
                          menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
                        elsif XLinemTool.xLine_validate_selection_xline
                          menu.add_separator
                          menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
                    unless file_loaded?(__FILE__)
                      cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
                      cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
                      cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
                      cmd.tooltip = "Construction Line Conversion"
                      tb = UI.toolbar("Line Conversion") # Fixed string termination
                      tb.add_item(cmd)
                      tb.restore
                    end```
                    TIGT F 2 Replies Last reply Reply Quote 1
                      TIG Moderator @Sketcheldar
                      @Sketcheldar
                      Because you haven't formatted your code properly it's unusable.
                      Use the </> button to add the correct 'Code' formatting...
                      Which is three ` at the start & end of your code, on a separate line.
                      • F Offline
                        FlorinAp @Sketcheldar
                        @Sketcheldar Something is wrong with this code...!!??
                        TIGT 1 Reply Last reply Reply Quote 0
                          TIG Moderator @FlorinAp
                          @FlorinAp
                          That code has never worked.
                          The code as presented applies to a Class [XLinemTool] which should be inside a Module.
                          No Class is defined.
                          There's no RB file to set up the extension as SketchUp loads, and the image PNGs are not in a folder with the main code.
                          There's also three trailing ` characters.
                          If the missing parts were supplied and the whole lot then packaged in an RBZ file, life would be much easier for every one...
                          F 1 Reply Last reply Reply Quote 0
                          • F Offline
                            FlorinAp @TIG
                            @TIG Maybe somebody can do something about it, because right now we have no option to convert construction lines to edges (the reverse it is possible, at least with Curvizard).
                            I know only one option (DBur Guide Tools) but it can do only one line at a time....
                            • 2 / 2
