    How to trim an image
    Scheduled Pinned Locked Moved Solved SketchUp Discussions
    16 Posts 4 Posters 1.5k Views 4 Watching
      pipingguy
      I am trying to do a tile layout. Each tile is a component made from an image and a 5-sided hollow group. Is there a way to trim the tiles? Of course, I would need to first make the tile that needs trimming a unique component.[0_1729164139214_TRYING TO TRIM AN IMAGE.
      skp](Uploading 100%)
      • Rich O BrienR Rich O Brien marked this topic as a question on
        Dave R @pipingguy
        @pipingguy if each is a solid component, draw a cutter shape to the outside perimeter of the tiled area and make it a solid object. Then use Trim from the native Solid Tools, or better, Eneroth Solid Tools or Bool Tools 2 to trim the tiles with the cutter. The latter two respect components.
        You may not need to make each tile unique. If you have a row of tiles that all get cut the same, they can be instance of the same component. Then you only need to trim one. The corners, would be unique.
        The native Solid Tools convert components they modify into groups.
        With Bool Tools2
          pipingguy @Dave R
          @Dave-R
          I assume, by your response, my skp file did not upload into my post? Let me try again. The fact that the tile components contain an imported png image is the source of the problem.TRYING TO TRIM AN IMAGE.skp
          BoxB Dave RD 2 Replies Last reply Reply Quote 0
          • BoxB Offline
            Box @pipingguy
            @pipingguy
            It's a straight line geometric pattern. Far quicker to create the relevant sections and radially array them... than to bother with any image trimming.
              pipingguy @Box
              @Box
              So, I gather that an image is un-trimmable. Is that correct? BTW, the final tile choice ends up being too intricate to replicate with lines and arcs. And even if I did it, it may look like a dark blotch when viewed from a distance due to geometry density on a relatively small 8x8 size.
              BoxB 1 Reply Last reply Reply Quote 0
              • BoxB Offline
                Box @pipingguy
                @pipingguy
                yes there are ways to trim images, Tig's SKM tools for example.
                But the design you show is a simple mirror, radial array of a small number of arcs. Broken down it is very simple to reproduce.
                P 1 Reply Last reply Reply Quote 1
                  Dave R @pipingguy
                  @pipingguy you are correct. Your SketchUp file did not load in your first post.
                  Why are you putting an image in a component? If you must have individual tiles, use the image as a texture instead of an image. Box is correct that you could just create a texture to apply to the floor face.
                  Is there a reason you haven't cropped the image to the limit of the tile? That should be done before adding it into SketchUp.
                  • Rich O BrienR Online
                    Rich O Brien Moderator @Dave R
                    @Dave-R I had nice pyjamas with that pattern. I was in my Napoleon phase at the time.
                    Dave RD 1 Reply Last reply Reply Quote 1
                      Dave R @Rich O Brien
                      @Rich-O-Brien I bet you cut a dashing figure in those pyjamas.
                        pipingguy @Box
                        @Box
                        This will do.......ace of spades tile as a 'non-image'.skp
                          Dave R @pipingguy
                          @pipingguy that seems like an odd way to make your tiles. Is the center area supposed to be missing its faces?
                          Unfortunately your objects aren't solids so you can't use the Solid Tools with them.
                            pipingguy
                            I filled-in the missing face. Is it now considered a solid?
                              Dave R @pipingguy
                              @pipingguy said in How to trim an image:
                              No. You can see that they aren't if you look at Entity Info. Your tile components contain a group of the geometry for the edges and back of the tile. along with a bunch of loose geometry for the front of the tile. Use Outliner to see that.
                              The cut tile is the same way. Explode the groups inside the components and the components will be solids.
                              What is the benefit to bloating your model with all this geometry instead of using the image you have as a texture? As was shown, there's be a whole lot less screwing around trying to get the geometry right if you just use a texture. Even if you create a component of a single tile with the texture ot would be a whole lot less geometry and it would be easier to work with.
                                pipingguy @Dave R
                                @Dave-R
                                Sounds like I need to educate myself on textures.
                                  Rich O Brien Moderator @pipingguy
                                  @pipingguy Here's a cropped and perspective adjusted version of your tile
                                  Here's a 4x4 with each tile randomly rotated 90d to vary the appearance
                                  You can trim in SketchUp using the context menu but you are still carrying the extra file weight of the unused texture space...
                                  Here's a version with dirt, chewing gum and dust in case there's little kiddos running rampant
                                    pipingguy @Rich O Brien
                                    Finished product. The real one, not the computer graphics one. Tips too! Cabinets and walls are white.....not sure why they appear blue.TIPS FOR TILES ON A BACKSPLASH......txt
