    Medeek Floor
    151 Posts 6 Posters 22.9k Views 5 Watching
    • medeekM Offline
      medeek
      First look at skewed hangers with staggered joists:
      A little bit more complicated than regular joists due to the offsets but overall its pretty much the same routine. Pretty excited that I actually can get this to work, at first I wasn't really sure if it was even feasible.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 0.9.9 - 10.01.2024
        • Further updated the insulation, blocking, metal bridging and hanger modules to accommodate staggered joists.
        • Added skewed hanger options into the Floor tab of the Global Settings.
        • Added skewed hangers to the Draw and Edit menus.
        • Added the following skewed (45 degree) Simpson hangers into the built-in library: SUL24, SUL26, SUL210, SUL214, SUL1819, SUL18111, SUL18114, SUL2069, SUL20611, SUL20614, SUR24, SUR26, SUR210, SUR214, SUR1819, SUR18111, SUR18114, SUR2069, SUR20611, SUR20614
        • Updated and added a new subtraction mode to the SUBTRACT feature: SUBTRACT_JOIST
        • Added Subtractive Geometry (Joist) in the General tab of the Global Settings.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 0.9.9b - 10.01.2024
          • Updated the Floor tab of the Global Settings with additional parameters for joist construction.
          • Fixed a minor bug with the hanger module for double ply staggered studs.
          • Fixed a bug in the Draw and Edit menus so that all hangers in the library are properly displayed.
          • Added the following skewed (45 degree) Simpson hangers into the built-in library (skew_hangers): SUL410, SUL414, SUL214_2, SUL210_2, SUL26_2, SUR410, SUR414, SUR214_2, SUR210_2, SUR26_2
          design.medeek.com
          • medeekM Offline
            medeek
            Version 0.9.9c - 10.03.2024
            • Enabled diagonal deck boards with the addition of a Board rotation parameter.
            • Enabled 2-Ply rim joists with our without an air gap.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.9.9d - 10.03.2024
              • Fixed critical bugs with saving of floor presets.
              • Improved robustness of floor attribute library and data lookup methods.
              Some incremental improvements but necessary.
              IMPORTANT
              Note that the last few updates prior to this update introduced a number of new features that effectively disabled the saving of floor presets. Please download this latest update to restore the ability to save floor presets.
              design.medeek.com
              • medeekM Offline
                medeek
                Double rim joists with air gap, lapped and extended:
                A quick test of the non-orthogonal floor types shows that the algorithm holds up as it should:
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 0.9.9e - 10.04.2024
                  • Updated 2-Ply rim joists with air gap to extend joists that are in a lapped configuration.
                  • Updated the Floor tab of the Global Settings with even more parameters for joist construction.
                  • Added the following face mount Simpson hangers into the built-in library: MIU1819, MIU18111, MIU18114, MIU18116, MIU18118.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Tutorial #4: Deck Boards (6:42 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 5 - Rim Joists and Sill Plates (5:47 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Tutorial 6 - Skewed Joist Hangers (5:03 min.)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 7 - Subtractive Geometry (10:57 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 8 - Staggered Joists (5:06 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              One additional parameter for removing specific rim boards:
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I am currently working on the floor covering tool which will then become the code template for the floor opening tool. Once I have those two big items completed I think we will finally have a mostly usable plugin.
                                I am sure there will be requests for additional features and/or changes to the functionality but the core of the plugin will be mostly in place. At that point I will test the plugin in as many states as possible and attempt to discover any final bugs or issues, then within a couple days I will probably release Version 1.0.0.
                                Further integration with the estimating module will also be something on the todo list in the weeks ahead.
                                As always please feel free to chime in with any specific requests or items you feel need to be addressed. I take all feedback and suggestions very seriously and I take everything under consideration. Ultimately I will weigh every idea in the balance and based on its relevancy and time considerations your ideas may quickly become a reality within this plugin or any other plugin in the Medeek family.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Is 8,000 sqft too large? I'm going to say yes, at least for most people.
                                  Besides the regular mdkBIM plugins I also used the grid tool (Medeek Project), but the regular SketchUp grid tool works just as well. A grid tool is a requirement in my opinion, you really need something like this for laying things out correctly.
                                  I also used TIG's mirror tool for certain manual modeling tasks.
                                  The trim and extend tools in the Medeek Project were also very handy for creating my diagonal braces.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    My wife said my design was boring so I saved a new version and let her try to come up with something a little more interesting…
                                    floor_su140_800.jpg floor_su141_800.jpg floor_su142_800.jpg floor_su143_800.jpg
                                    design.medeek.com
                                    Rich O BrienR 1 Reply Last reply Reply Quote 3
                                      Rich O Brien Moderator @medeek
                                      @medeek Its a hotel!
                                      medeekM 1 Reply Last reply Reply Quote 1
                                      • medeekM Offline
                                        medeek @Rich O Brien
                                        @Rich-O-Brien
                                        That's what my daughter said it looks like or a very serious bed and breakfast or even a small ski lodge.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Just a few more screenshots showing how I am stacking posts and beams to ensure a valid load path to the foundation:
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            And a few more cross sectional views and interesting screenshots:
                                            floor_su151_800.jpg floor_su171_800.jpg floor_su172_800.jpg floor_su177_800.jpg
                                            design.medeek.com
                                            • 4 / 8
