    Medeek Floor
    152 Posts 6 Posters 44.9k Views 5 Watching
    • medeekM Offline
      medeek
      The edit menu and draw menu are pretty much done now, just a few more tweaks and error checking and we might be able to start creating our first real floors with this thing:
      https://global.discourse-cdn.com/sketchup/optimized/3X/2/0/20c16d0501736d7be6258e6ce72a539eaf42e7cd_2_228x500.jpeg
      I was going to include the blocking as an advanced option but after some further thought it seemed like it might be more intuitive to have the blocking be similar to beams and openings, where you can really customize the location and size etc... of each row of blocks independently.
      I usually have a pretty good idea how I want things to go even before I start coding but sometimes you get halfway into it and you realize that an alternative method or system would be more optimal.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I realize that people are chomping at the bit for this new plugin and I have been working on it diligently for the last two to three weeks. The biggest holdup has been going back through all of the code and bringing it up to speed with the other plugins. There have been quite a few incremental changes to the other plugins with regards to licensing, materials, layers etc...
        For instance the plugin material library back end was originally coded based off of the 2022 version of the Wall plugin. I just updated all of the code now so that it is keeping in line with the most current version of the Wall plugins material library code base.
        So right now I'm spending a few more days making sure everything is modern and up to speed with the other plugins.
        design.medeek.com
        gullfoG 1 Reply Last reply Reply Quote 1
        • gullfoG Offline
          gullfo @medeek
          Yay! it's finally coming!
          Glenn
          http://www.runnel.com
          • medeekM Offline
            medeek
            I might actually designate the initial release a BETA number but I'm still not decided on that yet.
            Right now the plugin is all torn apart as I continue to add in a few additional features like presets and the "remove joist list" option:
            This is my current desk setup, I've just added the big monitor to my left which gives me more screen real estate and improves my coding efficiency.  This is where all the magic happens, at least for now.
            I also initially used the slab-on-grade code for moving edges of the floor perimeter but now that I'm testing it more extensively it appears that I should probably switch to the code I use for the complex roofs, so some additional adjustments required there as well.
            This is how the sausage is made, one line of code at a time.
            design.medeek.com
            • gullfoG Offline
              gullfo
              what, no physical scale models of a floor joist system as a handy reference? 🙂
              Glenn
              • medeekM Offline
                medeek
                The draw and edit menus are working great (all HTML) but I’ve decided I might as well add in “floor” presets since I know that request will be coming down pike if I don’t add it in initially.
                Also after using the current menus and given all the I-joist options (sizes and manufacturers) it seems almost cryptic in many ways unless you are intimately familiar with the various manufacturer’s product numbers. I’m not saying now but maybe at a later date (after the initial release) I will add in a small SVG graphic into both of these menus which give a simple preview (cross section) with dimensions of the selected I-joist product. It would certainly make the menus a bit more graphical and exciting(engaging) and actually be minimal work to implement, thoughts?
                design.medeek.com
                gullfoG 1 Reply Last reply Reply Quote 0
                • gullfoG Offline
                  gullfo @medeek
                  i might suggest only simple icons - wood, metal, i-joist and glulam representations and textual info - should be sufficient to select the range of product by type and then list the dimensions. chances are someone engineering this structure would have likely researched the products and specs before going though the effort to lay it out...
                  Glenn
                  • medeekM Offline
                    medeek
                    How soon should I release the BETA version? I'm currently checking the floor preset functionality and I will also look at the addition of insulation (bat or fill) tomorrow. The gypsum (ceiling) seems to be working great, but eventually I will add in battens because I know someone will request it, but it is not top priority right now.
                    I'm thinking I will push out the opening and beam modules after I release the BETA, they will complicate things and may take a few weeks of tweaking and testing before they are ready for prime time. The opening module will be the higher priority of the two.
                    I've created the template for the integration with the estimating module, but this will also require further fleshing out. In addition there will need to be updates to the cost database and weight database modules that integrate materials for the floor assemblies.
                    I'm honestly not sure how useful the connection function is as compared to the Truss plugin, but it will be a feature since most of the heavy lifting is already done.
                    The CUSTOM and SUBTRACT feature will be similar to the Truss plugin, it is in place and appears to be working as it should, further testing would be prudent.
                    The I-Joist libraries (sizes and types) is much more organized than the previous system and should be easier to maintain and if required more manufacturers can be easily added. I may also add in a "custom I-Joist" option which would allow one to specify the full set of dimensions for a custom sized I-Joist (depth, flange depth, flange width, web width, web material etc...)
                    Similar to the Truss and Wall plugins, one can specify a comma deliminated remove list to remove specific joists from an assembly.
                    Still lots to do but it is almost close enough to the finish line to think about putting it out there and start garning feedback and suggestions.
                    design.medeek.com
                    • gullfoG Offline
                      gullfo @medeek
                      @medeek maybe keep working on it a couple more weeks and then release the beta. it sounds like you're still in the middle of a couple of things that may hamper a good set of beta testing.
                      Glenn
                      • medeekM Offline
                        medeek
                        Added a “Floors” tab to the global settings, I’m sure this tab will get more populated as development progresses.
                        The tool tip in the draw and edit menu.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Batt and Blown insulation are now enabled:
                          design.medeek.com
                          gullfoG 1 Reply Last reply Reply Quote 2
                          • gullfoG Offline
                            gullfo @medeek
                            @medeek quick note - the ability to renew or purchase the floor plugin is failing with a "gateway or proxy" error:
                            502 - Web server received an invalid response while acting as a gateway or proxy server.
                            Glenn
                            medeekM 1 Reply Last reply Reply Quote 0
                            • medeekM Offline
                              medeek @gullfo
                              @gullfo
                              I will look into it, but you cannot currently purchase the plugin since I have not yet released it to the public.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                In the Materials tab of the Global Settings you can switch between the more realistic textures/materials for lumber and pressure treated lumber:
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  First look at a mitered rim joist:
                                  floor_su013_800.jpg floor_su014_800.jpg floor_su015_800.jpg floor_su016_800.jpg floor_su017_800.jpg floor_su018_800.jpg
                                  I know, no one builds it this way but I’m just covering all my bases.
                                  I just need to test the sill plate algorithm tomorrow morning and I think we are ready for an initial BETA release.
                                  design.medeek.com
                                  • gullfoG Offline
                                    gullfo @medeek
                                    it would be awesome for joist hangers esp on the angled parts. currently i use my own dynamic component to build angled versions of the hangers - not technically detailed but sufficient for parts list and for the contractors to build it... not sure about the mitred rim joist but i think i would likely recommend it for my projects where i only have a very small air gap so the mitred ends would be a neat finish.
                                    Glenn
                                    • medeekM Offline
                                      medeek
                                      A reverse lapped rim joist with a regular lap on the sill plate:
                                      I think I will forego the “solid” option for the rim and sill for now. If requested I will add it in but I don’t consider it a priority right now.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        The Move Floor Edge tool is working as it should:
                                        This tool is very similar to the tool in the complex roof module with some minor adjustments.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 0.9.0 - 09.08.2024
                                          • Created the Medeek Floor Plugin, utilizing SketchUp's Ruby API.
                                          • Added the draw floor tool with the ability to create I-Joist and solid sawn (lumber) polygon shaped floors.
                                          The Floor extension can be downloaded directly here:
                                          404 - File or directory not found.
                                          (design.medeek.com)
                                          Note that this is a BETA release and does not include all of the future planned functionality (ie. openings, beams etc...) I am only posting this release in a few select locations to allow power users to test it out first and help me further debug and refine it. After approximately a week I will send out a notification to all users letting them know that the release is now publicly available. Hopefully in that time I can catch the most glaring bugs and issues so that my inbox does not become swamped.
                                          Also all those who have been issued licenses in the last year or so will have their expiration update date of their license automatically renewed so that it will be active for one year starting from tomorrow's date (09/09/2025).
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            The current todo list in no specific order:
                                            1.) Floor Coverings: Tile, Carpet, Hardwood etc…
                                            2.) Floor Openings: Stairwell and Crawlspace or ladder access
                                            3.) In Floor Beams
                                            4.) Blocking: Mid-span blocking, custom blocking, edge blocking
                                            5.) Ledgers: customize each edge or side of an assembly with a custom ledger or rim joist setting.
                                            6.) Hardware: Joist Hangers, Beam Hangers, diagonal bracing, deck holdowns
                                            7.) Railing: for decks
                                            8.) Custom Joist Doubling: ability to double any number of joists in the array
                                            9.) Custom Joist Offset: ability to offset any number of joists independently.
                                            10) Global Joist Offset
                                            11.) Max. Joist Span Indicator: Engineering related
                                            12.) Diagonal deck boards
                                            13.) MPC Wood Floor Trusses
                                            14.) Steel Trusses (not high priority)
                                            Feel free to help me add to this list.
                                            design.medeek.com
                                            • 2 / 8
