    Medeek Floor
    152 Posts 6 Posters 54.5k Views 5 Watching
    • medeekM
      medeek @gullfo
      @gullfo
      I will look into it, but you cannot currently purchase the plugin since I have not yet released it to the public.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        In the Materials tab of the Global Settings you can switch between the more realistic textures/materials for lumber and pressure treated lumber:
        design.medeek.com
        Reply Quote 2
        • medeekM
          medeek
          First look at a mitered rim joist:
          floor_su013_800.jpg floor_su014_800.jpg floor_su015_800.jpg floor_su016_800.jpg floor_su017_800.jpg floor_su018_800.jpg
          I know, no one builds it this way but I’m just covering all my bases.
          I just need to test the sill plate algorithm tomorrow morning and I think we are ready for an initial BETA release.
          design.medeek.com
          gullfoG 1 Reply Last reply
          • gullfoG
            gullfo @medeek
            it would be awesome for joist hangers esp on the angled parts. currently i use my own dynamic component to build angled versions of the hangers - not technically detailed but sufficient for parts list and for the contractors to build it... not sure about the mitred rim joist but i think i would likely recommend it for my projects where i only have a very small air gap so the mitred ends would be a neat finish.
            Glenn
            http://www.runnel.com
            • medeekM
              medeek
              A reverse lapped rim joist with a regular lap on the sill plate:
              I think I will forego the “solid” option for the rim and sill for now. If requested I will add it in but I don’t consider it a priority right now.
              design.medeek.com
              • medeekM
                medeek
                The Move Floor Edge tool is working as it should:
                This tool is very similar to the tool in the complex roof module with some minor adjustments.
                design.medeek.com
                • medeekM
                  medeek
                  Version 0.9.0 - 09.08.2024
                  • Created the Medeek Floor Plugin, utilizing SketchUp's Ruby API.
                  • Added the draw floor tool with the ability to create I-Joist and solid sawn (lumber) polygon shaped floors.
                  The Floor extension can be downloaded directly here:
                  404 - File or directory not found.
                  (design.medeek.com)
                  Note that this is a BETA release and does not include all of the future planned functionality (ie. openings, beams etc...) I am only posting this release in a few select locations to allow power users to test it out first and help me further debug and refine it. After approximately a week I will send out a notification to all users letting them know that the release is now publicly available. Hopefully in that time I can catch the most glaring bugs and issues so that my inbox does not become swamped.
                  Also all those who have been issued licenses in the last year or so will have their expiration update date of their license automatically renewed so that it will be active for one year starting from tomorrow's date (09/09/2025).
                  design.medeek.com
                  • medeekM
                    medeek
                    The current todo list in no specific order:
                    1.) Floor Coverings: Tile, Carpet, Hardwood etc…
                    2.) Floor Openings: Stairwell and Crawlspace or ladder access
                    3.) In Floor Beams
                    4.) Blocking: Mid-span blocking, custom blocking, edge blocking
                    5.) Ledgers: customize each edge or side of an assembly with a custom ledger or rim joist setting.
                    6.) Hardware: Joist Hangers, Beam Hangers, diagonal bracing, deck holdowns
                    7.) Railing: for decks
                    8.) Custom Joist Doubling: ability to double any number of joists in the array
                    9.) Custom Joist Offset: ability to offset any number of joists independently.
                    10) Global Joist Offset
                    11.) Max. Joist Span Indicator: Engineering related
                    12.) Diagonal deck boards
                    13.) MPC Wood Floor Trusses
                    14.) Steel Trusses (not high priority)
                    Feel free to help me add to this list.
                    design.medeek.com
                    • gullfoG
                      gullfo @medeek
                      stair openings 🙂 basically the x-y position and the length + width of the opening. doubling of the header joists and across (trimmers) as options. possibly right angle openings as well?
                      Glenn
                      • medeekM
                        medeek
                        Version 0.9.1 - 09.10.2024
                        • Enabled doubling of individual joists.
                        • Enabled offsetting of individual joists.
                        • Enabled global offsetting of joists.
                        • Added a duplicate floor check to the regen module for all floor types.
                        • Updated the javascript logic within the License tab of the Global Settings.
                        design.medeek.com
                        • medeekM
                          medeek
                          Tutorial 1 - Extension Overview (19:43 min.)
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 0.9.2 - 09.11.2024
                            • Enabled a overhang for deck boards.
                            • Enabled a global offset for deck boards.
                            • Fixed a bug with floor presets.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 0.9.3 - 09.12.2024
                              • Fixed a critical bug in the Draw Floor menu.
                              • Added a status icon (Draw Mode: Polyline or Face) in upper right corner of the Draw Floor menu.
                              • Added the Draw Mode parameter to Floors tab of the Global Settings.
                              design.medeek.com
                              • medeekM
                                medeek
                                I was thinking about hanger hardware for the joists but then I realized that things are quite a bit more complicated with these polygon floors. For example look at this floor:
                                The situation gets interesting for the first six joists in the array, they would require four hangers each rather than just the normal two. I'm going to have to really put on my thinking cap for this one.
                                And then you have the additional complication of non-orthogonal edges which may require special skewed hangers... Fortunately those are probably not as common so I can probably ignore that case for now.
                                P.S.
                                At first glance I think I can examine each joist individually once they've been trimmed/cut and count the number of edges that run parallel to the joist (x-axis or y-axis). For a regular lumber joist the total number of pieces will be the number of horizontal (long edges) divided by four. That will tell me how many hangers I actually need.
                                I can then cycle through this collection of edges finding all of the terminal vertices/locations and assign to each one a direction (left facing or right facing). From there it is simply a matter of running a for loop and placing the hangers. I think this will work but it may not be optimized yet.
                                P.P.S
                                I also just realized that there is the possibility for some joists to be doubled, which will naturally require a different hanger, so the hanger selection will require two parameters, one for single ply an one for two ply. However, there may be a situation where you want there to be hangers only on one side of the floor (ie. a deck with a ledger and beam supported on the other end) so four parameters for hanger selection:
                                1.) Start Hanger (1X Ply)
                                2.) Start Hanger (2X Ply)
                                3.) End Hanger (1X Ply)
                                4.) End Hanger (2X Ply)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 0.9.3b - 09.12.2024
                                  • Fixed a HTML/Javascript bug in the Draw Floor menu.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 0.9.4 - 09.16.2024
                                    • Added joist hangers to the Draw and Edit menus.
                                    • Added a built-in library of face mount and and top flange hangers.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 2 - Joist Hangers (19:57 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 0.9.5 - 09.18.2024
                                        • Added a joist direction arrow to the draw floor tool.
                                        • Added a "debug mode" parameter to the General tab of the Global Settings.
                                        • Fixed a bug with deck board placement.
                                        • Fixed a bug with the deck board offset parameter.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I have had two requests now for metal bridging or bracing so I took about an hour and modeled up a Simpson TB27 between 2X10 joists @ 16" on center. It actually looks really nice:
                                          However some things immediately jumped out at me:
                                          1.) I based my TB27 off of the ICF file on Simpson's website so it is dimensionally accurate, however to do that takes quite a bit of time. Modeling like this is fun but very time consuming and one thing I never have enough of is time.
                                          2.) This is the TB27 configured for 2X10's on 16" centers, now think of all the other permutations (including I-Joists). To make this look right would require a preconfigured component for each case. The number of permutations is at least 130 or more.
                                          3.) If you also consider custom offsets of specific joists then it gets even more crazy.
                                          My thinking is that if I do want to enable something like this it will need to be less detailed geometrically (just a basic representation) and drawn on the fly using an algorithm that checks joist depth and spacing. Rather than specify the exact part number (ie. TB20, TB27, TB30 etc...), just specify that it is metal bridging.
                                          design.medeek.com
                                          • gullfoG
                                            gullfo @medeek
                                            agreed - i'd say less detail on the components to improve speed and rendering, and just good descriptive text / names instead. one option might be in a "library" view showing a detailed version of a single component so selection purposes, but the generated structure uses the simpliest possible geometry.
                                            Glenn
                                            • 2 / 8
