    Medeek Floor
    151 Posts 6 Posters 20.3k Views 5 Watching
    • medeekM Offline
      medeek
      Added a “Floors” tab to the global settings, I’m sure this tab will get more populated as development progresses.
      The tool tip in the draw and edit menu.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Batt and Blown insulation are now enabled:
        design.medeek.com
        gullfoG 1 Reply Last reply Reply Quote 2
        • gullfoG Offline
          gullfo @medeek
          @medeek quick note - the ability to renew or purchase the floor plugin is failing with a "gateway or proxy" error:
          502 - Web server received an invalid response while acting as a gateway or proxy server.
          Glenn
          http://www.runnel.com
          medeekM 1 Reply Last reply Reply Quote 0
          • medeekM Offline
            medeek @gullfo
            @gullfo
            I will look into it, but you cannot currently purchase the plugin since I have not yet released it to the public.
            design.medeek.com
            • medeekM Offline
              medeek
              In the Materials tab of the Global Settings you can switch between the more realistic textures/materials for lumber and pressure treated lumber:
              design.medeek.com
              • medeekM Offline
                medeek
                First look at a mitered rim joist:
                floor_su013_800.jpg floor_su014_800.jpg floor_su015_800.jpg floor_su016_800.jpg floor_su017_800.jpg floor_su018_800.jpg
                I know, no one builds it this way but I’m just covering all my bases.
                I just need to test the sill plate algorithm tomorrow morning and I think we are ready for an initial BETA release.
                design.medeek.com
                gullfoG 1 Reply Last reply Reply Quote 1
                • gullfoG Offline
                  gullfo @medeek
                  it would be awesome for joist hangers esp on the angled parts. currently i use my own dynamic component to build angled versions of the hangers - not technically detailed but sufficient for parts list and for the contractors to build it... not sure about the mitred rim joist but i think i would likely recommend it for my projects where i only have a very small air gap so the mitred ends would be a neat finish.
                  Glenn
                  • medeekM Offline
                    medeek
                    A reverse lapped rim joist with a regular lap on the sill plate:
                    I think I will forego the “solid” option for the rim and sill for now. If requested I will add it in but I don’t consider it a priority right now.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      The Move Floor Edge tool is working as it should:
                      This tool is very similar to the tool in the complex roof module with some minor adjustments.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 0.9.0 - 09.08.2024
                        • Created the Medeek Floor Plugin, utilizing SketchUp's Ruby API.
                        • Added the draw floor tool with the ability to create I-Joist and solid sawn (lumber) polygon shaped floors.
                        The Floor extension can be downloaded directly here:
                        http://design.medeek.com/calculator/sketchup/medeek_floor_ext.rbz
                        Note that this is a BETA release and does not include all of the future planned functionality (ie. openings, beams etc...) I am only posting this release in a few select locations to allow power users to test it out first and help me further debug and refine it. After approximately a week I will send out a notification to all users letting them know that the release is now publicly available. Hopefully in that time I can catch the most glaring bugs and issues so that my inbox does not become swamped.
                        Also all those who have been issued licenses in the last year or so will have their expiration update date of their license automatically renewed so that it will be active for one year starting from tomorrow's date (09/09/2025).
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          The current todo list in no specific order:
                          1.) Floor Coverings: Tile, Carpet, Hardwood etc…
                          2.) Floor Openings: Stairwell and Crawlspace or ladder access
                          3.) In Floor Beams
                          4.) Blocking: Mid-span blocking, custom blocking, edge blocking
                          5.) Ledgers: customize each edge or side of an assembly with a custom ledger or rim joist setting.
                          6.) Hardware: Joist Hangers, Beam Hangers, diagonal bracing, deck holdowns
                          7.) Railing: for decks
                          8.) Custom Joist Doubling: ability to double any number of joists in the array
                          9.) Custom Joist Offset: ability to offset any number of joists independently.
                          10) Global Joist Offset
                          11.) Max. Joist Span Indicator: Engineering related
                          12.) Diagonal deck boards
                          13.) MPC Wood Floor Trusses
                          14.) Steel Trusses (not high priority)
                          Feel free to help me add to this list.
                          design.medeek.com
                          • gullfoG Offline
                            gullfo @medeek
                            stair openings 🙂 basically the x-y position and the length + width of the opening. doubling of the header joists and across (trimmers) as options. possibly right angle openings as well?
                            Glenn
                            • medeekM Offline
                              medeek
                              Version 0.9.1 - 09.10.2024
                              • Enabled doubling of individual joists.
                              • Enabled offsetting of individual joists.
                              • Enabled global offsetting of joists.
                              • Added a duplicate floor check to the regen module for all floor types.
                              • Updated the javascript logic within the License tab of the Global Settings.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 1 - Extension Overview (19:43 min.)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 0.9.2 - 09.11.2024
                                  • Enabled a overhang for deck boards.
                                  • Enabled a global offset for deck boards.
                                  • Fixed a bug with floor presets.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 0.9.3 - 09.12.2024
                                    • Fixed a critical bug in the Draw Floor menu.
                                    • Added a status icon (Draw Mode: Polyline or Face) in upper right corner of the Draw Floor menu.
                                    • Added the Draw Mode parameter to Floors tab of the Global Settings.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      I was thinking about hanger hardware for the joists but then I realized that things are quite a bit more complicated with these polygon floors. For example look at this floor:
                                      The situation gets interesting for the first six joists in the array, they would require four hangers each rather than just the normal two. I'm going to have to really put on my thinking cap for this one.
                                      And then you have the additional complication of non-orthogonal edges which may require special skewed hangers... Fortunately those are probably not as common so I can probably ignore that case for now.
                                      P.S.
                                      At first glance I think I can examine each joist individually once they've been trimmed/cut and count the number of edges that run parallel to the joist (x-axis or y-axis). For a regular lumber joist the total number of pieces will be the number of horizontal (long edges) divided by four. That will tell me how many hangers I actually need.
                                      I can then cycle through this collection of edges finding all of the terminal vertices/locations and assign to each one a direction (left facing or right facing). From there it is simply a matter of running a for loop and placing the hangers. I think this will work but it may not be optimized yet.
                                      P.P.S
                                      I also just realized that there is the possibility for some joists to be doubled, which will naturally require a different hanger, so the hanger selection will require two parameters, one for single ply an one for two ply. However, there may be a situation where you want there to be hangers only on one side of the floor (ie. a deck with a ledger and beam supported on the other end) so four parameters for hanger selection:
                                      1.) Start Hanger (1X Ply)
                                      2.) Start Hanger (2X Ply)
                                      3.) End Hanger (1X Ply)
                                      4.) End Hanger (2X Ply)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.9.3b - 09.12.2024
                                        • Fixed a HTML/Javascript bug in the Draw Floor menu.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 0.9.4 - 09.16.2024
                                          • Added joist hangers to the Draw and Edit menus.
                                          • Added a built-in library of face mount and and top flange hangers.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 2 - Joist Hangers (19:57 min.)
                                            design.medeek.com
                                            • 2 / 8
