    AI-Created Extension for SketchUp – Issues with CTRL Modifier Functionality
    4 Posts 3 Posters 785 Views 3 Watching
    • robertWanR Offline
      robertWan
      Hi everyone,
      I’m having trouble with a custom SketchUp tool that was created by AI. The tool correctly highlights a selected plane and applies materials to it when clicked. Additionally, this code works for closed groups and components. However, the CTRL modifier functionality is not working as expected. Here’s a summary of the issues I’m facing:
      Plane Highlighting: The tool highlights the plane correctly when hovered over and works on closed groups and components.
      Material Application: Materials are correctly applied to the selected plane or to closed groups and components when clicked.
      CTRL Modifier: The CTRL key should trigger the application of the material to the entire object (group or component) rather than just the selected plane. This should work for both closed groups and components, but this functionality is not working.
      Here is the relevant code:
      module CustomSelectionTool
        class SelectPlaneTool
          def initialize
            @ip = Sketchup::InputPoint.new
            @view = Sketchup.active_model.active_view
            @last_face = nil
            @model = Sketchup.active_model
            @selection = @model.selection
            @materials = @model.materials
          def onMouseMove(flags, x, y, view)
            @ip.pick(view, x, y)
            face = @ip.face
            if face && face.is_a?(Sketchup::Face)
              if face != @last_face
                # Clear previous selection
                @selection.clear
                # Select the new face
                @selection.add(face)
                @last_face = face
                view.invalidate
            else
              if @last_face
                # Clear selection when there is no face
                @selection.clear
                @last_face = nil
                view.invalidate
            view.tooltip = @last_face ? "Face selected" : "No face selected"
          def onLButtonDown(flags, x, y, view)
            if @last_face
              if (flags & MK_CONTROL) == MK_CONTROL
                # Apply material to the entire object (group or component)
                apply_material_to_object(@last_face.parent)
              else
                # Apply material to the selected face
                apply_material(@last_face)
              @last_face = nil
              view.invalidate
          def apply_material(face)
            material = @model.materials.current
            if material
              face.material = material
            else
              puts "No material to apply"
          def apply_material_to_object(entity)
            if material
              if entity.is_a?(Sketchup::Group) || entity.is_a?(Sketchup::ComponentInstance)
                entity.entities.grep(Sketchup::Face).each { |f| f.material = material }
              elsif entity.is_a?(Sketchup::Face)
                entity.material = material
              else
                puts "Cannot apply material to this type of object"
            else
        def self.activate_select_plane_tool
          Sketchup.active_model.select_tool(SelectPlaneTool.new)
      if !file_loaded?(__FILE__)
        UI.menu('Plugins').add_item('Select Plane Tool') {
          CustomSelectionTool.activate_select_plane_tool
        file_loaded(__FILE__)
      What I’ve Tried:
      Using Sketchup::InputModifier::CTRL to check if the CTRL key is pressed.
      Ensuring the current material is selected before applying it.
      Any suggestions or insights on why the CTRL key functionality is not applying the material to the entire object (including closed groups and components) as intended would be greatly appreciated. Thank you!
      The code is written in Ruby 1.8, which is compatible with SketchUp 8.
      Robert
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @robertWan
        Class: Sketchup::Tool
        Tool is the interface that you implement to create a SketchUp tool.
        SketchUp Ruby API Documentation (ruby.sketchup.com)
        The arguments passed to the button press method are wrong, they start with key and you test if CTRL was pressed using the right VK_ constant. Also the if test needs rewriting to suit. I'm not near a computer to do more till next week...
        • Dan RathbunD Offline
          Dan Rathbun
          @robertWan said in AI-Created Extension for SketchUp – Issues with CTRL Modifier Functionality:
          Where did you get Sketchup::InputModifier::CTRL from? This is NOT a constant defined by SketchUp's Ruby API. Nor is there an InputModifier submodule. Be careful as the AIs have been known to just "invent" coding objects or functions to satisfy themselves in providing "solutions" (which are not guaranteed to work.)
          FYI, the toplevel constants defined by SketchUp's Ruby API are listed at: Top Level Namespace
          In the tool's onLButtonDown callback method, I think you should be using COPY_MODIFIER_KEY or COPY_MODIFIER_MASK instead of MK_CONTROL to test the flags passed in by the SketchUp engine. See the Sketchup::Tool abstract class overview.
          Also, your extension submodule should be wrapped within a unique top-level namespace module. Ie:
          module RobertWan # top-level namespace
            module CustomSelectionTool # extension submodule
                # ... the tool code ...
            end # extension submodule
          end # top-level namespace
          I'm not here much anymore.
            Dan Rathbun
            If it does not work using onLButtonDown then try renaming the callback to onLButtonUp. I recall back in the v8 days there were some quirks with one or the other callback method (I think on Mac platform mostly.)
            • Rich O BrienR Rich O Brien moved this topic from Extensions & Applications Discussions on
