    Rayscaper bugsplat.
    7 Posts 3 Posters 474 Views 3 Watching
      Rendering another scene, tried to change light value and bugsplat/Crash #190663.
      • pixelcruncherP
        pixelcruncher Extension Creator @Mike Amos
        @Mike-Amos
        Thanks for reporting!
        Unfortunately, the bug splat number is a SketchUp thing; AFAIK, plugin developers cannot access that mechanism to get diagnostics about their plugins.
        • Is the crash reproducible? By changing a light value, do you mean changing a value in the Rayscaper lights tab?
        • Which version of Rayscaper are you currently running?
        • If this would happen again, do you mind sending me the log file SUEX_Rayscaper.log?
        Rayscaper creates a log file in the application data directory named SUEX_Rayscaper.log. For example C:\Users\Thomas\AppData\Roaming\Rayscaper. To find the application directory, you can use explorer on Window, and type %AppData% in the address bar. Make sure to send us this log file.
        I received a similar report from Rich that he ran into a crash while changing light values, so I'm keeping an eye on this.
        Thanks,
        Thomas
        Mike AmosM 1 Reply Last reply
          Mike Amos @pixelcruncher
          @pixelcruncher
          It only happened the once, not reproducable I'm afraid.
          • pixelcruncherP
            @Mike-Amos Thanks for reporting back, will keep an eye out an continue to fix bugs. Eventually those crashes surface, and we’ll fix them.
              @pixelcruncher
              I have to say that there were lots of textures that did nothing, attached nowhere and were just bloating the file. A possible cause.
              I have cleaned the model several times and will report back when it is retextured and re rendered to see if anything changes.
              • KrassK
                Krass
                Hello, I'm testing rayscaper and I'm very interested in your program, but as soon as I click on “settings” sketchup 2022 crashes. Thanks for your advice
                Krass
                • pixelcruncherP
                  @Krass Thanks for your interest. Which settings menu are you referring to? The one in Rayscaper.
