    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Tutorial 48 - Elevation Swing Lines (8:31 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.6.4 - 06.08.2024
        • Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
        • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
        • Allowed the use of a period "." in custom beam hanger library names.
        http://design.medeek.com/resources/wallplugin/images7/wall_su776_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.6.5 - 06.12.2024
          • Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
          design.medeek.com
          medeekM 1 Reply Last reply Reply Quote 1
          • medeekM Offline
            medeek @medeek
            Tutorial 49 - Component Libraries (13:05 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.6.6 - 06.24.2024
              • Added hardware (caps and bases) options to the post module.
              • Updated the material/color parameter for (exterior) wall trim to include custom materials.
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 50 - Post Hardware (8:45 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.6.6b - 06.24.2024 thru 06.25.2024
                  • Fixed a minor bug with the post cap positioning algorithm.
                  • Added the following Simpson post cap: APL6
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.6.7 - 06.27.2024
                    • Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
                    • Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
                    404 - File or directory not found.
                    (design.medeek.com)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.6.8 - 06.28.2024
                      • Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
                      • Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.6.9 - 07.23.2024
                        • Enabled "Remove Cladding Lines" for 3D cladding materials.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.7.0 - 07.25.2024
                          • Added a duplicate wall check to the regen module for all wall types.
                          Tutorial 51 - Duplicating Walls (6:15 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.7.1 - 09.17.2024
                            • Added a vertical offset parameter for in-wall column king studs.
                            In the case where you have a beam pocket and king studs over top of a door or window this update is critical. Previously the king studs would simply project to the bottom plate in the wall passing through the opening. Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset. Note that the offset can be both positive or negative or zero (default)
                            design.medeek.com
                            gullfoG 1 Reply Last reply Reply Quote 1
                            • gullfoG Offline
                              gullfo @medeek
                              honestly though, if i was putting in a beam support over the opening, i've have either an additional jack stud under the header/lintel, or a X x X sized column on either side, and likely as well as a glulam etc type header/lintel. unless the beam was only supporting some deadweight and not a live area above. just me probably...
                              Glenn
                              http://www.runnel.com
                              • medeekM Offline
                                medeek
                                I wasn't paying attention to a realistic header with trimmers, just focusing on the king stud offset, I agree, a few things would need to be beefed up to handle this type of beam configuration. I've only actually engineered one job with this type of beam over window(s).
                                design.medeek.com
                                • gullfoG Offline
                                  gullfo @medeek
                                  i don't have to do it often but a couple of recent projects have beams over doors to address the extended span of a room with the door the best option - in those cases we used steel i-beams as posts and header as well as the new beam in order to get the load supported needed with lower profile than wood products. so it's rarely needed but a useful option when you can get around to it. maybe even just leaving the space so manually someone could insert the members / assemblies would work.
                                  Glenn
                                  medeekM 1 Reply Last reply Reply Quote 0
                                  • medeekM Offline
                                    medeek @gullfo
                                    @gullfo
                                    Post a screenshot or send me some via email (nathan@medeek.com) so I can get a better idea what this looks like. I will give it some consideration.
                                    design.medeek.com
                                    gullfoG 1 Reply Last reply Reply Quote 0
                                    • gullfoG Offline
                                      gullfo @medeek
                                      @medeek I'm away until Thurs I'll send some then
                                      Glenn
                                      • medeekM Offline
                                        medeek
                                        design.medeek.com
                                        • gullfoG Offline
                                          gullfo
                                          wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
                                          Glenn
                                          • medeekM Offline
                                            medeek
                                            Very interesting. Let me see what I can do.
                                            design.medeek.com
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 75
                                            • 76
                                            • 48 / 76
