    Fredo6 Joint Push Pull Error
    fredojointpushpullfredo6
    2 Posts 2 Posters 412 Views 2 Watching
    • H
      hmurphy Newcomers
      Hi, I've paid for a licence but the tool is simply not showing up... I've dowloaded the latest plugins, & when I use the 'ExtensionStore' from SketchUcation, it says it's installed the plugins but nothing shows up. I manually downloaded & installed them. Help!
      TIGT 1 Reply Last reply
        TIG Moderator @hmurphy
        @hmurphy
        Have you restarted SketchUp after the extension / lib were installed ?
        That should sync everything.
        The toolbar & menu items should show up then.
        Fredo's extensions are listed under a submenu in the Tools menu... did you look there after a restart ?
        Simply paying for a license doesn't license the extension. You need to activate it in the appropriate submenu under Tools...
        If you have tried all of this without success, then please comeback for further help...
