    Rayscaper Sample Model Download
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    rayscaper
    22 Posts 4 Posters 2.7k Views 4 Watching
      Rich O Brien Moderator @ntxdave
      @ntxdave
      Try this one but it is in your own interest to troubleshoot so you can get a firm grasp of the software.
      ROBR_rs_shader_ball-scene.skp
      As I mentioned, older files were tailored to earlier builds. Expect unwanted results. Rayscaper is not a finished product.
      ntxdaveN 1 Reply Last reply
      • ntxdaveN
        ntxdave @Rich O Brien
        @Rich-O-Brien Thanks Rich. This file worked MUCH better. It is not exactly like the one in the in the video but it is close enough that I can now get the hang of things.
        I will now have to try some stuff with one of my own models.
        I appreciate your feedback/support so I can begin to try Rayscaper and hopefully start moving forward.
        Press F1...thank me later
        • pixelcruncherP
          pixelcruncher Extension Creator @ntxdave
          @Rich-O-Brien Thanks for fixing.
          Recently, the range of exposure values changed, bringing this scene to an exposure of -10, rendering everything dark. Setting it to zero would have fixed this.
          Like Rich said, it's still beta software, so there might be quirks.
          • ntxdaveN
            ntxdave @pixelcruncher
            @pixelcruncher Well, after playing around and trying a lot of settings, here is my first render. The metal frame is not quite as shinny as I would like it but, again, this is my first render. Also, the background is darker that I would like.
            • ntxdaveN
              ntxdave @ntxdave
              @ntxdave OK, now I have a silly question. Is there a way to save the settings I used in the above render?
              • pixelcruncherP
                Hey @ntxdave ,
                It's great to see you are already getting results with Rayscaper!
                As a first check, make sure you are using the global illumination render method. It's slower than approximate GI, but approximate GI is not photorealistic and doesn't render materials correctly, always favoring speed.
                What material are you using for the metal surfaces? The metal material or the Disney material? The roughness slider allows you to control the shininess of either material. The below renders show a chrome ball with three different roughness settings (0, 0.20, and 0.50).
                You can control that via the environment settings. Either adjust the color (or use an image) or adjust the power.
                You can also drag & drop one of the HDRIs to get more realistic lighting:
                Does that help?
                Cheers,
                Thomas
                • ntxdaveN
                  @pixelcruncher Thank you sir. I will give these a try. πŸ‘
                  This is all part of the learning process. πŸ™‚
                  • ntxdaveN
                    ntxdave
                    Well, progress, I think. But still a LOT to learn about how to use the tool.
                    Oh No, the background in the render is not what I was seeing during the render.
                    BTW: Here is the settings I used for the frame which is still not exactly as shinny as I was wanting.
                    • pixelcruncherP
                      @ntxdave said in Rayscaper Sample Model Download:
                      Can you clarify shininess πŸ™‚ From looking at the gray frame, it seems like a perfect mirror.
                      • ntxdaveN
                        @pixelcruncher OK, I just did some more "playing around" and here is the result.
                        Final result: Blower-Dryer-Mammoth_Rayscaper-V2.png
                        And here are the settings I used to get here: Blower-Dryer-Mammoth_Rayscaper-Settings-V2.png
                        Still a long way to go to get comfortable with Rayscaper but progress is one step at a time.
                        • ntxdaveN
                          ntxdave @ntxdave
                          OK still a little more progress.
                          Noticed a problem in the model so fixed it and re-rendered.
                          Then I played with another setting and like this one a little more.
                          I am going to start another thread about Rayscaper Learning-Practice as I continue to learn how to render with Rayscaper and also a place to ask questions.
                          • 2 / 2
