    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 97.2k Views 30 Watching
    • TutorialsUpT Offline
      TutorialsUp
      @anton_s said:
      @tutorialsup said:
      Hi, Anton
      Thanks for updating this plugin.
      can we adjust zoom in/out speed like the layout?
      I'm using mouse 4th and 5th buttons as a scroll to zoom in and out in SketchUp but using with buttons zoom in/out speed is very fast and windows scroll speed settings are not applied in SketchUp viewport.
      it would be great if I can decrease speed with your Plugins. I want very slow
      Hey. How do you zoom in/out with 4th and 5th buttons? What are these buttons you are referring to? For me, I can only zoom with the mouse wheel.
      Anton thank you so much for your response, Actually, with the help of X-Mouse Button Control software or Logitech software, I can use these buttons as a wheel up and down. Right now it's helping but speed is a bit fast. and there is no any way to control the speed.
      Thanks again
      imgur.com
      Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
      Imgur (imgur.com)
        Anton_S
        Thanks again
        I tried out the X-Mouse Button Control tool. At the moment the only way you can decrease the zoom speed is by decreasing the Duration to 50ms. See attached image. Go to (Extebsion)>SmoothZoom>Options
        The downside of changing the Duration to 50ms is that the normal mouse wheel will no longer be as smooth.
          AISmebel
          Hello. I've been using this plugin for several years now and really like it. I use version 1.3. For me, it is more convenient and I don’t want to switch to an earlier version, it doesn’t suit me.
          Version 1.3 has difficulty compatability with FredoSketch. When holding down the Ctrl button (in FredoSketch), it is not possible to make a soft selection ((
          Is it difficult for you to tweak version 1.3 for me to work well with FredoSketch?
          Thank you very much.
            rv1974
            The problem with smooth zoom is its uniformity. For example, if I'm located 900m from the building I'm modeling duration 400 is perfect - one hair scroll and I'm in the right place. But if I need to zoom in in finer manner to refine the handle on the entrance door duration 400 is too addressee, 100 is better value. Maybe scrolling with some modifier key (if it'd exist) would help?
              rv1974
              Anton, with the latest version I have model jumping like rabbit while scrolling for zoom in. It happens on the 2nd (left) monitor, the situation on the main one (right) is better. 😕
                lans1972
                Hi Anton!
                In older versions, the flight stopped when the wheel was pressed. Now there is no stopping. I've been using this for a few years now and I'm very used to it. At settings around 600ms, this gave precise and smooth control. 😢
                  kurdoc69
                  HELLO FRIENDS, THIS PLUGINS IS CURRENTLY GIVING ERROR IN SKETCHUP 2024, IT IS A VERY IMPORTANT PLUGINS FOR SOME OF US, DO YOU THINK YOU CAN SOLVE IT? 🤞
                    armerial
                    Error message when installing on sketchup 2024 version. Does anyone have a solution?
                    • E Offline
                      Eric5261
                      I am getting an error mesage when I install the extensions and open a project.Extension Errors Report
                      SketchUp: 24.0.553
                      OS: Windows 11
                      Ruby: 3.2.2
                      Extension: SoothZoom (2.1.1a)
                      Error: NoMethodError (undefined method `exists?' for File:Class)
                      It gives this error on both the library and the extension. Does anyone have a solution?
                      TIGT 1 Reply Last reply Reply Quote 0
                        TIG Moderator @Eric5261
                        @Eric5261
                        File.exists? AND File.exist? methods have worked forever. although the File.exists? method has been deprecated for along time, but someone decided to remove it completely from the Ruby version used by v2024.
                        This has caused a lot of problems with code - I myself have had several files to fix for full compatibility.
                        To an English speaker File.exists? is the more logical grammatically correct form, so why it changed is somewhat mysterious.
                        It's a simple matter for the author to edit the files so only File.exist? is used...
                        If the file is RB you could edit it to suit, but I'm sure that Anton will fix it asap...
                          armerial
                          I'm still waiting for this awesomeness for the 2024 version
                          • F Offline
                            FlorinAp
                            Guys, this tool is exceptional, yet (instead of complaining about it), you should give yourself the chance to try at least for 3 weeks a Space Mouse (or 3D Mouse) from 3D Connexion.
                            No opinion from YouTube (or from yourself) doesn't weigh as much as 3 weeks of day-to-day use of this device - 3 weeks is the minimum your brain needs to understand and use this device, and after that, you will ask yourself how could you ever work without it, and you will never work without it (i have 3 of them).
                            This device is priceless.!
                              melindasaur
                              Getting an error as well:
                              SketchUp: 24.0.594
                              OS: Windows 10
                              Ruby: 3.2.2
                              Error: NoMethodError (undefined method exists?' for File:Class) C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:65:in block in require_all'
                              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:63:in each' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:63:in require_all'
                              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main.rb:95:in <top (required)>' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in require'
                              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require'
                              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:42:in register_extension'
                              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:42:in <module:SmoothZoom>' C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:10:in module:AMS'
                              C:/Users/clayt/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_SmoothZoom.rb:9:in `<top (required)>'
                                Anton is aware of this errors. Expect a fix asap
                                  Until there's a fix available, because the error is in a RB file you can edit it with a plain-text editor like Notepad++.exe
                                  Find where it says File.exists? and change it to File.exist?
                                  Both method coexisted for ever and were equivalent to each other, but in >=v2024 someone chose to deprecate the original correct-English sounding version, and cause authors issues.
                                  After you save that edit restart SketchUp to see if that fixed it...
                                    kurdoc69 @Anton_S
                                    @Anton_S HELLO FRIEND, CAN YOU MAKE IT WORK ON VERSION 2025 ? IT IS MY ESSENTIAL COMPONENT ! THANK Y👏 OU
                                      TIG Moderator @kurdoc69
                                      @kurdoc69
                                      Read my reply above yours, it outlines how to do a manual fix on the RB file, until the author responds.
                                      K 1 Reply Last reply Reply Quote 0
                                        kurdoc69 @TIG
                                        @TIG i downloaded notepad++ but my file is rbz, when i open it i can't understand the language to edit, sorry i don't understand about this.
                                          You need to install it into v2025 from the RBZ - with errors.
                                          Then close SketchUp and find the RB file in your Plugins folder, open it it with Notepad++.exe and do the edit as outlined above...
                                          The installed file is C:/Users/YOURUSERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb
                                            kurdoc69 @TIG
                                            @TIG I changed 3 places where it said File.exists? and then I get this new error
                                            Informe de errores de extensión
                                            SketchUp: 25.0.571
                                            OS: Windows 11
                                            Ruby: 3.2.2
                                            Extensión: SoothZoom (2.1.1a)
                                            Error: IOError (Stage directory, "C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/libraries/stage/win64/3.2", is missing!)
                                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:76:in require_all' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main.rb:95:in <top (required)>'
                                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in require' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in <top (required)>'
                                            C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in load'
                                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in register_extension' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in module:SmoothZoom'
                                            C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:10:in <module:AMS>' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:9:in <top (required)>'
                                            • 4 / 4
