    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.2k Views 84 Watching
    • V
      valerostudio
      I think I also noticing that if I enable a plugin through the SketchUcation manager, close SketchUp and restart, SketchUp will hard crash the first time it starts up and loads that plugin. If I start SketchUp again, no problems and the plugin loads.
        Rich O Brien Moderator @valerostudio
        @valerostudio said in [Plugin] SketchUcation Tools:
        The more scenarios where it fails that are reported the better. Then we can try reproduce it our end.
        We have 4.4.1 build where the disabling seems to be correct now. But I'll try these steps you've shared to see if it is resolved fully.
          TIG Moderator @valerostudio
          @valerostudio
          Fixed the loading issue in v2024.
          Now testing before reissuing...
          V 1 Reply Last reply
          • V
            valerostudio @TIG
            @TIG I'm happy to test it as well if needed. Thanks TIG
            • V
              valerostudio
              New update is great. Thanks TIG
              • B
                B2Pi @TIG
                @TIG @Rich-O-Brien
                Any chance you're actually using edg3d.io ? That is blocked for me, and it would give me a place to start...
                Cheers
                  Rich O Brien Moderator @B2Pi
                  @B2Pi said in [Plugin] SketchUcation Tools:
                  ....it would give me a place to start...
                  To start what? That has no relation to Sketchucation Tools
                  B 1 Reply Last reply
                  • B
                    B2Pi @Rich O Brien
                    @Rich-O-Brien said in [Plugin] SketchUcation Tools:
                    To start figuring out why I can't get sketchucation tools to work.
                    To refresh your memory, @TIG had suggested ensuring that two URL's and two IP addresses were unblocked. They are unblocked, but an additional URL associated with those IP addresses is blocked (I've no idea why).
                    TIGT 1 Reply Last reply
                      TIG Moderator @B2Pi
                      @B2Pi
                      If you gave us details of the blocked URL / IP it'd help...
                      I assume it's some old edg3d.io IP URL ??
                      • G
                        Gábor
                        @B2Pi
                        As far as I know, SketchUcation Tools does not require access to edg3d.io .
                        Currently there are 2 IP addresses which are used by different parts of the Tools: 144.76.69.227 and 178.63.47.155
                        Plus some functions (image, javascript, css, and .rbz file downloads) are using the Amazon AWS CloudFront CDN. The CDN URLs are:
                        https://pluginstatic.sketchucation.com
                        http://pluginstatic.sketchucation.com
                        https://pluginrepo.sketchucation.com
                        http://pluginrepo.sketchucation.com
                        If the access to https://pluginrepo.sketchucation.com/ and it's sub folders is blocked, it might cause the error message you mentioned.
                        Let us know if unblocking these URLs helped or not.
                        • V
                          valerostudio
                          I seem to still get some startup hard crashes when I have re-enabled a plugin and I restart SketchUp. Could be V-Ray and or Artisan?
                          F 1 Reply Last reply
                          • F
                            FlawinneF @valerostudio
                            @valerostudio
                            Hello,
                            I have "V-Ray 6.20.03" and "artisan 2 (2.1.2)" neither of these extensions cause crashes for me.
                            • 16
                            • 17
                            • 18
                            • 19
                            • 20
                            • 20 / 20
