    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 179.8k Views 84 Watching
    • V Offline
      valerostudio
      New update is great. Thanks TIG
        B2Pi @TIG
        @TIG @Rich-O-Brien
        Any chance you're actually using edg3d.io ? That is blocked for me, and it would give me a place to start...
        Cheers
          Rich O Brien Moderator @B2Pi
          @B2Pi said in [Plugin] SketchUcation Tools:
          ....it would give me a place to start...
          To start what? That has no relation to Sketchucation Tools
          B 1 Reply Last reply Reply Quote 0
            B2Pi @Rich O Brien
            @Rich-O-Brien said in [Plugin] SketchUcation Tools:
            To start figuring out why I can't get sketchucation tools to work.
            To refresh your memory, @TIG had suggested ensuring that two URL's and two IP addresses were unblocked. They are unblocked, but an additional URL associated with those IP addresses is blocked (I've no idea why).
            TIGT 1 Reply Last reply Reply Quote 0
            • TIGT Online
              TIG Moderator @B2Pi
              @B2Pi
              If you gave us details of the blocked URL / IP it'd help...
              I assume it's some old edg3d.io IP URL ??
                Gábor
                @B2Pi
                As far as I know, SketchUcation Tools does not require access to edg3d.io .
                Currently there are 2 IP addresses which are used by different parts of the Tools: 144.76.69.227 and 178.63.47.155
                Plus some functions (image, javascript, css, and .rbz file downloads) are using the Amazon AWS CloudFront CDN. The CDN URLs are:
                https://pluginstatic.sketchucation.com
                http://pluginstatic.sketchucation.com
                https://pluginrepo.sketchucation.com
                http://pluginrepo.sketchucation.com
                If the access to https://pluginrepo.sketchucation.com/ and it's sub folders is blocked, it might cause the error message you mentioned.
                Let us know if unblocking these URLs helped or not.
                • V Offline
                  valerostudio
                  I seem to still get some startup hard crashes when I have re-enabled a plugin and I restart SketchUp. Could be V-Ray and or Artisan?
                  F 1 Reply Last reply Reply Quote 0
                  • F Offline
                    FlawinneF @valerostudio
                    @valerostudio
                    Hello,
                    I have "V-Ray 6.20.03" and "artisan 2 (2.1.2)" neither of these extensions cause crashes for me.
                    • 16
                    • 17
                    • 18
                    • 19
                    • 20
                    • 20 / 20
