[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
@fredo6 said:
@cmeed said:
I don't think there will be a solution for the future, as there is no longer any API to access menus and screen visual elements.
This is indeed sad news! LOTB has speeded up my work. Its quick, easy and (was) very adapatble. I am still a keen fan and will be a tester if ever you need help with further developments.
Cheers for all your hard work
Chris -
Chrismy 2 cents: Just make ONE large vertical (say 6X30) palette, add separators\line breaks where needed - so everything is in one place perfectly organized on the 2nd monitor. No need in extra menus or palettes (maybe except history). the rest is shortcuts and tool search
@panixia said:
@cmeed said:
my personal buttons I've created, have stopped working
I posted a workaround a few pages before
https://sketchucation.com/forums/viewtopic.php?f=323&t=73776&start=270#p687744
Hi. Personally, I still haven't figured out how to use your method ((( Will you have the opportunity to write instructions in more detail for noobs
Thanks for the 2cents. Sounds great - Not sure if it helps me with the buttons I’d created for plugins that don’t have buttons. But I do take you’re point about short cuts. I have so many though it’s hard to keep them in my head, especially the ‘used occasionally’ variety. Also I am running out of suitable key combinations ! Ha ha. I tend to keep everything on the left hand side of the keyboard for speed and one hand.
@cmeed
My 2c are related to your disappeared menus, custom icons are aside -
NEW RELEASE: LordOfTheToolbars v2.7a - 02 Apr 24
Requirements
- LibFredo6: v14.3b or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.7a is a maintenance release for:
- Future compatibility
Home Page of LordOfTheToolbars for information and Download.
NEW RELEASE: LordOfTheToolbars v2.7b - 07 Apr 24
Requirements
LordOfTheToolbars 2.7b is a maintenance release for:
- SU2024
- Fix for shortcuts
- Visual adjustment for palettes
@fredo6 Hello dear Fredo. I would like to ask you if you can expect to repair the "menu" tab in new versions of SU in your future updates?
Hello dear fredo, I am a heavy user of Lott. I upgraded from su2021 to 2024 and noticed some issues. When I right-click on an icon, only the system native icon like 1 will pop up a menu, while most icons like 2 will not pop up a menu. Is this my problem or is it a bug? I hope to receive your help. Thank you
No scroll bars?
can't get to the button at bottom of windows ?
With the 2024 version, I am trying to configure new palettes, how ever the ability to add line breaks, separators etc is missing from the right-click menu.
Do you see the commands if you right-click ON an icon?
@fredo6 If I right-click on an icon there are no commands shown. This is using Win 10 (if that makes a difference).
It seems that the problem might be related to the Text Scaling factor in Windows, as per this post on the Sketchup Forum.
@fredo6 My latest LOTT (win11, SU24) lost right click (on icons) menu shown by
17628046164 6 posts above. Might it be fixed please?
