    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    147 Posts 40 Posters 162.9k Views 40 Watching
      rv1974
      they published a new build - Swap Curves and Sandbox's Drape (not yours, I know) still don't work in context.
      Will have to skip this version too 😄
        JHJ001
        hello. I'm a Korean user who uses Fredo's products usefully.
        A little while ago, I purchased a license for 'fredo spline' and pressed the 'Download' button,
        but the result is a white screen with only the text below.
        /pluginrepo/rbz/
        /var/www/html/pluginrepo/rbz/FredoSpline.rbz
        File does not exist. Make sure you specified correct file name.
        If anybody know a solution, please send 'e-mail' to help. Thank you.
        email address ▶jhjncorp@naver.com
        • H Offline
          HaroenMartens
          Question
          I paid for a license, however my plugin keeps telling me it doesnt work due to the fact that i have not the latest version of it. I keep on installing v 2.5 over and over but it keeps sending me the same message. It used to work perfectly in an older version. I cannot seem to fix the issue.
          Any thoughts or people experiencing the same issue?
            Do you have the current version of LibFredo6 installed? Also the current version of the Sketchucation ExtensionStore? Both of those are required. Share a screen shot of the error message you're getting.
            Are you still using SketchUp 2015 Pro as indicated in your forum profile?
              rv1974
              Fredo, is it possible to implement a general weight setting in "convert curves" and "edit curves" commands please?
              I get used to create all sorts of fredo curves out of faces or chains of straight edges and really miss this general setting. It also counter-effective to change the weight one-by-one in edit
              • fredo6F Offline
                I get used to create all sorts of splines out of faces of chains of straight edges and really miss this general option. It also counter-effective to change the weight one-by-one in edit
                I think you can select several control points and chenge the weight in one action.
                  rv1974
                  Thats news to me. so how do I change the weight globally?
                    rv1974
                    Also, in case of polycorner arc editing.. I really miss ability to choose (with crossing window and\or by single picks) several vertices and change their radius at once. So again mass editing is really welcomed.
                      rv1974
                      my humble request: window selection - most obvious and basic functionality. currently the process of vertex selection is not bearable.
                      Yet another idea: in edit, ability to assign different types of vertices in given spline(s) : arc, bezier, simple corner.
                      • fredo6F Offline
                        NEW RELEASE: FredoSpline v2.6a - 01 Apr 24
                        Requirements
                        • LibFredo6: v14.3b
                        • Sketchucation PluginStore: v4.4.0
                        FredoSpline 2.6a is a maintenance release for:
                        • Future compatibility
                        Home Page of FredoSpline for information and Download.
                        Main post of this FredoSpline thread.
                        • zivotinjaZ Offline
                          zivotinja
                          I own a bundle bu I do not have bezier curves. HOw can I add this plugin to the bundle?
                          Thank you
                          Best,
                          Nenad
                            rv1974
                            Maybe I missed it, but Its surprising nobody reports this faulty behavior
                            When changing radius with mouse wheel at some stage the plugin jumps to radius 0 and its impossible to change it anymore:
                            Also, any editing (adding, deleting, moving) in majority of situations would delete existing faces:
                            How about editing multiple curve at once:
                            P.S. Fredo, It was requested in the past and its not implemented, but hope dies last: Is it possible to preserve plane constrains after editing is finished please? Thanks
                            fredo6F 1 Reply Last reply Reply Quote 0
                            • fredo6F Offline
                              fredo6 @rv1974
                              @rv1974
                              For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner. This allows to only round long edges when you do it globally.
                              Deletion of faces happens when you change the number of vertices. It is somehow difficult to maintain the face.
                              It seems to me that if you created the curve with a specified plane, the edition of vertices will be along the plane.
                              R 1 Reply Last reply Reply Quote 0
                                rv1974 @fredo6
                                This post is deleted!
                                  rv1974
                                  @fredo6
                                  For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
                                  OK, but it should not break scrolling.
                                  In many situations a banal vertex moving deletes face as well .
                                  Unfortunately - no , it can easily run away from the plane. Also, if there are objects not laying on this plane - SU easily snaps to them.
                                  is it possible to implement scrolling\nudging based on exact user defined values ?
                                  currently there are no exact values on radius\tension changing. This feature would be extremely useful in other plugins where scrolling\nudging being used - PaintThru, Axiz etc.
                                  Thank you for attention
                                    rv1974
                                      rv1974
                                      @fredo6 Any chance to make inference work while moving vertices please?
                                      P.S. >>>For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
                                      Why such a strong limitation exists? Say I have L shape 200/100cm.. why the plugin can't create 99 cm fillet?
                                        dascaualex
                                        Hello,
                                        I have problem with this plugin and with Fredo plugins in general recently. The licenses appear to be invalid. I bought the license for this plugin today and I it is not working even tho when i activate it everything seems to be ok, validity is there, but once i close the window and try to use the plugin it says that the trial has expired and I get a small notification from skp saying that license is invalid. I have this problem with all fredo plugins both on older skp and 2024.
                                          Rich O Brien Moderator @dascaualex
                                          @dascaualex said in [Plugin][$] FredoSpline - v2.6a - 01 Apr 24:
                                          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                          D 1 Reply Last reply Reply Quote 0
                                            dascaualex @Rich O Brien
                                            @Rich-O-Brien
                                            Fredo6 Plugins Information on 2024-11-15 09:18:09 +0200
                                            • Sketchup: 24.0.484
                                            • LibFredo6: v14.6a
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.1
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              FredoSpline v2.6a
                                              JointPushPull v4.8a
                                              Signature File: 2022-09-14 17:22:45 +0300
                                              ClothWorks: 2022-09-14 18:13:22 +0300
                                              RoundCorner: 2022-12-06 15:51:28 +0200
                                            • 7 / 8
