    [code] extract png thumbnail image from .skp file
    19 Posts 9 Posters 6.6k Views 9 Watching
      driven
      hi Jim
      to clarify, I'm trying to run it in 'Ruby Console' using the embedded ruby 2...
      and it also fails using Jeff's Terminal.app cmd, but mac also uses ruby 2...
        slbaumgartner
        @driven said:
        hi Jim
        John, try putting the magic comment at the head of jim's file:
        coding:ascii-8bit
        At least that worked for me from a Terminal window. And the png I got was much nicer than the ones I remember from SU 8 when I last tried this...
        Steve
          driven
          @steve
          that stopped the errors, but still not working here...
          send me your copy...
            slbaumgartner
            @driven said:
            @steve
            sent via PM
              driven
              cheers Steve that works if I cd into the folder then run...
              it returns the exact same png as Sketchup.save_thumbnail [if that's set for png]...
              pixel dimensions vary wildly from skp to skp...
              you can influence the size by re-saving the skp in v2015, but the logic is a little obscure...
              one that was 400x183, I re-saved now comes in at 256x256 but that seems to be the limit...
              it also cropped the image, so needs zoom extents in a square viewport to see all...
              the upshot is I can use it for a quick'n'dirty batch mode icon generator, but they're not as good as doing them individually using my add icon plugin...1 = resized + batch icon; 2 = as extracted + batch icon; 3 = using add_icon.rb
                jkoll66
                I know this post is like a thousand years old, but I was using the "extract_png.rb" from "Jim". It doesn't seem to work in SU2023. I need this to compile a catalogue of all of my components. Is there an updated version out there somewhere? I really need this. Thanks in advance!
                • ntxdaveN
                  ntxdave
                  Can’t you just export the file as a png?
                  Press F1...thank me later
                    The long existing method is
                    https://ruby.sketchup.com/Sketchup.html#save_thumbnail-class_method
                    • ntxdaveN
                      ntxdave
                      Ooops, I thought they wanted to create a set of png images of their components.
                      • Dan RathbunD
                        Dan Rathbun
                        If you are doing this from within SketchUp, try something like:
                        # SketchUp 2015 or later.
                        def export_thumbnails(source_path = nil, dest_path = nil)
                          unless source_path && File.directory?(source_path)
                            models = Sketchup.active_model.path
                            if models.empty?
                              models = File.join(ENV['HOME'], 'Documents')
                            source_path = UI.select_directory(
                              title; "Select Model Directory",
                              directory; models
                            return unless source_path
                          unless dest_path && File.directory?(dest_path)
                            images = Sketchup.active_model.path
                            images = source_path if images.empty?
                            dest_path = UI.select_directory(
                              title; "Select Image Output Directory",
                              directory; images
                            return unless dest_path
                          Dir.glob( '*.skp', base; source_path ) do |skp|
                            source_file = File.join(source_path, skp)
                            image_file  = skp.split('.')[0] << '.png'
                            output_file = File.join( dest_path, image_file )
                            Sketchup.save_thumbnail(source_file, output_file)
                          end # Dir loop
                        end ###
                        I'm not here much anymore.
