    [code] extract png thumbnail image from .skp file
    19 Posts 9 Posters 6.9k Views 9 Watching
      Jim
      This bit of Ruby code extracts the png image from a .skp file and writes it to disk using the same basename as the model file.
      extract_png.rb
      • tbdT
        tbd
        yup, i did something similar in 2005, a viewer for .skp thumbnail inside Total Commander - see my blog post (no source though yet)
        http://plugins.ro
        • Dan RathbunD
          Dan Rathbun
          _
          The following code does the same thing BUT must be run from within Sketchup Ruby.
          ( Jim's code can run in standard Ruby, and does not need Sketchup running.)
          folder = Dir.getwd
          # browse for another folder here (opt.)
          # see TIG's "import_from_folder" script
          Dir.foreach( folder ) do |fn|
            skp = File.join(folder,fn)
            img = ''
            # first 2 entries are dirs '.' and '..'
            if File.ftype( skp )=='file'
              if fn.downcase.include?('.skp')
                # it's a Sketchup model
                img = fn.split('.')[0]+'.png'
                img = File.join( folder, img )
                Sketchup.save_thumbnail(skp,img)
              end # if it's a SKP
            end # if 'file' type
          end # Dir loop
          EDIT-06JAN2010: added downcase to filename .skp test
          FYI: There are three (3) save_thumbnail methods
          Sketchup.save_thumbnail which can work on files, other than the one that's loaded.
          Model.save_thumbnail which only works for the current model, but has a bug, in that if the model has never been saved, it writes a blank thumbnail image to the %UserProfile% folder instead of the Model folder specified in Preferences>Files>Model folderpath.
          [BUG - as of SU ver 7.1.6087]
          ComponentDefinition.save_thumbnail
          There is also View.write_image which can write a thumbnail of the current view that CAN be different than the thumbnail that was saved within the file.
          _
          I'm not here much anymore.
          • N
            nuagevert
            i would like to know how to extract with better resolution than a thumbail or how t oextract texture from skp files
            thanks a lot ?
            regards
            Gabriel
              slbaumgartner
              @nuagevert said:
              thanks a lot ?
              regards
              Gabriel
              SketchUp automatically generates a thumbnail image and saves it inside the skp file. That is what Jim's code extracts. You have no control over the size or quality of this image. In my experience, for a complex model it is almost useless. There just aren't enough pixels in it to avoid total blur of the contents.
              To get an image in which you control the size and quality, you must use one of the techniques Dan describes. As he notes, these are Ruby code that runs within SketchUp - though I suppose you could write code using the C API that would do it.
              Steve
              • Dan RathbunD
                Dan Rathbun
                @Gabriel... do you REALLY use pre-v6 SketchUp ? Did you download it off the web somewhere ?
                Please go to SketchUp.com and download the latest free version. There are very many bugs in those old version, they should be outlawed! 😄
                • N
                  nuagevert
                  thanks you a lot
                  i hadnt understand at the begininng it was extraction of thumbail
                  so i understand know why their were so little .
                  so i will try download for more recent sketchup version and i will try to find the way to find a ruby code or try to done if is not so complicated
                  i will try to extract texture of scene and atribute the name of skp object , cause it was that s i exactly want to do
                  thanks again and have nice year !
                  Gabriel
                    driven
                    hi all
                    anyone tried Jim's script using ruby 2 in SU...
                    I get encoding errors on my mac...
                    Error: invalid Unicode escape: /\xFF\xFE\xFF\x0ES\x00k\x00e\x00t\x00c\x00h\x00U\x00p\x00 \x00M\x00o\x00d\x00e\x00l\x00\xFF\xFE\xFF
                    If I can get it to run, I can pipe the output and attach it to the skp files resource fork ...
                    I think it would be faster then using Sketchup.save_thumbnail(skp,img) for the same purpose...
                    I want to compare them...
                      Jim
                      Not sure - it still works fine for me.
                        driven
                        hi Jim
                        to clarify, I'm trying to run it in 'Ruby Console' using the embedded ruby 2...
                        and it also fails using Jeff's Terminal.app cmd, but mac also uses ruby 2...
                          slbaumgartner
                          @driven said:
                          hi Jim
                          John, try putting the magic comment at the head of jim's file:
                          coding:ascii-8bit
                          At least that worked for me from a Terminal window. And the png I got was much nicer than the ones I remember from SU 8 when I last tried this...
                          Steve
                            driven
                            @steve
                            that stopped the errors, but still not working here...
                            send me your copy...
                              slbaumgartner
                              @driven said:
                              @steve
                              sent via PM
                                driven
                                cheers Steve that works if I cd into the folder then run...
                                it returns the exact same png as Sketchup.save_thumbnail [if that's set for png]...
                                pixel dimensions vary wildly from skp to skp...
                                you can influence the size by re-saving the skp in v2015, but the logic is a little obscure...
                                one that was 400x183, I re-saved now comes in at 256x256 but that seems to be the limit...
                                it also cropped the image, so needs zoom extents in a square viewport to see all...
                                the upshot is I can use it for a quick'n'dirty batch mode icon generator, but they're not as good as doing them individually using my add icon plugin...1 = resized + batch icon; 2 = as extracted + batch icon; 3 = using add_icon.rb
                                  jkoll66
                                  I know this post is like a thousand years old, but I was using the "extract_png.rb" from "Jim". It doesn't seem to work in SU2023. I need this to compile a catalogue of all of my components. Is there an updated version out there somewhere? I really need this. Thanks in advance!
                                  • ntxdaveN
                                    ntxdave
                                    Can’t you just export the file as a png?
                                    Press F1...thank me later
                                      The long existing method is
                                      https://ruby.sketchup.com/Sketchup.html#save_thumbnail-class_method
                                      • ntxdaveN
                                        ntxdave
                                        Ooops, I thought they wanted to create a set of png images of their components.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          If you are doing this from within SketchUp, try something like:
                                          # SketchUp 2015 or later.
                                          def export_thumbnails(source_path = nil, dest_path = nil)
                                            unless source_path && File.directory?(source_path)
                                              models = Sketchup.active_model.path
                                              if models.empty?
                                                models = File.join(ENV['HOME'], 'Documents')
                                              source_path = UI.select_directory(
                                                title; "Select Model Directory",
                                                directory; models
                                              return unless source_path
                                            unless dest_path && File.directory?(dest_path)
                                              images = Sketchup.active_model.path
                                              images = source_path if images.empty?
                                              dest_path = UI.select_directory(
                                                title; "Select Image Output Directory",
                                                directory; images
                                              return unless dest_path
                                            Dir.glob( '*.skp', base; source_path ) do |skp|
                                              source_file = File.join(source_path, skp)
                                              image_file  = skp.split('.')[0] << '.png'
                                              output_file = File.join( dest_path, image_file )
                                              Sketchup.save_thumbnail(source_file, output_file)
                                            end # Dir loop
                                          end ###
