    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.4.3 - 01.18.2024
      • Improved the serial number verification logic within the License tab of the Global Settings.
      • Added a Door Reset button in the Doors tab of the Global Settings.
      • Added a Window Reset button in the Windows tab of the Global Settings.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.4.4 - 01.24.2024
        • Added a pressure treated option for in-wall columns.
        • Created a more realistic material/texture for pressure treated timbers (for in-wall columns and posts).
        http://design.medeek.com/resources/wallplugin/images6/wall_su727_800.jpg
        design.medeek.com
        • gullfoG Offline
          gullfo
          one thing i recently ran into was needed a steel column to support a steel beam spanning a couple of walls to get the proper support for ceiling joists. it would be a nice option (not necessarily to provide a steel column in leiu of a wood one πŸ˜„ ) but just to leave the space for easily adding one separately (and thus avoiding closing it etc when regenerating due to a wall change).
          cheers!
          Glenn
          http://www.runnel.com
          • medeekM Offline
            medeek
            I could provide another option in the Advanced Options section which essentially removes the column and leaves a blank opening in wall. Is this what you are suggesting?
            design.medeek.com
            • gullfoG Offline
              gullfo
              yes, or even just have a column type of "blank" (or simply marker) in the selection list (along with x dia round steel, x by x wood, etc) πŸ˜„ this way the code is effectively the same, just whether or not the spacing has anything other than say a 2D marker of the column location.
              Glenn
              • medeekM Offline
                medeek
                Version 3.4.5 - 01.28.2024
                • Added two additional column types for in-wall columns: Custom, Blank.
                • Three additional parameters added for custom in-wall columns.
                • Added a custom label option and annotation section for in-wall columns.
                • Updated the javascript logic within the License tab of the Global Settings.
                http://design.medeek.com/resources/wallplugin/images6/wall_su728_800.jpg
                Technically this update is a bit redundant because one can already configure custom in-wall columns within the global settings. However, this new option gives one the ability to insert any sort of column into the wall (non-wood) as well as a blank opening where one could then insert their own manually modeled column or structural support.
                The custom label option applies to all column types, so it can override the auto labeling algorithm of the module.
                This update per customer request.
                design.medeek.com
                • gullfoG Offline
                  gullfo
                  thanks! this will be handy as i design a lot of studio where the isolation structure has to be separated from the exterior and custom columns and sizing it for that critical 2" separation, using i-beams and glulams, when using autogenerated walls etc will make this much easier to draw and document πŸ˜„
                  Glenn
                  • medeekM Offline
                    medeek
                    Version 3.4.5b - 01.28.2024
                    • Fixed a bug with holdowns for in-wall columns.
                    • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.4.6 - 01.30.2024
                      • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
                      • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
                      • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
                      • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
                      http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
                      http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
                      http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
                      All updates per customer requests.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.4.7 - 02.01.2024
                        • Updated the Columns tab of the Global Settings with new parameters.
                        • Added glazing color and opacity parameters to the Sheathing tab of the Global Settings.
                        http://design.medeek.com/resources/wallplugin/images6/wall_su732_800.jpg
                        http://design.medeek.com/resources/wallplugin/images6/wall_su733_800.jpg
                        The Columns tab now includes Custom and Blank under Column Type.
                        Up until now the glass color and opacity has been hard coded in to the plugin, now the user can adjust these values if desired.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.4.8 - 02.04.2024
                          • Added a Sheathing Reset button in the Sheathing tab of the Global Settings.
                          • Added Dimension Layer 5 specfically for framing/elevation auto-dimensions (Layer tab of the global settings).
                          • Enabled editing of dimensions for framing/elevation dimensions (rectangular walls only).
                          http://design.medeek.com/resources/wallplugin/images6/wall_su734_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su735_800.jpg
                          Tutorial 46 - Editing Framing Dimensions (7:34 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.4.9 - 02.16.2024
                            • Added an RGB color code input into the Add, Update and Import menus for custom materials.
                            • Added an RGB color code input for each color in the Materials tab of the Global Settings.
                            • Added a "Toggle RGB Input" button to the Materials tab of the Global Settings.
                            http://design.medeek.com/resources/wallplugin/images6/wall_su736_800.jpg
                            http://design.medeek.com/resources/wallplugin/images6/wall_su737_800.jpg
                            Updates per customer request.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.5.0 - 02.23.2024
                              • Separated the tee blocking option for exterior and interior walls.
                              • Fixed a bug with geometry guides for metric templates.
                              http://design.medeek.com/resources/wallplugin/images6/wall_su738_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.5.1 - 02.24.2024
                                • Added a 45 and 135 degree rainscreen option for rectangular walls.
                                http://design.medeek.com/resources/wallplugin/images6/wall_su739_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.5.2 - 03.02.2024
                                  • Added the following door types: 3/4 glass, double 3/4 glass.
                                  • Added a separate threshold material option for all man doors.
                                  • Added additional grille (grid) options for glass doors.
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.5.3 - 03.06.2024
                                    • Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
                                    • Fixed a javascript bug for window and door presets.
                                    • Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
                                    • Rearranged the door casing section of the door Draw and Edit menus.
                                    • Fixed a bug with the advanced options for all wall types when using metric templates.
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su744_800.jpg
                                    With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself. I highly recommend upgrading to this latest release of the plugin.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.5.4 - 03.08.2024
                                      • Enabled an end grain material for top and bottom plates of rectangular walls.
                                      • Fixed a javascript bug for garage door presets.
                                      • Fixed a bug with door presets when using metric templates.
                                      http://design.medeek.com/resources/wallplugin/images6/wall_su745_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.5.4b - 03.09.2024
                                        • Enabled a pressure treated end grain material for bottom plates of all walls.
                                        • Enabled end grain materials for in-wall columns.
                                        • Enabled end grain materials for beams.
                                        • Enabled end grain materials for blocks.
                                        • Enabled end grain materials for posts.
                                        http://design.medeek.com/resources/wallplugin/images6/wall_su749_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images6/wall_su746_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images6/wall_su747_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images6/wall_su748_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.5.5 - 03.11.2024
                                          • Added a "Custom Glass" garage door type/option with fully customizable glass panels.
                                          • Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
                                          http://design.medeek.com/resources/wallplugin/images6/wall_su750_800.jpg
                                          I will need to create a tutorial video explaining the proper syntax for the "Glass List".
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Medeek Wall Plugin Tutorial 47 - Custom Glass Garage Doors (w/ Webcam)
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 75
                                            • 76
                                            • 20 / 76
