    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • gullfoG
      gullfo
      yes, or even just have a column type of "blank" (or simply marker) in the selection list (along with x dia round steel, x by x wood, etc) πŸ˜„ this way the code is effectively the same, just whether or not the spacing has anything other than say a 2D marker of the column location.
      Glenn
      http://www.runnel.com
      • medeekM
        medeek
        Version 3.4.5 - 01.28.2024
        • Added two additional column types for in-wall columns: Custom, Blank.
        • Three additional parameters added for custom in-wall columns.
        • Added a custom label option and annotation section for in-wall columns.
        • Updated the javascript logic within the License tab of the Global Settings.
        http://design.medeek.com/resources/wallplugin/images6/wall_su728_800.jpg
        Technically this update is a bit redundant because one can already configure custom in-wall columns within the global settings. However, this new option gives one the ability to insert any sort of column into the wall (non-wood) as well as a blank opening where one could then insert their own manually modeled column or structural support.
        The custom label option applies to all column types, so it can override the auto labeling algorithm of the module.
        This update per customer request.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • gullfoG
          gullfo
          thanks! this will be handy as i design a lot of studio where the isolation structure has to be separated from the exterior and custom columns and sizing it for that critical 2" separation, using i-beams and glulams, when using autogenerated walls etc will make this much easier to draw and document πŸ˜„
          Glenn
          • medeekM
            medeek
            Version 3.4.5b - 01.28.2024
            • Fixed a bug with holdowns for in-wall columns.
            • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
            design.medeek.com
            • medeekM
              medeek
              Version 3.4.6 - 01.30.2024
              • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
              • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
              • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
              • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
              http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
              http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
              http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
              All updates per customer requests.
              design.medeek.com
              • medeekM
                medeek
                Version 3.4.7 - 02.01.2024
                • Updated the Columns tab of the Global Settings with new parameters.
                • Added glazing color and opacity parameters to the Sheathing tab of the Global Settings.
                http://design.medeek.com/resources/wallplugin/images6/wall_su732_800.jpg
                http://design.medeek.com/resources/wallplugin/images6/wall_su733_800.jpg
                The Columns tab now includes Custom and Blank under Column Type.
                Up until now the glass color and opacity has been hard coded in to the plugin, now the user can adjust these values if desired.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.4.8 - 02.04.2024
                  • Added a Sheathing Reset button in the Sheathing tab of the Global Settings.
                  • Added Dimension Layer 5 specfically for framing/elevation auto-dimensions (Layer tab of the global settings).
                  • Enabled editing of dimensions for framing/elevation dimensions (rectangular walls only).
                  http://design.medeek.com/resources/wallplugin/images6/wall_su734_800.jpg
                  http://design.medeek.com/resources/wallplugin/images6/wall_su735_800.jpg
                  Tutorial 46 - Editing Framing Dimensions (7:34 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.4.9 - 02.16.2024
                    • Added an RGB color code input into the Add, Update and Import menus for custom materials.
                    • Added an RGB color code input for each color in the Materials tab of the Global Settings.
                    • Added a "Toggle RGB Input" button to the Materials tab of the Global Settings.
                    http://design.medeek.com/resources/wallplugin/images6/wall_su736_800.jpg
                    http://design.medeek.com/resources/wallplugin/images6/wall_su737_800.jpg
                    Updates per customer request.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.5.0 - 02.23.2024
                      • Separated the tee blocking option for exterior and interior walls.
                      • Fixed a bug with geometry guides for metric templates.
                      http://design.medeek.com/resources/wallplugin/images6/wall_su738_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.5.1 - 02.24.2024
                        • Added a 45 and 135 degree rainscreen option for rectangular walls.
                        http://design.medeek.com/resources/wallplugin/images6/wall_su739_800.jpg
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.5.2 - 03.02.2024
                          • Added the following door types: 3/4 glass, double 3/4 glass.
                          • Added a separate threshold material option for all man doors.
                          • Added additional grille (grid) options for glass doors.
                          http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
                          http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.5.3 - 03.06.2024
                            • Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
                            • Fixed a javascript bug for window and door presets.
                            • Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
                            • Rearranged the door casing section of the door Draw and Edit menus.
                            • Fixed a bug with the advanced options for all wall types when using metric templates.
                            http://design.medeek.com/resources/wallplugin/images6/wall_su744_800.jpg
                            With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself. I highly recommend upgrading to this latest release of the plugin.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.5.4 - 03.08.2024
                              • Enabled an end grain material for top and bottom plates of rectangular walls.
                              • Fixed a javascript bug for garage door presets.
                              • Fixed a bug with door presets when using metric templates.
                              http://design.medeek.com/resources/wallplugin/images6/wall_su745_800.jpg
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.5.4b - 03.09.2024
                                • Enabled a pressure treated end grain material for bottom plates of all walls.
                                • Enabled end grain materials for in-wall columns.
                                • Enabled end grain materials for beams.
                                • Enabled end grain materials for blocks.
                                • Enabled end grain materials for posts.
                                http://design.medeek.com/resources/wallplugin/images6/wall_su749_800.jpg
                                http://design.medeek.com/resources/wallplugin/images6/wall_su746_800.jpg
                                http://design.medeek.com/resources/wallplugin/images6/wall_su747_800.jpg
                                http://design.medeek.com/resources/wallplugin/images6/wall_su748_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.5.5 - 03.11.2024
                                  • Added a "Custom Glass" garage door type/option with fully customizable glass panels.
                                  • Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su750_800.jpg
                                  I will need to create a tutorial video explaining the proper syntax for the "Glass List".
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Medeek Wall Plugin Tutorial 47 - Custom Glass Garage Doors (w/ Webcam)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.5.6 - 03.21.2024
                                      • Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
                                      • Updated and added additional tool tips within the Global Settings.
                                      design.medeek.com
                                      gullfoG 1 Reply Last reply
                                      • gullfoG
                                        gullfo @medeek
                                        is that a level 4 or level 5 finish? πŸ˜‰
                                        Glenn
                                        • medeekM
                                          medeek
                                          Version 3.5.7 - 04.17.2024
                                          • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.5.8 - 04.25.2024
                                            • Fixed a bug with cripple studs over windows and doors.
                                            • Fixed a bug with the copy wall tool.
                                            alt text
                                            design.medeek.com
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 80
                                            • 81
                                            • 68 / 81
