    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • gullfoG Offline
      gullfo
      one thing i recently ran into was needed a steel column to support a steel beam spanning a couple of walls to get the proper support for ceiling joists. it would be a nice option (not necessarily to provide a steel column in leiu of a wood one πŸ˜„ ) but just to leave the space for easily adding one separately (and thus avoiding closing it etc when regenerating due to a wall change).
      cheers!
      Glenn
      http://www.runnel.com
      • medeekM Offline
        medeek
        I could provide another option in the Advanced Options section which essentially removes the column and leaves a blank opening in wall. Is this what you are suggesting?
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • gullfoG Offline
          gullfo
          yes, or even just have a column type of "blank" (or simply marker) in the selection list (along with x dia round steel, x by x wood, etc) πŸ˜„ this way the code is effectively the same, just whether or not the spacing has anything other than say a 2D marker of the column location.
          Glenn
          • medeekM Offline
            medeek
            Version 3.4.5 - 01.28.2024
            • Added two additional column types for in-wall columns: Custom, Blank.
            • Three additional parameters added for custom in-wall columns.
            • Added a custom label option and annotation section for in-wall columns.
            • Updated the javascript logic within the License tab of the Global Settings.
            http://design.medeek.com/resources/wallplugin/images6/wall_su728_800.jpg
            Technically this update is a bit redundant because one can already configure custom in-wall columns within the global settings. However, this new option gives one the ability to insert any sort of column into the wall (non-wood) as well as a blank opening where one could then insert their own manually modeled column or structural support.
            The custom label option applies to all column types, so it can override the auto labeling algorithm of the module.
            This update per customer request.
            design.medeek.com
            • gullfoG Offline
              gullfo
              thanks! this will be handy as i design a lot of studio where the isolation structure has to be separated from the exterior and custom columns and sizing it for that critical 2" separation, using i-beams and glulams, when using autogenerated walls etc will make this much easier to draw and document πŸ˜„
              Glenn
              • medeekM Offline
                medeek
                Version 3.4.5b - 01.28.2024
                • Fixed a bug with holdowns for in-wall columns.
                • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.4.6 - 01.30.2024
                  • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
                  • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
                  • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
                  • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
                  http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
                  http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
                  http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
                  All updates per customer requests.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.4.7 - 02.01.2024
                    • Updated the Columns tab of the Global Settings with new parameters.
                    • Added glazing color and opacity parameters to the Sheathing tab of the Global Settings.
                    http://design.medeek.com/resources/wallplugin/images6/wall_su732_800.jpg
                    http://design.medeek.com/resources/wallplugin/images6/wall_su733_800.jpg
                    The Columns tab now includes Custom and Blank under Column Type.
                    Up until now the glass color and opacity has been hard coded in to the plugin, now the user can adjust these values if desired.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.4.8 - 02.04.2024
                      • Added a Sheathing Reset button in the Sheathing tab of the Global Settings.
                      • Added Dimension Layer 5 specfically for framing/elevation auto-dimensions (Layer tab of the global settings).
                      • Enabled editing of dimensions for framing/elevation dimensions (rectangular walls only).
                      http://design.medeek.com/resources/wallplugin/images6/wall_su734_800.jpg
                      http://design.medeek.com/resources/wallplugin/images6/wall_su735_800.jpg
                      Tutorial 46 - Editing Framing Dimensions (7:34 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.4.9 - 02.16.2024
                        • Added an RGB color code input into the Add, Update and Import menus for custom materials.
                        • Added an RGB color code input for each color in the Materials tab of the Global Settings.
                        • Added a "Toggle RGB Input" button to the Materials tab of the Global Settings.
                        http://design.medeek.com/resources/wallplugin/images6/wall_su736_800.jpg
                        http://design.medeek.com/resources/wallplugin/images6/wall_su737_800.jpg
                        Updates per customer request.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.5.0 - 02.23.2024
                          • Separated the tee blocking option for exterior and interior walls.
                          • Fixed a bug with geometry guides for metric templates.
                          http://design.medeek.com/resources/wallplugin/images6/wall_su738_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.5.1 - 02.24.2024
                            • Added a 45 and 135 degree rainscreen option for rectangular walls.
                            http://design.medeek.com/resources/wallplugin/images6/wall_su739_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.5.2 - 03.02.2024
                              • Added the following door types: 3/4 glass, double 3/4 glass.
                              • Added a separate threshold material option for all man doors.
                              • Added additional grille (grid) options for glass doors.
                              http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
                              http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
                              http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.5.3 - 03.06.2024
                                • Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
                                • Fixed a javascript bug for window and door presets.
                                • Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
                                • Rearranged the door casing section of the door Draw and Edit menus.
                                • Fixed a bug with the advanced options for all wall types when using metric templates.
                                http://design.medeek.com/resources/wallplugin/images6/wall_su744_800.jpg
                                With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself. I highly recommend upgrading to this latest release of the plugin.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.5.4 - 03.08.2024
                                  • Enabled an end grain material for top and bottom plates of rectangular walls.
                                  • Fixed a javascript bug for garage door presets.
                                  • Fixed a bug with door presets when using metric templates.
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su745_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.5.4b - 03.09.2024
                                    • Enabled a pressure treated end grain material for bottom plates of all walls.
                                    • Enabled end grain materials for in-wall columns.
                                    • Enabled end grain materials for beams.
                                    • Enabled end grain materials for blocks.
                                    • Enabled end grain materials for posts.
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su749_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su746_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su747_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su748_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.5.5 - 03.11.2024
                                      • Added a "Custom Glass" garage door type/option with fully customizable glass panels.
                                      • Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
                                      http://design.medeek.com/resources/wallplugin/images6/wall_su750_800.jpg
                                      I will need to create a tutorial video explaining the proper syntax for the "Glass List".
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Medeek Wall Plugin Tutorial 47 - Custom Glass Garage Doors (w/ Webcam)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.5.6 - 03.21.2024
                                          • Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
                                          • Updated and added additional tool tips within the Global Settings.
                                          design.medeek.com
                                          gullfoG 1 Reply Last reply Reply Quote 0
                                          • gullfoG Offline
                                            gullfo @medeek
                                            is that a level 4 or level 5 finish? πŸ˜‰
                                            Glenn
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 79
                                            • 80
                                            • 68 / 80
