    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 3.3.8 - 12.02.2023
      • Updated the face selection algorithm of the draw wall perimeter tool.
      This addresses the issue of selecting faces that are embedded or nested within groups. You can now select faces that are in the root of the model or nested within other groups.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.3.9 - 12.18.2023
        • Added a "Cedar Siding" built-in material (horizontal) into the material library.
        http://design.medeek.com/resources/wallplugin/images6/wall_su723_800.jpg
        This material is a horizontal version of the previously added vertial version. This update per customer request.
        design.medeek.com
        • medeekM
          medeek
          Version 3.4.0 - 12.22.2023
          • Fixed a minor bug with the error checking code for custom casing profiles of windows and doors.
          • Added top and bottom vertical offset parameters for shearwall sheathing.
          • Added a QHQ casement window to the window draw and edit modules.
          http://design.medeek.com/resources/wallplugin/images6/wall_su725_800.jpg
          http://design.medeek.com/resources/wallplugin/images6/wall_su726_800.jpg
          Both updates are per customer request.
          design.medeek.com
          • medeekM
            medeek
            Version 3.4.1 - 12.29.2023
            • Updated and improved the license verification module.
            • Disabled redundant logging to improve plugin performance.
            design.medeek.com
            • medeekM
              medeek
              Version 3.4.2 - 01.09.2024
              • Fixed a bug with steel framing and tee intersections.
              • Fixed a bug with hip walls and tee intersections (two stud with blocking).
              design.medeek.com
              • medeekM
                medeek
                Version 3.4.3 - 01.18.2024
                • Improved the serial number verification logic within the License tab of the Global Settings.
                • Added a Door Reset button in the Doors tab of the Global Settings.
                • Added a Window Reset button in the Windows tab of the Global Settings.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.4.4 - 01.24.2024
                  • Added a pressure treated option for in-wall columns.
                  • Created a more realistic material/texture for pressure treated timbers (for in-wall columns and posts).
                  http://design.medeek.com/resources/wallplugin/images6/wall_su727_800.jpg
                  design.medeek.com
                  • gullfoG
                    gullfo
                    one thing i recently ran into was needed a steel column to support a steel beam spanning a couple of walls to get the proper support for ceiling joists. it would be a nice option (not necessarily to provide a steel column in leiu of a wood one πŸ˜„ ) but just to leave the space for easily adding one separately (and thus avoiding closing it etc when regenerating due to a wall change).
                    cheers!
                    Glenn
                    http://www.runnel.com
                    • medeekM
                      medeek
                      I could provide another option in the Advanced Options section which essentially removes the column and leaves a blank opening in wall. Is this what you are suggesting?
                      design.medeek.com
                      • gullfoG
                        gullfo
                        yes, or even just have a column type of "blank" (or simply marker) in the selection list (along with x dia round steel, x by x wood, etc) πŸ˜„ this way the code is effectively the same, just whether or not the spacing has anything other than say a 2D marker of the column location.
                        Glenn
                        • medeekM
                          medeek
                          Version 3.4.5 - 01.28.2024
                          • Added two additional column types for in-wall columns: Custom, Blank.
                          • Three additional parameters added for custom in-wall columns.
                          • Added a custom label option and annotation section for in-wall columns.
                          • Updated the javascript logic within the License tab of the Global Settings.
                          http://design.medeek.com/resources/wallplugin/images6/wall_su728_800.jpg
                          Technically this update is a bit redundant because one can already configure custom in-wall columns within the global settings. However, this new option gives one the ability to insert any sort of column into the wall (non-wood) as well as a blank opening where one could then insert their own manually modeled column or structural support.
                          The custom label option applies to all column types, so it can override the auto labeling algorithm of the module.
                          design.medeek.com
                          • gullfoG
                            gullfo
                            thanks! this will be handy as i design a lot of studio where the isolation structure has to be separated from the exterior and custom columns and sizing it for that critical 2" separation, using i-beams and glulams, when using autogenerated walls etc will make this much easier to draw and document πŸ˜„
                            Glenn
                            • medeekM
                              medeek
                              Version 3.4.5b - 01.28.2024
                              • Fixed a bug with holdowns for in-wall columns.
                              • Fixed a bug with the bottom plate cutting algorithm for in-wall columns.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.4.6 - 01.30.2024
                                • Added a "Dimension to Centerline" option for framing dimensions in the General tab of the Global Settings.
                                • Enabled centerline dimensioning for openings, columns and SSW for rectangular walls.
                                • Added a "Style 5" (Pull Plate) to the built-in door hardware options.
                                • Added more options for grid style window grilles: 3X4, 4X5, 5X6.
                                http://design.medeek.com/resources/wallplugin/images6/wall_su730_800.jpg
                                http://design.medeek.com/resources/wallplugin/images6/wall_su729_800.jpg
                                http://design.medeek.com/resources/wallplugin/images6/wall_su731_800.jpg
                                All updates per customer requests.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.4.7 - 02.01.2024
                                  • Updated the Columns tab of the Global Settings with new parameters.
                                  • Added glazing color and opacity parameters to the Sheathing tab of the Global Settings.
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su732_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images6/wall_su733_800.jpg
                                  The Columns tab now includes Custom and Blank under Column Type.
                                  Up until now the glass color and opacity has been hard coded in to the plugin, now the user can adjust these values if desired.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.4.8 - 02.04.2024
                                    • Added a Sheathing Reset button in the Sheathing tab of the Global Settings.
                                    • Added Dimension Layer 5 specfically for framing/elevation auto-dimensions (Layer tab of the global settings).
                                    • Enabled editing of dimensions for framing/elevation dimensions (rectangular walls only).
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su734_800.jpg
                                    http://design.medeek.com/resources/wallplugin/images6/wall_su735_800.jpg
                                    Tutorial 46 - Editing Framing Dimensions (7:34 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.4.9 - 02.16.2024
                                      • Added an RGB color code input into the Add, Update and Import menus for custom materials.
                                      • Added an RGB color code input for each color in the Materials tab of the Global Settings.
                                      • Added a "Toggle RGB Input" button to the Materials tab of the Global Settings.
                                      http://design.medeek.com/resources/wallplugin/images6/wall_su736_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images6/wall_su737_800.jpg
                                      Updates per customer request.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.5.0 - 02.23.2024
                                        • Separated the tee blocking option for exterior and interior walls.
                                        • Fixed a bug with geometry guides for metric templates.
                                        http://design.medeek.com/resources/wallplugin/images6/wall_su738_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.5.1 - 02.24.2024
                                          • Added a 45 and 135 degree rainscreen option for rectangular walls.
                                          http://design.medeek.com/resources/wallplugin/images6/wall_su739_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.5.2 - 03.02.2024
                                            • Added the following door types: 3/4 glass, double 3/4 glass.
                                            • Added a separate threshold material option for all man doors.
                                            • Added additional grille (grid) options for glass doors.
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su741_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su742_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su743_800.jpg
                                            design.medeek.com
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 80
                                            • 81
                                            • 67 / 81
