    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 355.6k Views 91 Watching
      Blns Newcomers
      @panixia said:
      @studiospectre said:
      Unfortunately my menu bar is still completely gone 😞
      I think I'll finally upgrade from 21 to 23
      Naa.. It works fine in 2021 (tbh it works way better than it does on 2023 due to the 23 UI limitation).
      You probably messed up the install.
      Make sure to download and install this:
      LibFredo6 | SketchUcation
      (sketchucation.com)
      THEN download and install this:
      LordOfTheToolbars | SketchUcation
      (sketchucation.com)
      Reboot Sketchup and you toolbars will show up again.
      My toolbars still aren't activated... 😞
      I tried to instell the extension in the second link you posted, but it still has an expiration date at 31.10.2023, is this the problem?
        carlosmgilp
        Hello how are you.
        My version of 2.5a expired.
        When will there be a new update?
        Or how can I solve this problem.
        Thank you.
        • cmeedC Offline
          cmeed
          Hi All,
          I have recently updated to SU2023 and this is my first time hearing about a UI limitation and it having a negative effect on LOTB.
          Since updating LOTB and SU, my personal buttons I've created, have stopped working. They are greyed out as if the extension/plugin is not associated with it.
          When I 'edit' or create 'New' the next window that pops up should show all the extensions/plugins to associate with the icon/button - as you see, this is Blank. even when i search...
          Is the UI limitation in SU2023 my problem ? or me doing it wrong? or something else, otherwise its working as expected.
          Cheers in Advance
          • fredo6F Offline
            SU2023 has introduced a radical change of the UI technical framework (migrating to Qt).
            As a result, all features related to Menu commands and Clear Screen cannot work and are disabled in SU2023.
            Sorry for that. I don't think there will be a solution for the future, as there is no longer any API to access menus and screen visual elements.
            • panixiaP Offline
              panixia
              I posted a workaround a few pages before
              https://sketchucation.com/forums/viewtopic.php?f=323&t=73776&start=270#p687744
              • cmeedC Offline
                cmeed
                @fredo6 said:
                This is indeed sad news! LOTB has speeded up my work. Its quick, easy and (was) very adapatble. I am still a keen fan and will be a tester if ever you need help with further developments.
                Cheers for all your hard work
                  rv1974
                  my 2 cents: Just make ONE large vertical (say 6X30) palette, add separators\line breaks where needed - so everything is in one place perfectly organized on the 2nd monitor. No need in extra menus or palettes (maybe except history). the rest is shortcuts and tool search
                    AISmebel
                    Hi. Personally, I still haven't figured out how to use your method ((( Will you have the opportunity to write instructions in more detail for noobs 😆
                    • cmeedC Offline
                      cmeed
                      @rv1974
                      Thanks for the 2cents. Sounds great - Not sure if it helps me with the buttons I’d created for plugins that don’t have buttons. But I do take you’re point about short cuts. I have so many though it’s hard to keep them in my head, especially the ‘used occasionally’ variety. Also I am running out of suitable key combinations ! Ha ha. I tend to keep everything on the left hand side of the keyboard for speed and one hand.
                        rv1974
                        @cmeed
                        My 2c are related to your disappeared menus, custom icons are aside
                        • fredo6F Offline
                          NEW RELEASE: LordOfTheToolbars v2.7a - 02 Apr 24
                          Requirements
                          • LibFredo6: v14.3b or above
                          LordOfTheToolbars 2.7a is a maintenance release for:
                          • Future compatibility
                          Home Page of LordOfTheToolbars for information and Download.
                          Main post of this LordOfTheToolbars thread.
                          • fredo6F Offline
                            NEW RELEASE: LordOfTheToolbars v2.7b - 07 Apr 24
                            Requirements
                            LordOfTheToolbars 2.7b is a maintenance release for:
                            • SU2024
                            • Fix for shortcuts
                            • Visual adjustment for palettes
                            A 1 Reply Last reply Reply Quote 0
                              AISmebel @fredo6
                              @fredo6 Hello dear Fredo. I would like to ask you if you can expect to repair the "menu" tab in new versions of SU in your future updates?
                              • 1 Offline
                                17628046164
                                Hello dear fredo, I am a heavy user of Lott. I upgraded from su2021 to 2024 and noticed some issues. When I right-click on an icon, only the system native icon like 1 will pop up a menu, while most icons like 2 will not pop up a menu. Is this my problem or is it a bug? I hope to receive your help. Thank you
                                  TECHDAVE02
                                  No scroll bars?
                                  can't get to the button at bottom of windows ?
                                  fredo6F 1 Reply Last reply Reply Quote 0
                                    RLGL
                                    With the 2024 version, I am trying to configure new palettes, how ever the ability to add line breaks, separators etc is missing from the right-click menu.
                                    • fredo6F Offline
                                      fredo6 @RLGL
                                      @RLGL
                                      Do you see the commands if you right-click ON an icon?
                                      R 1 Reply Last reply Reply Quote 0
                                        RLGL @fredo6
                                        @fredo6 If I right-click on an icon there are no commands shown. This is using Win 10 (if that makes a difference).
                                        • fredo6F Offline
                                          fredo6 @TECHDAVE02
                                          @TECHDAVE02
                                          It seems that the problem might be related to the Text Scaling factor in Windows, as per this post on the Sketchup Forum.
                                            rv1974
                                            @fredo6 My latest LOTT (win11, SU24) lost right click (on icons) menu shown by
                                            17628046164 6 posts above. Might it be fixed please?
                                            • 24
                                            • 25
                                            • 7 / 25
