    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 150.7k Views 49 Watching
      Antimo98
      I use SketchUp 2014.
      The file (attached) contains an image and a single poligon realized and exported in KML by Google Earth
      When I run the kml tools for any files .kml everywhere it is in PC (c:, Desktop, other directory) always it says:
      1. "the model does not contain a Google Earth terrain. Do you want import one first , Yes No"
        in both cases
      2. "File seems non to exist. Please check the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
      Where is the problem?
      Thank you for all contributions.
      Regards
      Antimo
      Good in Google Earth but not in SU.
      • B
        balique_bap
          in both cases
        Regards
        Antimo
        I have the same issue.
        Has anybody found a solution ?
        Thank you very much,
        Baptiste
        • B
          balique_bap
          Post to be deleted.
          • U
            usablake
            Sweet plugin, any plans for an update to use with new versions?
            • P
              PatrickBiani
              Hello, I'm looking for a tutorial explaining in detail how the "TimeSpan" plugin works, thank you in advance and good luck
                jonathantrepanier
                I would love to try this plugin, but I have an error message can you help to find a solution?
                Erreur de chargement du fichier C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb
                Error: #<SyntaxError: C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:103: formal argument cannot be an instance variable
                ...d_action_callback("init"){|@dlg, param|
                C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:133: formal argument cannot be an instance variable
                ..._callback("receiveJson") {|@dlg, json|
                C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb:2:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in require'
                C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in load' C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in register_extension'
                C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in `<top (required)>'
                  ...){|@dlg, json| is where the issue lies...
                  In newer Rubies you cannot use an instance variable [ @...] as a argument in a block.
                  As it's an RB file you could try finding all such occurrences in the reported files.
                  Replace @dlg with dlg
                  You need to do this with all {|...|... blocks BUT not elsewhere in the code as I expect @dlg will be needed...
                  After the |...| you might be able to add @dlg=dlg to minimize the required editing, if @dlg is defined earlier, or used later ??
                  Perhaps the author can do a fix ??
                  • C
                    cpuwolf
                    kmlTools_1_4_12.rbz + sketchup8 works. Thank you
                    • I
                      ivanunki Newcomers
                      thank u! ill save and open with 2023 version.
                      • H
                        hanowski Newcomers
                        In Google Earth I "Save Place As..." contours.kml. I use your tool Extensions > KML Tools > Import KML File to import it into sketchup, it says "The model does not contain a Google Earth terrain. Do you want to import one first?". I click the "No" button.
                        Then it says "File seems not to exist. Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
                        Suggestions?
                        • 7 / 7
