    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 139.1k Views 49 Watching
      BIANI patrick
      Sir, I have installed your update (SketchUp 8 Pro), but I can not find anywhere in the menu can add Timespan, thank you for your help
        Antimo98
        I use SketchUp 2014.
        The file (attached) contains an image and a single poligon realized and exported in KML by Google Earth
        When I run the kml tools for any files .kml everywhere it is in PC (c:, Desktop, other directory) always it says:
        1. "the model does not contain a Google Earth terrain. Do you want import one first , Yes No"
          in both cases
        2. "File seems non to exist. Please check the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
        Where is the problem?
        Thank you for all contributions.
        Regards
        Antimo
        Good in Google Earth but not in SU.
          balique_bap
            in both cases
          Regards
          Antimo
          I have the same issue.
          Has anybody found a solution ?
          Thank you very much,
          Baptiste
            balique_bap
            Post to be deleted.
            • U Offline
              usablake
              Sweet plugin, any plans for an update to use with new versions?
                PatrickBiani
                Hello, I'm looking for a tutorial explaining in detail how the "TimeSpan" plugin works, thank you in advance and good luck
                  jonathantrepanier
                  I would love to try this plugin, but I have an error message can you help to find a solution?
                  Erreur de chargement du fichier C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb
                  Error: #<SyntaxError: C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:103: formal argument cannot be an instance variable
                  ...d_action_callback("init"){|@dlg, param|
                  C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:133: formal argument cannot be an instance variable
                  ..._callback("receiveJson") {|@dlg, json|
                  C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                  C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb:2:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in require'
                  C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in load' C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in register_extension'
                  C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in `<top (required)>'
                    ...){|@dlg, json| is where the issue lies...
                    In newer Rubies you cannot use an instance variable [ @...] as a argument in a block.
                    As it's an RB file you could try finding all such occurrences in the reported files.
                    Replace @dlg with dlg
                    You need to do this with all {|...|... blocks BUT not elsewhere in the code as I expect @dlg will be needed...
                    After the |...| you might be able to add @dlg=dlg to minimize the required editing, if @dlg is defined earlier, or used later ??
                    Perhaps the author can do a fix ??
                      cpuwolf
                      kmlTools_1_4_12.rbz + sketchup8 works. Thank you
                      • I Offline
                        ivanunki Newcomers
                        thank u! ill save and open with 2023 version.
                        • H Offline
                          hanowski Newcomers
                          In Google Earth I "Save Place As..." contours.kml. I use your tool Extensions > KML Tools > Import KML File to import it into sketchup, it says "The model does not contain a Google Earth terrain. Do you want to import one first?". I click the "No" button.
                          Then it says "File seems not to exist. Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
                          Suggestions?
                          • 7 / 7
