    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 147.8k Views 49 Watching
    • O Offline
      organicmotion
      "File seems not to exist.
      Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
      Am I doing something wrong? Took the KMZ file from gps opened in Google earth saved as KML then tried to import into SU with the KMLtools and I get the error above..
      any ideas anyone? Thanks, I am a beginner with SU 😄
        truga
        It appears that KML Tools are not yet compatible with 2014. I get the message:
        Error Loading File kmlDate.rb
        Error: #<SyntaxError: C:/Users/truga/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/kmlDate.rb:77: formal argument cannot be a global variable
        ...previewTimeLine") {|$kmlDateDlg, param|
        etc.
          borrel
          I am getting the same problem (Mac OSX 10.9.2) with v 2013 and 2014 - with Google SketchUp 8.0.15157 - the old version works fine. Sad, because SU is a great tool for visualization AND a converter to make X3D files from GPS-GPX tracks thus: GPS tracker > GPX > KML (gpsbabel or GPS Viz) > SKP > VRML (WRL) > X3D (via aopt). See the models here: http://abdallah.hiof.no/drone/index.html
            Gorin21
            great job with the plugin! I would like to know, if the functionality of adding timestamps can be included in next release? In 2.0 beta there is none, in the previous stable version, there is availability to add a timestamp.
            Thanks for the reply,
            Paul
              BIANI patrick
              Sir, would it be possible to have a detailed using your KML exporter of interesting tutorial.
              I would like to export animations 'Keyframe' to Google earth to animate a plane flight or a vehicle path, but do not have your talent developer, looking for a simple tool that can help me in this regard,
              thank you for your attention.
              Patrick
              patrickbiani13@gmail.com
              http://www.wix.com/patrickbiani13/scan-service
                BIANI patrick
                Sir, I have installed your update (SketchUp 8 Pro), but I can not find anywhere in the menu can add Timespan, thank you for your help
                  Antimo98
                  I use SketchUp 2014.
                  The file (attached) contains an image and a single poligon realized and exported in KML by Google Earth
                  When I run the kml tools for any files .kml everywhere it is in PC (c:, Desktop, other directory) always it says:
                  1. "the model does not contain a Google Earth terrain. Do you want import one first , Yes No"
                    in both cases
                  2. "File seems non to exist. Please check the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
                  Where is the problem?
                  Thank you for all contributions.
                  Regards
                  Antimo
                  Good in Google Earth but not in SU.
                    balique_bap
                      in both cases
                    Regards
                    Antimo
                    I have the same issue.
                    Has anybody found a solution ?
                    Thank you very much,
                    Baptiste
                      balique_bap
                      Post to be deleted.
                      • U Offline
                        usablake
                        Sweet plugin, any plans for an update to use with new versions?
                          PatrickBiani
                          Hello, I'm looking for a tutorial explaining in detail how the "TimeSpan" plugin works, thank you in advance and good luck
                            jonathantrepanier
                            I would love to try this plugin, but I have an error message can you help to find a solution?
                            Erreur de chargement du fichier C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb
                            Error: #<SyntaxError: C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:103: formal argument cannot be an instance variable
                            ...d_action_callback("init"){|@dlg, param|
                            C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlImport.rb:133: formal argument cannot be an instance variable
                            ..._callback("receiveJson") {|@dlg, json|
                            C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                            C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools/kmlTools_loader.rb:2:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in require'
                            C:/Program Files/SketchUp/SketchUp 2022/Tools/extensions.rb:197:in load' C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in register_extension'
                            C:/Users/UTILISATEUR/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/kmlTools.rb:17:in `<top (required)>'
                              ...){|@dlg, json| is where the issue lies...
                              In newer Rubies you cannot use an instance variable [ @...] as a argument in a block.
                              As it's an RB file you could try finding all such occurrences in the reported files.
                              Replace @dlg with dlg
                              You need to do this with all {|...|... blocks BUT not elsewhere in the code as I expect @dlg will be needed...
                              After the |...| you might be able to add @dlg=dlg to minimize the required editing, if @dlg is defined earlier, or used later ??
                              Perhaps the author can do a fix ??
                                cpuwolf
                                kmlTools_1_4_12.rbz + sketchup8 works. Thank you
                                • I Offline
                                  ivanunki Newcomers
                                  thank u! ill save and open with 2023 version.
                                  • H Offline
                                    hanowski Newcomers
                                    In Google Earth I "Save Place As..." contours.kml. I use your tool Extensions > KML Tools > Import KML File to import it into sketchup, it says "The model does not contain a Google Earth terrain. Do you want to import one first?". I click the "No" button.
                                    Then it says "File seems not to exist. Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
                                    Suggestions?
                                    • 7 / 7
