    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • N Offline
      ncallen Newcomers
      Hi! I recently used Loft By Spline to loft a series of complex curves and it worked beautifully, I came back to the project after a few weeks and am suddenly unable to complete the action. I get the error message "Error in the construction of the Junctions - Try to change the parameters" instead. Has there been an update or something? In the attached file, the image of the object I successfully lofted is next to the one I'm trying to loft. I can upload the actual .skp file if need be.
        Please do
        • H Offline
          happygonzogmail Newcomers
          my curviloft is give me an expiring massage before i even use it.what must i do.
            Install the latest versions of the extension, and LibFredo, and the SketchUcation toolset [which deals with SCF licensing].
            Restart SketchUp afterwards to sync everything.
            If you don't have a license you must buy one... then activate it...
            There are several posts about this on the forum...
              AlphaFox
              Hello, the toolbar buttons are not appearing, the same thing happens with other plugins in the Fredotools collection, any solution?
                ciaran370 Newcomers
                I'm having the same issue.
                I just downloaded Sketchup 23.1.340, and I have installed:
                Curviloft 1.9b
                LibFredo6 14.2a
                SketchUcation Toolset 4.3.1
                (as far as I can tell, the latest versions of everything)
                When I attempt to use Curviloft, I get a message that my free license expired on Thursday 30th December 2021
                I have tried restarting both SketchUp and my computer, but nothing is working...
                Any idea what to try next?
                  You haven't bought a license and validated it ??
                    savata
                    Hello. I'm trying to buy Fredo6Bundle2022-8 on sketchucation.com but it's not successful. Can you contact me? cimsav-at-hotm co
                      savata
                      Hello... I want to buy Fredo6Bundle2022 - 8 via sketchucation, but the system does not make me pay. If you give me an IBAN, what if I pay that way?
                        In what country are you?
                        What version of SketchUp are you using? You put 2022 Free/Make in your profile but there is no such version.
                        • E Offline
                          erikcoleman1992
                          I accidently exited out of the little curviloft plug in tool bar and im having trouble getiing it to show back up. how do you get that to pop back up!? please help!!
                            cicollaart
                            I just bought « CURVILOFT PERPETUAL LICENSE », yet I have 2 problems :
                            First, both RBZ files « CURVILOFT_v1.9.rbz » and « LibFredo6_v14.2&.rdb » won’t get installed with my extensions manager on Sketchup. For information, my setting has all the requirements.
                            Then, I see I can download the exact same files for free.
                            So first, I’m asking for your help to run these 2 plugins on my computer, then I’m asking for a refund.
                            Thank you in advance.
                              What do you mean "my setting has all the requirements"? One requirement for using Curviloft is that you also have the current version of the Sketchucation Extension Store installed. If you have that installed you should use it to install LibFred06 and Curvilot.
                              Where can you get Curviloft for free? It won't run without a license which you must pay for.
                              • fredo6F Offline
                                NEW RELEASE: Curviloft v2.0a - 31 Mar 24
                                Curviloft 2.0a is a maintenance release including changes for
                                • Future compatibility
                                See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                                Main post of this thread
                                R 1 Reply Last reply Reply Quote 0
                                  rv1974 @fredo6
                                  @fredo6 "Future compatibility" sounds like v2025 is close, isn't it?
                                    rsaum
                                    Hi. Unless it's just me, the tool icons for the plugin are undersized (v 2017), which makes them look pixelated on the main toolbar. Thanks.
                                      mlt27 Newcomers
                                      hola! no consigue que funcione curviloft, lo acabo de descargar pero no se como poner la licencia gratuita de 30 dias, cmo se hace?
                                      Hi! I can't get Curviloft to work. I just downloaded it, but I don't know how to install the free 30-day license. How do I do it?
                                        bebert77 Newcomers @fredo6
                                        i cant load my license of curviloft .
                                        TIGT 1 Reply Last reply Reply Quote 0
                                          TIG Moderator @bebert77
                                          @bebert77
                                          Please give us more info.
                                          Error messages / dialogs etc...
                                            RASKL
                                            Hello,
                                            This tool has stopped working since SU 2024. I hover over the buttons and get the info in the info bar, but when I click to use the tool nothing happens. This is when I select the edges or paths before and after clicking the loft tool. Just completely unresponsive.
                                            Can you help? It used to be a major part of my workflow.
                                            Win 11 SU 2026
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 65 / 66
