    Make layer visible or invisible in all scenes
    11 Posts 6 Posters 856 Views 6 Watching
      schaferron1
      I had an extension called, "turn on tag in all scenes" enabled in sketchup.
      It would ask me if I wanted to have a tag to be visible or invisible in all scenes. It was not working properly so I deleted it. But now I cannot find the extension. It is great. It allows you to make a layer visible or invisible in all of your scenes.
      I know about the extension "auto invisible layer" it allows you to create a new layer and it doesn't turn on in all of your existing layers.
      Have you heard of this extension? Where I can find it again?
        Never heard of "turn on tags in all scenes". Where would you have gotten it? Maybe the Extension Warehouse? Maybe it is part of some other extension? Did you have it in a previous version of SketchUp? Maybe you still have that version installed and could open it to see what it really is.
          rv1974
          Plugin: Add Hidden Layer
          Update Apr 2014 - Version 1.0.1 Add a Layer to your SketchUp model and control its visibility on existing and new Scenes. Use Activa...
          (sketchuptips.blogspot.com)
          • TIGT Online
            "Auto Invisible Layer" from the Extension Warehouse
            https://extensions.sketchup.com/search/?q=auto%20invisible%20layer
              schaferron1
              The plugin "auto invisible layer" will it allow me to select a layer and have it turn on or off in all scenes? It seems this plugin is just when a new tag is created, it will not be visible in all the existing scenes. Which is good BTW. Just looking for more .. thanks.
                Maybe I am missing the point but if you CTRL click scenes in the Scene panel and then pick the Visibility in the Tag panel and click Update in the Scenes panel it applies that setting to all selected scenes.
                  schaferron1
                  Hi Rich. Thanks for your reply. I don't see a visibility setting(s) choice in my scenes drop down. I am not quite sure what it is that you are suggesting.
                    schaferron1
                    Question, I just loaded the extension "Auto Invisible Layer ON/OFF" When I close sketchup do I have to remember to turn this extension on? It seems that way. Maybe I am doing something incorrectly.
                      You have to activate it when you want it for each SketchUp session. It isn't automatically enabled when you start SketchUp.
                        Yeah, I thought I was barking up the wrong tree. Regardless here's what I mean...
                        https://i.imgur.com/UZJ9krk.png
                        If you use CTRL+LMB to select your scenes then set the visibility for the Tags and click Update it will apply that to the selected scenes. That's just how I've always done it.
                        Probably not what you are after. But since I am barking I might as well continue howling.
                        • O Offline
                          OSN58
                          SketchUp Extension Warehouse
                          Your library of custom third-party extensions created to optimize your SketchUp workflow.
                          (extensions.sketchup.com)
