    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • samuel_tS
      samuel_t
      1.2.3 version doesn't display anymore the "Source dir of model to import is not writable" error message.
      Download latest Universal Importer plugin from SketchUcation PluginStore.
        romanencom Newcomers
        Dear samuel_t, I just installed your plugin, but I can't import the step file, I get this message. At the same time, a duplicate of it with a different name is created in the folder with this file. You can help me?
        U 1 Reply Last reply
        • O
          Ottown
          Hi Samuel,
          Have downloadeed the latest version along with sketchup pro 2023 for mac, but every time i try to import a model fbx or obj im getting the errow shown.
          Any advise
          Universal Importer Error: Command failed: cd "/Users/davidott/Downloads/Test" && "/Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/Applications/Assimp/Mac/assimp" export "uir-source.3ds" "uir-inter.obj" -tri
          /Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
          Universal Importer Version: 1.2.3
          • samuel_tS
            samuel_t
            Dear Roman,
            Unfortunately, compatibility with the STEP format is low.
            • samuel_tS
              samuel_t
              @ottown said:
              Hi Samuel,
              Any advise
              Hi David,
              In this situation, the error message does not provide enough details. Maybe your macOS is not allowed to run Assimp executable?
              • W
                Waltersch
                Hi Samuel
                First of all thank you very much for this great and super useful extension!
                But I do habe a problem on importing from Model Converter X.
                Here my workflow.
                Construction on Sketchup 17. Export as collada file.
                Import to 3DCoat for texturing. Export as obj file.
                Import to Model Converter X for checking and file conversion. Export as obj file.
                I do check the polygons in every step and they are the same in every step. Pic1 shows the correct wireframe so far.
                Import to Sketchup with "Universal Importer Plugin". Now the wireframe is not as it was in all the steps ahead. Some of the edges are missing. I´m not using any polygon reduction. Pic2 shows the result after the import.
                My question to you is only, why the imported wireframe is not the same as it was in all the other steps ahead. Because the wireframe is broken in some area, the texture does´nt fit any more.
                For an additional explanation. The workfrlow may seam strange and all can be done with different software solutions much easier. You are all right, but this is my workflow I´m used to it.
                  jamesdavies0211
                  Hi!
                  Really love the look of this extension, however, having some issues with importing blend and obj files.
                  Any help would be greatly appreciated!
                  • samuel_tS
                    samuel_t
                    @waltersch said:
                    Here my workflow.
                    Hi Walter,
                    I don't want to criticize your workflow, but try to have less conversion steps as this can cause problems.
                    • samuel_tS
                      samuel_t
                      Hi James!
                      Your .blend model was created with which version of Blender? Could you send it to me via PM please?
                      • Z
                        zenotr
                        hallo! run on sketchup 2023?
                          Yes.
                          Please update your forum profile. It's more than 10 years out of date.
                          • Z
                            zenotr
                            @dave r said:
                            Yes.
                            report this error
                              Janneman Newcomers
                              @ottown said:
                              Hi Samuel,
                              Any advise
                              Hi I had the same problem (running on wine in Linux) and trying to run assimp.exe manually showed that it couldnot find the vcruntime140_1.dll. Copying or linking this to the .../Win/Assimp/ folder solved it.
                              Greeting John
                              • W
                                Waltersch
                                @samuel_t said:
                                @waltersch said:
                                Hi Walter,
                                Hi Samuel
                                Thank your for your reply. I know and you are right. Because I check the mesh in every step and can only find the broken mesh, when importing with "Universal Importer" back to Sketchup, I thought there may be a setting I missed or something else that I did wrong.
                                But any way, thank you for the response.
                                Best regards
                                Walter
                                • N
                                  NinaX
                                  Hi, I'm getting this error for obj files. what to do?
                                  • samuel_tS
                                    samuel_t
                                    1.2.4 version:
                                    • Tries to preserve the original materials names. You should see less materials named <auto>1, <auto>2, etc.
                                    • Enhances compatibility for (non textured) 3MF files and IRR files, thanks to Assimp's contributors! 😊
                                    • Supports an unlimited number of embedded textures (previously the maximum number was 1000).
                                    • Includes an Assimp CLI tool compiled for the Intel Mac and Apple Silicon processors: M1, M2, etc. 🚀
                                      AxiomNick Newcomers
                                      This post is deleted!
                                        AxiomNick Newcomers
                                          AxiomNick Newcomers
                                            AxiomNick Newcomers
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
