    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • samuel_tS
      samuel_t
      @rizkymfadh19 said:
      this amazed me, really thank you for the plugin 👍 👍
      I'm glad to hear that! 😄
        Sondre_S
        Hi, I've used Universal Importer for about a month now and I'm suddenly getting an error saying it doesn't have write access to my documents folder (or any other folder for that matter). The only place it would import from was the root of my C drive! I checked and all folders are marked as "Read Only", but all other programs work correctly.
        I opened import.rb and commented out this:
        # Source dir must be writable to host hard links we'll create later.
              #raise "Source dir of model to import is not writable; #{@source_dir}"\
               # unless File.writable?(@source_dir)
        and I can now import from my documents folder again.
        I found this in an article from Microsoft:
        "The Read-only and System attributes is only used by Windows Explorer to determine whether the folder is a special folder, such as a system folder that has its view customized by Windows (for example, My Documents, Favorites, Fonts, Downloaded Program Files), or a folder that you customized by using the Customize tab of the folder's Properties dialog box. As a result, Windows Explorer does not allow you to view or change the Read-only or System attributes of folders."
        What does it mean if Windows isn't supported? | Microsoft Support
        Learn what it means if you have an older version of Windows that's no longer supported.
        (support.microsoft.com)
        • samuel_tS
          samuel_t
          @Sondre_S
          Thanks for the technical details. I will solve this problem as soon as possible.
          • samuel_tS
            samuel_t
            1.2.3 version doesn't display anymore the "Source dir of model to import is not writable" error message.
            Download latest Universal Importer plugin from SketchUcation PluginStore.
              romanencom Newcomers
              Dear samuel_t, I just installed your plugin, but I can't import the step file, I get this message. At the same time, a duplicate of it with a different name is created in the folder with this file. You can help me?
              U 1 Reply Last reply
              • O
                Ottown
                Hi Samuel,
                Have downloadeed the latest version along with sketchup pro 2023 for mac, but every time i try to import a model fbx or obj im getting the errow shown.
                Any advise
                Universal Importer Error: Command failed: cd "/Users/davidott/Downloads/Test" && "/Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/Applications/Assimp/Mac/assimp" export "uir-source.3ds" "uir-inter.obj" -tri
                /Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
                Universal Importer Version: 1.2.3
                • samuel_tS
                  samuel_t
                  Dear Roman,
                  Unfortunately, compatibility with the STEP format is low.
                  • samuel_tS
                    samuel_t
                    @ottown said:
                    Hi Samuel,
                    Any advise
                    Hi David,
                    In this situation, the error message does not provide enough details. Maybe your macOS is not allowed to run Assimp executable?
                    • W
                      Waltersch
                      Hi Samuel
                      First of all thank you very much for this great and super useful extension!
                      But I do habe a problem on importing from Model Converter X.
                      Here my workflow.
                      Construction on Sketchup 17. Export as collada file.
                      Import to 3DCoat for texturing. Export as obj file.
                      Import to Model Converter X for checking and file conversion. Export as obj file.
                      I do check the polygons in every step and they are the same in every step. Pic1 shows the correct wireframe so far.
                      Import to Sketchup with "Universal Importer Plugin". Now the wireframe is not as it was in all the steps ahead. Some of the edges are missing. I´m not using any polygon reduction. Pic2 shows the result after the import.
                      My question to you is only, why the imported wireframe is not the same as it was in all the other steps ahead. Because the wireframe is broken in some area, the texture does´nt fit any more.
                      For an additional explanation. The workfrlow may seam strange and all can be done with different software solutions much easier. You are all right, but this is my workflow I´m used to it.
                        jamesdavies0211
                        Hi!
                        Really love the look of this extension, however, having some issues with importing blend and obj files.
                        Any help would be greatly appreciated!
                        • samuel_tS
                          samuel_t
                          @waltersch said:
                          Here my workflow.
                          Hi Walter,
                          I don't want to criticize your workflow, but try to have less conversion steps as this can cause problems.
                          • samuel_tS
                            samuel_t
                            Hi James!
                            Your .blend model was created with which version of Blender? Could you send it to me via PM please?
                            • Z
                              zenotr
                              hallo! run on sketchup 2023?
                                Yes.
                                Please update your forum profile. It's more than 10 years out of date.
                                • Z
                                  zenotr
                                  @dave r said:
                                  Yes.
                                  report this error
                                    Janneman Newcomers
                                    @ottown said:
                                    Hi Samuel,
                                    Any advise
                                    Hi I had the same problem (running on wine in Linux) and trying to run assimp.exe manually showed that it couldnot find the vcruntime140_1.dll. Copying or linking this to the .../Win/Assimp/ folder solved it.
                                    Greeting John
                                    • W
                                      Waltersch
                                      @samuel_t said:
                                      @waltersch said:
                                      Hi Walter,
                                      Hi Samuel
                                      Thank your for your reply. I know and you are right. Because I check the mesh in every step and can only find the broken mesh, when importing with "Universal Importer" back to Sketchup, I thought there may be a setting I missed or something else that I did wrong.
                                      But any way, thank you for the response.
                                      Best regards
                                      Walter
                                      • N
                                        NinaX
                                        Hi, I'm getting this error for obj files. what to do?
                                        • samuel_tS
                                          samuel_t
                                          1.2.4 version:
                                          • Tries to preserve the original materials names. You should see less materials named <auto>1, <auto>2, etc.
                                          • Enhances compatibility for (non textured) 3MF files and IRR files, thanks to Assimp's contributors! 😊
                                          • Supports an unlimited number of embedded textures (previously the maximum number was 1000).
                                          • Includes an Assimp CLI tool compiled for the Intel Mac and Apple Silicon processors: M1, M2, etc. 🚀
                                            AxiomNick Newcomers
                                            This post is deleted!
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
