    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
      @zenotr said:
      run on sketchup 2023?
      Yes.
      Please update your forum profile. It's more than 10 years out of date.
      • Z
        zenotr
        @dave r said:
        Yes.
        report this error
          Janneman Newcomers
          @ottown said:
          Hi Samuel,
          Have downloadeed the latest version along with sketchup pro 2023 for mac, but every time i try to import a model fbx or obj im getting the errow shown.
          Any advise
          Universal Importer Error: Command failed: cd "/Users/davidott/Downloads/Test" && "/Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/Applications/Assimp/Mac/assimp" export "uir-source.3ds" "uir-inter.obj" -tri
          /Users/davidott/Library/Application Support/SketchUp 2023/SketchUp/Plugins/universal_importer/assimp.rb:106:in `convert_model'
          Universal Importer Version: 1.2.3
          Hi I had the same problem (running on wine in Linux) and trying to run assimp.exe manually showed that it couldnot find the vcruntime140_1.dll. Copying or linking this to the .../Win/Assimp/ folder solved it.
          Greeting John
          • W
            Waltersch
            @samuel_t said:
            @waltersch said:
            Hi Walter,
            I don't want to criticize your workflow, but try to have less conversion steps as this can cause problems.
            Hi Samuel
            Thank your for your reply. I know and you are right. Because I check the mesh in every step and can only find the broken mesh, when importing with "Universal Importer" back to Sketchup, I thought there may be a setting I missed or something else that I did wrong.
            But any way, thank you for the response.
            Best regards
            Walter
            • N
              NinaX
              Hi, I'm getting this error for obj files. what to do?
              • samuel_tS
                samuel_t
                1.2.4 version:
                • Tries to preserve the original materials names. You should see less materials named <auto>1, <auto>2, etc.
                • Enhances compatibility for (non textured) 3MF files and IRR files, thanks to Assimp's contributors! 😊
                • Supports an unlimited number of embedded textures (previously the maximum number was 1000).
                • Includes an Assimp CLI tool compiled for the Intel Mac and Apple Silicon processors: M1, M2, etc. πŸš€
                Download latest Universal Importer plugin from SketchUcation PluginStore.
                  AxiomNick Newcomers
                  This post is deleted!
                    AxiomNick Newcomers
                      AxiomNick Newcomers
                        AxiomNick Newcomers
                          AxiomNick Newcomers
                          Hi there, I'm having an error importing OBJ and FBX files with the same error. Screenshot 2024-05-09 164640.jpg
                          The file was exported from 3ds max 2024 and imported into sketchup 2022.
                          • G
                            giogrim
                            I'm trying to import the file highlighted in the following photo,File da importare.png but I get the following message.Errore Universal Importer.png
                            what should I do?
                            Thank you.
                            • G
                              Gunner77
                              Hey There...just a quick question on compatibility with SketchUp 2024...is it?
                              ...the text states only 2023...I'm going to give it a try anyway, but just wondered...
                              samuel_tS 1 Reply Last reply
                              • samuel_tS
                                samuel_t @Gunner77
                                Hey @Gunner77,
                                It should works on SketchUp 2024. Let me know if not.
                                • samuel_tS
                                  samuel_t
                                  1.2.5 version:
                                  • Provides finally a good support of STEP (AP203, AP214, AP242) files, thanks to the included Mayo command-line converter.
                                  • Supports two new file formats: IGES (v5.3) and BREP, thanks again to the Mayo software and the Open CASCADE Technology.
                                  Note 1: For the moment, reducing polygons when importing a STEP/IGES/BREP file is not possible. While waiting for a future version which will fill this gap, you can always reduce the polygons by clicking on the swan icon in the plugin toolbar.
                                  Note 2: Although I can't confirm it, the import of STEP/IGES/BREP files should work on macOS as well.
                                    RLGL
                                    I tried the Universal Importer using a 3D step file from McMaster Carr of a bolt and nut. The bolt was 3/4" long. The import brought it in over 100" long.. Am I asking too much to have it come in at the correct scale?
                                    • samuel_tS
                                      samuel_t @RLGL
                                      @RLGL No but can I ask you for a coffee in exchange? I need more blood in my veins to fix the wrong scale problem πŸ˜…
                                      MikeG73M 1 Reply Last reply
                                      • MikeG73M
                                        MikeG73 @samuel_t
                                        @samuel_t Hello Sam, this is a great extension, thank you. But it does not seem to support .blend files, very well. Is there a fix?
                                        Cheers!
                                        • samuel_tS
                                          samuel_t
                                          Hello everyone πŸ™‚
                                          The 1.2.6 version:
                                          • Allows you to specify the source model units (millimeters, centimeters, etc). Most probable units, for the model you are importing, are preselected to accelerate the workflow. However, be still attentive with unitless formats such as OBJ, real scale depends on specifications.
                                          • Automatically fixes, on SketchUp 2018 and newer versions, bad texture coordinates of some glTF models and "unexpected face count after polygon reduction" issue. If you are a SketchUp 2017 user, you will find a manual solution in the Troubleshooting FAQ of the plugin.
                                          • Handles polygon reduction of STEP/IGES/BREP models during the import.
                                          • Automatically fixes orientation of STEP/IGES/BREP models for last time? πŸ˜…
                                          • samuel_tS
                                            samuel_t
                                            @RLGL
                                            I think it's fine now. I imported with the Universal Importer v1.2.6 many STEP and IGES files from McMaster Carr and their scale is everytime correct in SketchUp. Be sure to let millimiters as "Source model units" when importing...
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
