    Missing "More Info"
    25 Posts 5 Posters 2.2k Views 5 Watching
      Thank you for doing that, Gábor.
      • T
        tapimjay
        I've just tried to get "More info" & it will not work
        with any of them. I went to Control Panel & used Uninstall,
        then pressed the Repair button. That didn't work either.
        I must have something wrong with my computer, however I
        will live without it.
        Thanks very much for your efforts.
        Dave & Gabor.
          What were you trying to uninstall/repair?
          • G
            Gábor
            with any of them.
            Hmmm.... Interesting. Do you have Javascript enabled in your internet explorer? The button uses an onclick event for opening up the "More info" what might not work if Javascript is disabled...
            • T
              tapimjay
              I was trying to uninstall/repair SketchUp 2013 & 2014.
              I also cheked if Java Script was enabled, it was.
              • P
                pipinek
                Greetings,
                I have the same issue on one of the two machines Both of them runs the same plugins and SU version 2023.1.340 (last one).
                On one machine there is no button INFO within Sketchucation Tools (dame the latest version of the plugin).
                Bizarre.
                I would appreciate any elucidation.
                Thank you
                Attached-please find a picture - the only button present is that in the middle.
                  It would help if you'd show which extensions don't have a More Info button. All of the ones in your screenshot appear to have them.
                    Pull the side of the dialog to make it slightly wider and up to three buttons per line should appear...
                    This change should be remembered across sessions...
                    • P
                      pipinek
                      I do thank you very much TIG.
                      Indeed pulling the window side make all the content visible.
                      • P
                        pipinek
                        Thank you.
                        I presented the extension window of one of machines. On which all icons has been visible. Not the other one.
                        TIG's suggestion has solves the isdue.
                        • 2 / 2
