    Missing "More Info"
    25 Posts 5 Posters 2.5k Views 5 Watching
    • P
      pipinek
      Greetings,
      I have the same issue on one of the two machines Both of them runs the same plugins and SU version 2023.1.340 (last one).
      On one machine there is no button INFO within Sketchucation Tools (dame the latest version of the plugin).
      Bizarre.
      I would appreciate any elucidation.
      Thank you
      Attached-please find a picture - the only button present is that in the middle.
        It would help if you'd show which extensions don't have a More Info button. All of the ones in your screenshot appear to have them.
          Pull the side of the dialog to make it slightly wider and up to three buttons per line should appear...
          This change should be remembered across sessions...
          • P
            pipinek
            I do thank you very much TIG.
            Indeed pulling the window side make all the content visible.
            • P
              pipinek
              Thank you.
              I presented the extension window of one of machines. On which all icons has been visible. Not the other one.
              TIG's suggestion has solves the isdue.
              • 2 / 2
