    More Fredo6 plugins becoming paid extensions
    165 Posts 56 Posters 95.4k Views 56 Watching
    • fredo6F Offline
      @markduncan1966 said:
      realistically the only person who could have half a chance of answering that question would be the extension developer and possibly only after they interrogated the system in question.
      The first thing is to describe what is the problem, which plugin, etc.... and also to tell us which version of Sketchup you run.
      The second thing is to make sure you have the latest version of
      • LibFredo6
      • Sketchucation ExtensionStore
      • The plugins you use
      If you can, go to menu Window > LibFredo6 Settings... > Check Fredo6 Plugins for Update.
      This will tell you if my plugins are up to date.
        MarkDuncan1966
        • LibFredo6
        ERM...........
        "A PC running win 10, sketch-up pro 2021.
        periodically upon selecting an edge to round off, the plug-in would grey out sketchup and display "program is not responding" this would become indefinite, requiring me to end the process which 9 times out of 10 resulted in a loss of project progress as the Recovered file usually rolled back around 10 minutes."
        And as an engineer, trust me when i tell you i religiously keep EVERYTHING up-to-date, and again from reading the already provided symptoms, logic would be work out that we are discussing one of the "round corner" plug-ins
          Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and paste the ruby console output into your reply.
          Example:
          Fredo6 Plugins Information on 2023-04-11 11;30;02 +0100
          - Platform; x64-mswin64_140 - Ruby; 2.7.2
          - Sketchup; 23.0.367
          - LibFredo6; v13.9a
          - LibFredo6 Binary loaded
          - Sketchucation ExtensionStore; 4.3.1
          - SCFLicense; v6.1a - 72
            As well as the info Rich asked for, could you also post a screen-shot of the extensions tool-bar which should appear across the top of your main screen, including the geometry you want to modify.
            If you have some odd combo of settings leading to a 'loop-of-death', then Fredo might be able to spot something in that screen-shot...
            Most user-induced disasters are trapped in the extension's code, but some can sneak through, especially if it's some obscure combo of settings and model form that hadn't been anticipated...
              TonyAU
              Where can I find the bundle, and whats included.
              It's really hard to find info on this and how to pay etc.
              any help would be great
              Cheers.
              • BoxB Offline
                SketchUcation | Cart
                (sketchucation.com)
                • F Offline
                  filatelik
                  Hello guys, anyone to share multi-license by sharing the cost too? I need only one license(seat) of bundle of 8 plugins. Thank you in advance guys. f
                    adrianapsn Newcomers
                    Hello! πŸ˜„
                    I've bought the 40$ bundle as a company expense. There are a few of the plugins that I've been using/discovering recently and they are just amazing, so I've decided to buy them all. Sadly, in the past, I've bought independently FredoPushPull as a student, so I currently own 2 licenses for it.
                    Is there any way I can get a refund or I'd gladly be happy if at least it can be swapped for another product/plug-in like FredoCorner?
                    Thank you in advance!
                    here you can see it
                      @adrianapsn said:
                      Hello! πŸ˜„
                      Its not possible to refund as the original purchase is ~11 months ago(2022-11-23).
                        @rich o brien said:
                        @adrianapsn said:
                        Hello! πŸ˜„
                        I understand. It is also not possible to swap with a different product/plug-in?
                        Thank you for the answer!
                        A 1 Reply Last reply Reply Quote 0
                          bigbeltrame
                          I bought curviloft in 2022. Is it possible to get a discount on the bundle?
                            bigbeltrame
                              ramonbastos
                              How do I release all seats from my fredo plugins? I want to restart everything.
                                Update extensions on your devices in particular Sketchucation Tools and Libfredo
                                https://sketchucation.com/plugin/696-sketchucationtools
                                https://sketchucation.com/pluginstore?pln=LibFredo6
                                Then at https://sketchucation.com/webshop/my-licences.php you can release online.
                                Otherwise just release seats at the devices using the license dialog for the extension.
                                  adrianapsn Newcomers @adrianapsn
                                  @adrianapsn Hello, any answer on this matter? Is there a way to swap license of my double JointPushPull (1st bought separately, 2nd in the bundle) with a different Fredo product?
                                  Thanks in advance!
                                    Rich O Brien Moderator @adrianapsn
                                    @adrianapsn said in More Fredo6 plugins becoming paid extensions:
                                    Thanks in advance!
                                    There's no way to swap licenses. If purchases were recent (~30days) we could refund but your purchases are Oct 2022 and Nov 2023.
                                    • Dave RD Dave R referenced this topic on
                                    • N Offline
                                      Nifrodel Newcomers
                                      I bought plugins. Can I activate them online and then use them offline without any time limitations?
                                        Rich O Brien Moderator @Nifrodel
                                        @Nifrodel said in More Fredo6 plugins becoming paid extensions:
                                        Yes, it will need to check online periodically but you don't need a constant daily/weekly connection.
                                        • fredo6F Offline
                                          This is an announcement for more plugins becoming paid under SCF License.
                                          As of 01 Sep 25, the following plugins will be licensed, for $15 each ($9 for Premium members), perpetual license for 3 seats, with trial period of 30 days.
                                          • FredoBatch
                                          • ElevationProfile
                                          • FredoSketch
                                          • LayOps
                                          • MatSim
                                          • Pic2Shape
                                          As of 01 Oct 25, the following plugin will be licensed, for $30 each ($18 for Premium members), perpetual license for 3 seats, with trial period of 30 days.
                                          • Animator
                                          E Steve RuggS 2 Replies Last reply Reply Quote 3
                                          • E Offline
                                            Exult @fredo6
                                            @fredo6 How do I pay and download the thrupaint extension?
                                            • 8 / 9
