    Mercedes Mansion
    25 Posts 6 Posters 1.7k Views 6 Watching
    • Bryan KB
      This will have to do. This model really is jinxed. It took 5 tries to get it to load into the render. I also found some foreground objects were double grouped, which also affects the render.
      I changed the HDRI again and then pushed the settings past where I normally set them.
      But I like this one better than all the previous ones.
        Rather smashing actually. πŸ‘
        • Bryan KB
          Thanks. πŸ‘
          I'm still not happy with it, but it's still better than all the previous versions including the first one from several years ago.
            There are times/models and especially from the warehouse, that are so bugged you spend hours just cleaning them up and straightening faces etc so in the end, nothing feels worthwhile.
            Sucks mate but instead of worrying about it I just move on as soon as the things get to be too much irritation.
            • Bryan KB
              Yep. πŸ˜‰
              Already considering my next subject. And there's some animation I need to try.
              • L
                Nice work Bryan, I would google "California palms" (Images) and use the feel of those images as a concept. Tall, elegant palms will transform that image with many palms and maybe some in the foreground also. Always practice safe design, always use a concept πŸ‘ πŸ‘
                • Bryan KB
                  Good suggestions. I tried to work with the included foliage and in hindsight, I should have deleted it all.
                  The high poly count of the foliage also created many of the problems I had loading and working with the model. Even with my new PC, it just bogged everything down.
                  • L
                    @bryan k said:
                    Good suggestions. I tried to work with the included foliage and in hindsight, I should have deleted it all and added my own.
                    I found some pretty nice low poly Palms, about 0.5 MB per tree. I bet if you got rid of the backdrop and existing trees you would be net better off. Whet I see that render my brain cries out palm trees very loudly, Anyway just a thought Bryan πŸ˜„
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    • L
                      Forgive me Bryan but I could not help myself.
                      • Bryan KB
                        HOLLYWOOD! πŸ˜†
                        Yeah, that looks fine. πŸ‘
                        • Bryan KB
                          Many changes. Got rid of the stock foliage. That helped right away. Added L I am's palm trees. Got rid of the HRDI dome and used the render stock lighting and clouds. Fixed a lot of materials. A lot.
                          This model is still jinxed in some way. It took ten tries to get it to render. But I like this version as well.
                          • Bryan KB
                            Meh. I like none of them. πŸ˜•
                            • Bryan KB
                              I cannot let this go.
                              • tuna1957T
                                tuna1957
                                Got to give you credit Bryan you sure are persistent πŸ˜‰ I think I’d have put this model on the shelf by now. Only going to make a couple of comments on these last two images. Keeping in mind a lot of this is just personal preference stuff. Overall these last l ages are a bit bright to me. Seems to wash things out a bit. Second is what’s happening with the palm fronds and big plants out front ? The color seems washed out…. Curious if you do any post processing ? πŸ‘
                                • tuna1957T
                                  tuna1957
                                  Bryan have you considered joining a support group, maybe β€œsketchuppers anonymous” ? Your persistence is to be applauded. πŸ‘ πŸ‘
                                  • Bryan KB
                                    πŸ˜† πŸ˜† πŸ˜†
