    Mercedes Mansion
    25 Posts 6 Posters 1.5k Views 6 Watching
    • Bryan KB Offline
      @mike amos said:
      There are times/models and especially from the warehouse, that are so bugged you spend hours just cleaning them up and straightening faces etc so in the end, nothing feels worthwhile.
      Sucks mate but instead of worrying about it I just move on as soon as the things get to be too much irritation.
      Yep. ๐Ÿ˜‰
      Already considering my next subject. And there's some animation I need to try.
        Nice work Bryan, I would google "California palms" (Images) and use the feel of those images as a concept. Tall, elegant palms will transform that image with many palms and maybe some in the foreground also. Always practice safe design, always use a concept ๐Ÿ‘ ๐Ÿ‘
        • Bryan KB Offline
          Good suggestions. I tried to work with the included foliage and in hindsight, I should have deleted it all.
          The high poly count of the foliage also created many of the problems I had loading and working with the model. Even with my new PC, it just bogged everything down.
            @bryan k said:
            Good suggestions. I tried to work with the included foliage and in hindsight, I should have deleted it all and added my own.
            I found some pretty nice low poly Palms, about 0.5 MB per tree. I bet if you got rid of the backdrop and existing trees you would be net better off. Whet I see that render my brain cries out palm trees very loudly, Anyway just a thought Bryan ๐Ÿ˜„
            3D Warehouse
            (3dwarehouse.sketchup.com)
              Forgive me Bryan but I could not help myself.
              • Bryan KB Offline
                HOLLYWOOD! ๐Ÿ˜†
                Yeah, that looks fine. ๐Ÿ‘
                • Bryan KB Offline
                  Many changes. Got rid of the stock foliage. That helped right away. Added L I am's palm trees. Got rid of the HRDI dome and used the render stock lighting and clouds. Fixed a lot of materials. A lot.
                  This model is still jinxed in some way. It took ten tries to get it to render. But I like this version as well.
                  • Bryan KB Offline
                    Meh. I like none of them. ๐Ÿ˜•
                    • Bryan KB Offline
                      I cannot let this go.
                      • tuna1957T Offline
                        tuna1957
                        Got to give you credit Bryan you sure are persistent ๐Ÿ˜‰ I think Iโ€™d have put this model on the shelf by now. Only going to make a couple of comments on these last two images. Keeping in mind a lot of this is just personal preference stuff. Overall these last l ages are a bit bright to me. Seems to wash things out a bit. Second is whatโ€™s happening with the palm fronds and big plants out front ? The color seems washed outโ€ฆ. Curious if you do any post processing ? ๐Ÿ‘
                        • tuna1957T Offline
                          tuna1957
                          Bryan have you considered joining a support group, maybe โ€œsketchuppers anonymousโ€ ? Your persistence is to be applauded. ๐Ÿ‘ ๐Ÿ‘
                          • Bryan KB Offline
                            ๐Ÿ˜† ๐Ÿ˜† ๐Ÿ˜†
                            • 2 / 2
