    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
    • kimi kimiK
      kimi kimi
      @morisdov said:
      quick solution is to use the following line in the ruby console to set the current selected scene -
      Sketchup.active_model.pages.selected_page.transition_time = 4
      Hi, I'm also having a problem when I want to change transition times. I can't see all the scenes on the screen. The quoted describes how to change it for a particular page, but I wan't to change transition times for a range of pages that fall outside the screen.
      Is there a code to do this for all pages? Or for pages, let's say 23-39?
      • duanekempD
        duanekemp
        Though I've read this thread and others, and the link to the .pdf (https://ligonsketchers.files.wordpress.com/2011/03/proper-animation-tutorial.pdf), I have not found the answer that explains how to do the following:
        Scene 01: Camera 01 - Proper animation HOLD till camera 02
        Scene 02: Camera 02 ( midpoint dolly to camera 3) - Proper animation get position 01 (start)
        Scene 03: Camera 03 - Proper animation get position 02
        Scene 04: Camera 04 - Proper animation get position 03
        Scene 05: Camera 05 - Proper animation HOLD or repeat position 03
        I read in the manual: To Unlink objects animation with “scene” changes, in order to “set” new adjusted positions
        1. Menu -> Plugins -> Proper Animation -> Stop Scenes observer
        2. Stop and Start again Animation Observer to reflect new set positions
          if you have set new positions while the “Scenes observer” was still started
        I've been trying this for a couple weeks and still cannot find a tutorial for creative use of the plugin or a manual that has this information. But, the scene delay times seems like the proper way to accomplish this... but, I can't get it as I'd like. Is there a video that demonstrate precision use of scene delay times to do this right?
        Can it be done?
        Thank you
        Duane Kemp
        Kemp Productions
        Puidoux, Switzerland
        Gallery:
        https://duanekemp.artstation.com/
        • V
          vizualism
          Thank you for your extraordinary plugin; I love Proper Animation! Did a first project with it. So helpful! https://youtu.be/alvABRdEMC0
          Keep up the good work!
          Frederik
          • T
            Tim Goffard
            I like the concept, but it does not want to do what I am trying to do. I am trying to animate a folding staircase and a murphy bed. I got the starting and ending positions to work, but during the transition, the staircase floats off it's hinges and twirls around before settling back down to the second position. I just want a simple hinge. In OSX, is there a way to set the axes of rotation along the axis of the hinge? Imagine a basic door-I don't want the door to come out of the frame and place itself back in the open position-I just want it to open on the hinges! I can't find any way to set the axis of rotation on mac.
            • ntxdaveN
              ntxdave
              Frederik
              I liked this very much.
              After what I have read, I would like to know how you produced the movie (read that you cannot produce movies with the plugin). Did you use any rendering engine? Also in your movie, you have text highlighting various aspects of your model. Could you elaborate a little more on what all software and processes you used?
              I want to build an animated car wash. I have used Keyframe Animation plugin with some pretty good results but right now the car wash components are not inside of a building. I want to put the equipment inside a building and use something to render it and improve the quality (although I am satisfied with NPR).
              Press F1...thank me later
              • CjWhitsettC
                CjWhitsett
                Moris Dov - are you still out there? Your plugin for Proper Animation seems like a great fit for what I'm trying to do but this post I'm replying to is about 6 years old. Is there a current version of your extension that will work with SU Pro 2016?
                Thanks very much - CjW
                  mgfranz
                  Using SU 2016, Is there a way to run an animation that allows me to edit a group or component midway through scenes? Meaning I can Set a component to place, then move that component to Set place, but then I want to edit another component and move both to a location and then Set another scene. When I try this, the edited component shows up as modified in all scenes.
                  13x3 Exploded_Anim.skp
                  "If you like what you do, it will never be work..."
                  In memory of Sam Maloof, 1916-2009
                    Akansha0027
                    hello i am student.
                    i need little help.
                    can any one tell me how save this plugin file model in video format.
                    • duanekempD
                      duanekemp
                      As there are new posts here, it might be good to point out the following:
                      @morisdov's last comment in this thread was Fri Apr 13, 2012 (almost 11 years ago).
                      Any further development of the plugin seems to have been abandoned at that time with no new responses to questions (by the author) since.
                      Just don't hold your breath for any support or feedback on this one as the last update was posted Here:
                      https://sketchucation.com/forums/viewtopic.php?f=323&t=10946&start=210#p397936
                      Duane Kemp
                      Kemp Productions
                      Gallery:
                        j_jones
                        Does anyone still have a copy of this plugin? The original google pages site is long gone.
                        Thanks for any info
                        -j_jones
                        • duanekempD
                          duanekemp
                          Try the link on the first post: https://sketchucation.com/forums/viewtopic.php?f=323&t=10946#p74003
                          The direct download link still seems to work: https://sketchucation.com/forums/download/file.php?id=58546
                          Duane Kemp
                          Kemp Productions
                          Gallery:
                          • 11
                          • 12
                          • 13
                          • 13 / 13
