    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 203.7k Views 108 Watching
      jars121
      @cody.sheridan-2008 said:
      hi all,
      I have done an animation using this plugin but have run into a problem. When I get to the 9th scene the movement changes from fluid to suddenly moving to the next position. I have attached the model so if you can help that would be really appreciated!
      EDIT: No worry's I have solved my problem now...
      Hi everyone,
      I'm having this exact problem. Scenes 1-7 are working perfectly. I have followed the same method for Scene 8, but the component jumps from position 7 to position 8 without actually animating. What's the problem?
        tomasz
        It looks, that the plugin doesn't apply a default value for animation easing for those additional positions. To solve the issue open and close the 'animation easing' options. 😒
        @Moris
        Proper_animation takes into account also those scenes that are not used/included in the animation. They have [] around their names. If such a scene is preset at the beginning of the animation, it ruins the whole thing.
          tomasz
          There is a bug with flipped groups.
          A group on the right moves 1 m upwards, but on its way it forgets it is flipped.
          Bug with flipped group
            timinder
            I'm having problems with tis plugin with SU2013.
            I've set up a model, assigned 5 different positions, created 5 scenes. All OK.
            When I start the scenes observer, select first tab and then "get position1" SU crashes. Every time.
            Does anyone have any ideas as to what I can do to fix it, or is it something that others have experienced?
              pankaj_tamore
              Dear Morisdov,
              First of all let me congratulate you for developing such very useful plugin.I saw the videos of your incredible "proper animation" plugin and it really, really wowed me.in fact this was exactly what i had needed for long time? now my search for much desired plugin got over but unfortunately efforts for installing same haven't got over. because repeatedly since yesterday i have been trying to install it in vain.i have also attached error dialogue box screen shot which shows up on screen for your kind reference. 👍
              Error report
              • mitcorbM Offline
                mitcorb
                Greetings, pankaj:
                Are there any other load errors besides the ones visible in your image? An advisor will want to see that in order to help sort this out.
                • V Offline
                  val_jacob
                  Hi!
                  I just started using properanimation and I find it quite useful!
                  I have the following problem and did not find the answer in the previous posts. I changed the style of the sketchup in which I'm using properanimation. I changed the style on every scene to make sure that the new style I wanted would apply throughout my animation. My problem is in between each scene: the original style comes back, making a kind of "flashy" animation between two styles.
                  Does anybody have a clue how to prevent that from happening? (starting from scratch is not the answer I hope for...!)
                  Thank you!
                    Jim
                    I don't have proper animation, but you could try this.
                    1. Select all Scenes in the Scene manager, then (2) unselect the Styles and Fog option.
                      charvi
                      @daniel s said:
                      Thank you!!! 😍 😍 😍
                      It works Great!!! And the plugin supports position and scale transformations!
                      I only have problems with some rotations.. look at the attach video. The simple box is rotated 90° from the center point but in the animation looks strange.
                      Now you can set up to 4 positions. Can you add more?? 4 is not sufficient for this so amazing plugin.
                      Thank You!!!
                      Daniel S
                      Hi Daniel,
                      I am trying to animate a scale, but it gives me only first and last frame - nothing (animation) between.
                      Could you please confirm it is working (with full animation)?
                      If so, any example?
                      Thank you so much.
                      Regards
                      Jakub
                      • kimi kimiK Offline
                        kimi kimi
                        @morisdov said:
                        quick solution is to use the following line in the ruby console to set the current selected scene -
                        Sketchup.active_model.pages.selected_page.transition_time = 4
                        Hi, I'm also having a problem when I want to change transition times. I can't see all the scenes on the screen. The quoted describes how to change it for a particular page, but I wan't to change transition times for a range of pages that fall outside the screen.
                        Is there a code to do this for all pages? Or for pages, let's say 23-39?
                        • duanekempD Offline
                          duanekemp
                          Though I've read this thread and others, and the link to the .pdf (https://ligonsketchers.files.wordpress.com/2011/03/proper-animation-tutorial.pdf), I have not found the answer that explains how to do the following:
                          Scene 01: Camera 01 - Proper animation HOLD till camera 02
                          Scene 02: Camera 02 ( midpoint dolly to camera 3) - Proper animation get position 01 (start)
                          Scene 03: Camera 03 - Proper animation get position 02
                          Scene 04: Camera 04 - Proper animation get position 03
                          Scene 05: Camera 05 - Proper animation HOLD or repeat position 03
                          I read in the manual: To Unlink objects animation with “scene” changes, in order to “set” new adjusted positions
                          1. Menu -> Plugins -> Proper Animation -> Stop Scenes observer
                          2. Stop and Start again Animation Observer to reflect new set positions
                            if you have set new positions while the “Scenes observer” was still started
                          I've been trying this for a couple weeks and still cannot find a tutorial for creative use of the plugin or a manual that has this information. But, the scene delay times seems like the proper way to accomplish this... but, I can't get it as I'd like. Is there a video that demonstrate precision use of scene delay times to do this right?
                          Can it be done?
                          Thank you
                          Duane Kemp
                          Kemp Productions
                          Puidoux, Switzerland
                          Gallery:
                          https://duanekemp.artstation.com/
                          • V Offline
                            vizualism
                            Thank you for your extraordinary plugin; I love Proper Animation! Did a first project with it. So helpful! https://youtu.be/alvABRdEMC0
                            Keep up the good work!
                            Frederik
                              Tim Goffard
                              I like the concept, but it does not want to do what I am trying to do. I am trying to animate a folding staircase and a murphy bed. I got the starting and ending positions to work, but during the transition, the staircase floats off it's hinges and twirls around before settling back down to the second position. I just want a simple hinge. In OSX, is there a way to set the axes of rotation along the axis of the hinge? Imagine a basic door-I don't want the door to come out of the frame and place itself back in the open position-I just want it to open on the hinges! I can't find any way to set the axis of rotation on mac.
                              • ntxdaveN Offline
                                ntxdave
                                Frederik
                                I liked this very much.
                                After what I have read, I would like to know how you produced the movie (read that you cannot produce movies with the plugin). Did you use any rendering engine? Also in your movie, you have text highlighting various aspects of your model. Could you elaborate a little more on what all software and processes you used?
                                I want to build an animated car wash. I have used Keyframe Animation plugin with some pretty good results but right now the car wash components are not inside of a building. I want to put the equipment inside a building and use something to render it and improve the quality (although I am satisfied with NPR).
                                Press F1...thank me later
                                • CjWhitsettC Offline
                                  CjWhitsett
                                  Moris Dov - are you still out there? Your plugin for Proper Animation seems like a great fit for what I'm trying to do but this post I'm replying to is about 6 years old. Is there a current version of your extension that will work with SU Pro 2016?
                                  Thanks very much - CjW
                                    mgfranz
                                    Using SU 2016, Is there a way to run an animation that allows me to edit a group or component midway through scenes? Meaning I can Set a component to place, then move that component to Set place, but then I want to edit another component and move both to a location and then Set another scene. When I try this, the edited component shows up as modified in all scenes.
                                    13x3 Exploded_Anim.skp
                                    "If you like what you do, it will never be work..."
                                    In memory of Sam Maloof, 1916-2009
                                      Akansha0027
                                      hello i am student.
                                      i need little help.
                                      can any one tell me how save this plugin file model in video format.
                                        duanekemp
                                        As there are new posts here, it might be good to point out the following:
                                        @morisdov's last comment in this thread was Fri Apr 13, 2012 (almost 11 years ago).
                                        Any further development of the plugin seems to have been abandoned at that time with no new responses to questions (by the author) since.
                                        Just don't hold your breath for any support or feedback on this one as the last update was posted Here:
                                        https://sketchucation.com/forums/viewtopic.php?f=323&t=10946&start=210#p397936
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                          j_jones
                                          Does anyone still have a copy of this plugin? The original google pages site is long gone.
                                          Thanks for any info
                                          -j_jones
                                            duanekemp
                                            Try the link on the first post: https://sketchucation.com/forums/viewtopic.php?f=323&t=10946#p74003
                                            The direct download link still seems to work: https://sketchucation.com/forums/download/file.php?id=58546
                                            Duane Kemp
                                            Kemp Productions
                                            Gallery:
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
