    Applying texture
    4 Posts 3 Posters 314 Views 3 Watching
      matsuo_lano
      Hello,
      I've modeled a stone block, found attached, using Artisan. There are three ways I tried texturing, not quite successful:
      • Using the paint brush function of Artisan
      • UV placement from V-Ray
      • ThruPaint from Fredo
      I've attached screenshots from each method, to show what happens.
      I also tried SketchUV, but that seems to do nothing at all!
      What would be the best way of texturing the model?
      original model
      painted using Artisan
      painted with ThruPaint
      V-Ray UV tools
      You try to rearrange me 'till I'm sane
        It would be best to UV unwrap it....
        https://i.imgur.com/RpcPxqj.png
        In this instance I used Wrap-R for SketchUp. But since it's mesh data you can unwrap it in whatever you wish.
        block-[uv].skp
          matsuo_lano
          That sounds like good solution, I'll try it out. Thanks for the help!
          • fredo6F
            With ThruPaint, use the Natural UV mode, not the QuadMesh UV mode. Your shape is not based on a quad mesh.
