    Fredo Plugins Error
    extensions
    26 Posts 15 Posters 7.7k Views 15 Watching
      SpicolisDad
      Similar problem to others here with Fredo Plugins - All licensed up (glad Fredo is getting some dough!)
      Symptoms:
      Get the "trial license expired" message - go to validate - navigate to where I stored my license files- The License files are invisible.(though actually there)
      So ...no validation is possible...
      The Answers:
      Yes I searched before asking. πŸ˜„
      Yes - I had to repair my SU install after a nasty fight with Vray's latest version.
      Yes- IIRC everything worked before that though Im not 100% sure.
      Followed several similar threads with various fixes suggested there-
      So far I tried:
      Deleting the C:/user data fredo folder,
      Uninstalling Sketchucation tools.
      Reinstalling Sketchucation Tools to latest
      Ran Fredo Updater - everything green and "up to date"
      Obviously a path or permissions issue somewhere....checker can't/won't/doesn't see the licenses -
      any help on getting it pointed correctly?
      Fear we're headed to a "gut it/scorched earth" situation here...a lengthy process
      Thanks for all you do!
        https://i.imgur.com/HSlz8qv.png
        The license won't show if it is not the correct name.
        https://i.imgur.com/ZeFQFJa.png
        If you set All Files what do you see?
          SpicolisDad
          Thank you for your assistance:
          As usual- the problem was down to user error.
          I became confused by a similarly named but now deprecated older plug in.
          In process of creating detailed screen shots documenting the loop I was in...
          I finally realized my mistake.
          you see my Skethucation friends....apparently I'm afflicted with what they call, in todays vernacular, "the big dumb"
          But, I draw well, and have good grooming habits..so I've got that going for me which is nice....
          Anyway...please disregard my prior post. All is well.
          The plugins now function as expected - (as they will do when installed correctly and not fighting with other plug ins)
          I couldn't be happier.
          Once again thanks I'm very grateful for the prompt support offered by this forum.
          you guys are great.
          -Spicoli's Dad
            You'll fit right in around here with those credentials πŸ‘
              janvin
              Not to bring this error up once again in 2023, but I'm experiencing it as well with SU 2021, FredoGhost v2.0a, FredoLib 13.7b, and Sketchucation Toolset v4.3.
              After getting the error and restarting SU, the toolbar appears but when trying to open the Studio tool or activating the other limited tools that are available with the trial version, nothing happens, no messages or anything.
              Disabled all plugins including Sketchucation v4.3 but except for Fredolib 13.7bb.
              Uninstalled FredoGhost.
              Started up SU 2021 - installed FredoGhost - got the regular Restart SU message.
              Restart SU 2021.
              FredoGhost toolbar appears - click on Studio tool and the Studio window opens as it should = baseline.
              Open Extension Manager - one by one enabling plugins followed immediately by clicking on the Studio tool.
              Enabled Sketchucation v4.3 - click FredoGhost Studio tool - no Studio window opens.
              Immed. disable Sketchucation v4.3 - click on FredoGhost Studio tool - no Studio window opens.
              Restart SU 2021.
              FredoGhost toolbar appears - click on Studio tool and the Studio window opens as it should.
              I continued through the list of plugins to see if any others prevented FredoGhost Studio from opening, all good except for Sketchucation is still disabled. I'll leave it disabled for now as I trial Ghost and hopefully if all works well, I will get that Ghost license and a new version Sketchucation will be released that doesn't cause this conflict.
              • fredo6F
                Before launching FredoGHost, could you open the Ruby Console and check if there are errors.
                • C
                  chrissfcs
                  I am getting a similar error on the tools on surface plug in. I uninstalled all plugins and started fresh with the latest libfredo and tools on surface plug in so that no others would interfere. Still the same error. Other plugins from fredo 6 are working correctly.
                  using 2022. the error messages are attached.
                  Thanks.
                    arhimas Newcomers
                    Hello everybody!. I'm having some issues trying to round some corners and edges. This is the output:
                    Date: 15-Jun-23 16:56:28
                    An error occurred in FredoCorner
                    An error occured in the Ruby code
                    undefined method `[]' for nil:NilClass
                    fredocorneralgo.rbe: 2316 -- brane_free_chemin
                    fredocorneralgo.rbe: 2061 -- block in catena_process_branes_protected
                    fredocorneralgo.rbe: 2047 -- each
                    fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                    fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                    fredocorneralgo.rbe: 2008 -- catch
                    fredocorneralgo.rbe: 2008 -- catena_process_branes
                    fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                    fredocorneralgo.rbe: 964 -- each
                    fredocorneralgo.rbe: 964 -- solid_construct_branes
                    fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                    fredocorneralgo.rbe: 918 -- each
                    fredocorneralgo.rbe: 918 -- solid_reconstruction
                    fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                    fredocornertool.rbe: 1840 -- selection_change
                    fredocornertool.rbe: 1828 -- selection_add_remove_edges
                    fredocornertool.rbe: 1868 -- selection_mouse_up
                    fredocornertool.rbe: 2300 -- onLButtonUp
                    Any ideas?
                    • fredo6F
                      Any ideas?
                      Difficult to tell without seeing the model.
                      It is likely related to an offset which is too large compared with the size of the edges you try to perform the rounding on.
                        Dyllanolv
                        please help! Freddo asks me to validate licenses again when he had previously validated them and they worked correctly. Now when I try to validate the licences again I get this error...
                        Error in the License Validation
                        Request to Sketchucation: ERROR AOC
                        Computer name mismatch - It is advised to erase the Signature file and revalidate
                        Do you want to open the folder containing the Signature file?
                        [/img]C:\Users\Usuario\Downloads\Captura.PNGq.PNG[/img]
                        • fredo6F
                          Please just do what is suggested in the dialog box.
                          M 1 Reply Last reply
                            mrwick @fredo6
                            @fredo6 Hey how am i supposed to do it please I paid a lot of money to buy 8 plugins just tell me how to revalidate and where
                              Rich O Brien Moderator @mrwick
                              @mrwick https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                              Licenses are at https://sketchucation.com/webshop/my-licences.php
                              You need latest releases of all extensions installed including Sketchucation Tools
                              https://sketchucation.com/plugin/696-sketchucationtools
                              ...and Libfredo
                              https://sketchucation.com/pluginstore?pln=LibFredo6
                              • 2 / 2
